Patch by Murray Jensen, 08 Jul 2005
Patch by Andy Fleming, 14 Jun 2005
Patch by Gerhard Jaeger, 21 Jun 2005
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
Patch by Greg Ungerer, 04 Jun 2005
Patch by Greg Ungerer, 21 May 2005
Code cleanup.
Controller.
* For READ_STATUS and READID commands always 8 bytes need to be read from
NDDB. Otherwise they stay there and get send to flash as the first data
word when writing.
* In nand_base.c the oob variable is not reset so this->oob_buf is
overwritten what eventually screws up the bad block descriptor table.
Rewrite of NAND code based on what is in 2.6.12 Linux kernel
Patch by Ladislav Michl, 29 Jun 2005
[Merge with /home/tur/nand/u-boot]
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and
BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for
NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is
implemented for these boards.
Patch by Stefan Roese, 1 Mar 2006
* Add env-variable "unlock" to handle initial state of sectors
(locked/unlocked).
Only the U-Boot image and it's environment is protected,
all other sectors are unprotected (unlocked) if flash
hardware protection is used (CFG_FLASH_PROTECTION) and
the environment variable "unlock" is set to "yes".
Patch by Stefan Roese, 28 Feb 2006
* Update drivers/cfi_flash.c:
- find_sector() called in both versions of flash_write_cfiword()
Patch by Peter Pearse, 27th Feb 2006
* CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode
Patch by Jose Maria Lopez, 16 Jan 2006
* Add support for AMD/Spansion Flashes in flash_write_cfibuffer
Patch by Alex Bastos and Thomas Schaefer, 2005-08-29
* Changes/fixes for drivers/cfi_flash.c:
We *should* check if there are any error bits if the previous call
returned ERR_OK (Otherwise we will have output an error message in
flash_status_check() already.) The original code would only check for
error bits if flash_status_check() returns ERR_TIMEOUT.
Patch by Marcus Hall, 23 Aug 2005
- Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c
- Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c
Patch by Sangmoon Kim, 19 Aug 2005
* Fixes for drivers/cfi_flash.c:
- Fix wrong timeout value usage in flash_status_check()
- Round write_tout up when converting to msec in flash_get_size()
- Remove clearing flash status at the end of flash_write_cfibuffer()
which sets Intel 28F640J3 flash back to command mode on CSB472
Patch by Tolunay Orkun, 02 July 2005
This is a first version of the testing-NAND branch merged back to main.
Register Definitions.
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file().
Patch by Reinhard Arlt, 30 Dec 2005
We need to adjust the bus number we are trying to access based
on which PCI controller its on
Patch by Kumar Gala 12 Jan 2006
Patch by Kumar Gala 11 Jan 2006
If a host controller sets up a region as prefetchable and
a device's BAR denotes it as prefetchable, allocate the
BAR into the prefetch region.
If a BAR is prefetchable and no prefetchable region has
been setup by the controller we fall back to allocating
the BAR into the normally memory region.
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c
- CFG_FLASH_QUIET_TEST added to use the common CFI driver
for bank autodetection
Patch by Stefan Roese, 22 Nov 2005
Patch by Mike Rapoport, 01 Nov 2005
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Patch by Art Shipkowski, 12 May 2005
Cleanup.
Patch by James MacAulay, 07 Oct 2005
Patch by Anders Larsen, 07 Oct 2005
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board.
Patch by Stefan Roese, 08 Oct 2005
Patch by Marcus Hall, 24 Aug 2005
Patch by Anders Larsen, 29 Apr 2005
* Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005
(8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
Patch by Rowel Atienza, 06 Apr 2005
Patch by Gleb Natapov, 21 Mar 2005
- Resolve the FIXME with respect to saving the u-boot environment.
- Make the default load address land in real memory.
- Fix lan91c96 SMC_{in,out}{b,w,l}() macros
Patch by David Brownell, 10 Mar 2005
- fix for ES2 differences.
- switch to using the cfi_flash driver.
- fix SRAM build address.
- fix for GP device operation.
- unlock SRAM for GP devices.
- display more device information.
- fix potential deadlock in omap24xx_i2c driver.
- fix DLL load values to match dpllout*1 operation.
- fix 2nd chip select init for combo DDR device.
- add support for CFI Intel 28F256L18 on H4 board.
Patch by Richard Woodruff, 03 Mar 2005
Patch by Zachary Landau, 11 Feb 2005
Use drivers/cfi_flash.c instead of private flash driver;
Remove hardcoded personalized settings from omap5912osk.h;
Fix spacing with (RO) marks in 'flinfo' output.
Patch by Michael Bendzick, 14 Jan 2005
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
Fix "WARNING: flash_make_cmd: unsuppported LittleEndian mode"
message when probing for nonexistent flash in little endian mode.
As a side effect more efficient and smaller code is generated,
which is always a Good Thing (TM).
Patch by Ladislav Michl, 24 Sep 2005
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP).
Add support for eeprom write-enable (CFG_EEPROM_WREN).
Patch by Stefan Roese, 22 Sep 2005
Patch by Stefan Roese, 21 Sep 2005
