In order to test that U-Boot actually maintains the watchdog device(s)
during long-running busy-loops, such as those where we wait for the
user to stop autoboot, we need a watchdog device that actually does
something during those loops; we cannot test that behaviour via the DM
test framework.
So introduce a relatively simple watchdog device which is simply based
on calling the host OS' alarm() function; that has the nice property
that a new call to alarm() simply sets a new deadline, and alarm(0)
cancels any existing alarm. These properties are precisely what we
need to implement start/reset/stop. We install our own handler so that
we get a known message printed if and when the watchdog fires, and by
just invoking that handler directly, we get expire_now for free.
The actual calls to the various OS functions (alarm, signal, raise)
need to be done in os.c, and since the driver code cannot get access
to the values of SIGALRM or SIG_DFL (that would require including a
host header, and that's only os.c which can do that), we cannot simply
do trivial wrappers for signal() and raise(), but instead create
specialized functions just for use by this driver.
Apart from enabling this driver for sandbox{,64}_defconfig, also
enable the wdt command which was useful for hand-testing this new
driver (especially with running u-boot under strace).
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Add support for hardware watchdog timer for Amlogic SoCs.
This driver has been heavily inspired by his Linux equivalent
(meson_gxbb_wdt.c).
Reviewed-by: Jerome Brunet <jbrunet@baylibre.com>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Philippe Boos <pboos@baylibre.com>
MAX6370 watchdog is available e.g. on Freescale P1/P2 RDB-PC boards.
Signed-off-by: Pali Rohár <pali@kernel.org>
As removal of nds32 has been ack'd for the Linux kernel, remove support
here as well.
Cc: Rick Chen <rick@andestech.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Add watchdog controller driver for NPCM7xx/npcm8xx
the wdt design of npcm750 and npcm845 is the same.
so the driver can work on npcm750 and npcm845.
about npcm845 wdt dtsi i will followed kernel dts name
to use nuvoton,npcm750-wdt.
Signed-off-by: Jim Liu <JJLIU0@nuvoton.com>
The watchdog timer is part of the sl28cpld management controller. The
watchdog timer usually supervises the bootloader boot-up and if it bites
the failsafe bootloader will be activated. Apart from that it supports
the usual board level reset and one SMARC speciality: driving the
WDT_TIMEOUT# signal.
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This driver supports the watchdog timer found on Apple's M1 SoC.
On systems that use these SoC, the watchdog timer is the primary
way to reboot the system.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Reviewed-by: Sven Peter <sven@svenpeter.dev>
Tested-on: Apple M1 Macbook
This driver supports the sun4i/sun6i/sun20i watchdog timers.
They have a maximum timeout of 16 seconds.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
A rather common kind of external watchdog circuit is one that is kept
alive by toggling a gpio. Add a driver for handling such a watchdog.
The corresponding linux driver apparently has support for some
watchdog circuits which can be disabled by tri-stating the gpio, but I
have never actually encountered such a chip in the wild; the whole
point of adding an external watchdog is usually that it is not in any
way under software control. For forward-compatibility, and to make DT
describe the hardware, the current driver only supports devices that
have the always-running property. I went a little back and forth on
whether I should fail ->probe or only ->start, and ended up deciding
->start was the right place.
The compatible string is probably a little odd as it has nothing to do
with linux per se - however, I chose that to make .dts snippets
reusable between device trees used with U-Boot and linux, and this is
the (only) compatible string that linux' corresponding driver and DT
binding accepts. I have asked whether one should/could add "wdt-gpio"
to that binding, but the answer was no:
https://lore.kernel.org/lkml/CAL_JsqKEGaFpiFV_oAtE+S_bnHkg4qry+bhx2EDs=NSbVf_giA@mail.gmail.com/
If someone feels strongly about this, I can certainly remove the
"linux," part from the string - it probably wouldn't the only place where
one can't reuse a DT snippet as-is between linux and U-Boot.
Add a driver for the PowerPC Book E watchdog driver that is present on a
number of Freescale/NXP SoCs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This patch adds watchdog support for the Mediatek MT7620 SoC
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
AST2600 has 8 watchdog timers including 8 sets of
32-bit decrement counters, based on 1MHz clock.
A 64-bit reset mask is also supported to specify
which controllers should be reset by the WDT reset.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Reviewed-by: Ryan Chen <ryan_chen@aspeedtech.com>
Adds support for Core 0 watchdog poke on OcteonTX and OcteonTX2
platforms.
Signed-off-by: Suneel Garapati <sgarapati@marvell.com>
This is based on the Linux kernel driver for the RTI watchdog.
To actually reset the system on an AM65x, it requires firmware running
on the R5 that accepts the NMI and issues the actual system reset via
TISCI. Kind of an iTCO, except that this watchdog hardware has support
for no-way-out, and only for that.
On the J721E, reset works without extra firmware help when routing the
RTI interrupt via the ESM.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
According to Server Base System Architecture (SBSA) specification,
the SBSA Generic Watchdog has two stage timeouts: the first signal
(WS0) is for alerting the system by interrupt, the second one (WS1) is a
real hardware reset.
More details about the hardware specification of this device:
ARM DEN0029B - Server Base System Architecture (SBSA)
This driver can operate ARM SBSA Generic Watchdog as a single stage
In the single stage mode, when the timeout is reached, your system
will be reset by WS1. The first signal (WS0) is ignored.
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Add support for Xilinx window watchdog, which can be found on
Versal platforms.
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Add support for hardware watchdog timer on all Cortina Access
CAxxxx family of SoCs.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Jason Li <jason.li@cortina-access.com>
Signed-off-by: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
This patch adds device tree and driver model watchdog support,
converts the legacy omap watchdog driver to driver model for
TI AM335x chipsets. The following compile warning is removed:
===================== WARNING ======================
This board does not use CONFIG_WDT (DM watchdog support).
Please update the board to use CONFIG_WDT before the
v2019.10 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/MIGRATION.txt for more info.
CONFIG_HW_WATCHDOG is no more a default option for AM33XX devices
after DT/DM conversion, adjusted kconfig accordingly.
DM watchdog support is enabled by default in SPL. The SPL image
doesn't fit into SRAM because of size constraints and build breaks
with an overflow. For this reason DM watchdog support should be
disabled in SPL, driver code should be adjusted accordingly to serve
this purpose.
Built and tested on AM335x device (BeagleboneBlack), compile tested
for all other AM33xx based boards.
Signed-off-by: Suniel Mahesh <sunil.m@techveda.org>
The BCM2835/2836 watchdog is not used in mainline U-Boot at all. This
patch removes the driver and its references (CONFIG_BCM2835_WDT)
completely.
Cc: Paolo Pisati <p.pisati@gmail.com>
Use CONFIG_IS_ENABLED(WDT) to permit use of WDT in SPL without DM,
while the full U-Boot can use rich DM/DT WDT driver.
Cc: Peng Fan <Peng.Fan@freescale.com>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Suniel Mahesh <sunil.m@techveda.org>
Convert legacy driver to use watchdog class.
This patch adds IWDG (Independent WatchDoG) support for
STM32MP platform.
Signed-off-by: Christophe Kerello <christophe.kerello@st.com>
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
sp805 is watchdog on some NXP layerscape SoCs, adding
it's driver. Configs CONFIG_WDT_SP805, CONFIG_WDT, CONFIG_CMD_WDT
needs to be enabled to use it.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
With the generic watchdog driver now implemented, this patch removes
some legacy stuff from the MPC8xx watchdog driver and its Kconfig
integration. CONFIG_MPC8xx_WATCHDOG is completely removed and
hw_watchdog_reset() is made static, as the watchdog will now get
serviced via the DM infrastructure if enabled via CONFIG_WATCHDOG.
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Support watchdog driver for fsl-lsch2. It's disabled in default.
If you want to use it, please enable CONFIG_IMX_WATCHDOG.
Define CONFIG_WATCHDOG_TIMEOUT_MSECS to set watchdog timeout.
Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
This patch adds a common driver for the Mediatek SoC integrated
watchdog.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Tested-by: Matthias Brugger <matthias.bgg@gmail.com>
This patch adds watchdog support for the Mediatek MT7621 SoC. The driver
is loosly based on the Linux kernel version.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
[fixed merge conflict in drivers/watchdog/Kconfig]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Convert the Watchdog driver for AT91SAM9x processors to support
the driver model and device tree. Changes "CONFIG_AT91SAM9_WATCHDOG"
to new "CONFIG_WDT_AT91" Kconfig option.
Signed-off-by: Prasanthi Chellakumar <prasanthi.chellakumar@microchip.com>
The existing imx_watchdog driver is compatible with mx25 chipsets.
Add a WDOG1_BASE_ADDR define for the base address and enable the driver
in watchdog's Makefile.
To use the driver, a board must define CONFIG_IMX_WATCHDOG and
CONFIG_HW_WATCHDOG.
This fixes an issue when booting an mx25 chip via usb/serial. In this
case, the boot rom will always enable the watchdog. If u-boot is running
in interactive mode and the watchdog is not serviced, the system is
rebooted when the watchdog expires.
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This adds support for the CPU watchdog found on Marvell Armada 37xx
SoCs.
There are 4 counters which can be set as CPU watchdog counters.
This driver uses the second counter (ID 1, counting from 0)
(Marvell's Linux also uses second counter by default).
In the future it could be adapted to use other counters, with
definition in the device tree.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
In preparation of DM watchdog, move basic actions into drivers/watchdog
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
This IP can be found on Zynq and ZynqMP devices.
The driver was tested with reset-on-timeout; feature.
Also adding WATCHDOG symbol to Kconfig because it is required.
Signed-off-by: Shreenidhi Shedi <imshedi@gmail.com>
Add watchdog driver for Intel Tangier based platforms.
Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
The Orion watchdog can be found on some Marvell Armada chips.
This driver is based on the code by Tomas Hlavacek in the CZ.NIC
turris-omnia-uboot repository, which can be found at
https://gitlab.labs.nic.cz/turris/turris-omnia-uboot, and that
one is based on code by Sylver Bruneau. His code is already in
mainline Linux kernel.
The code uses the new driver model API.
Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz>
create mode 100644 drivers/watchdog/orion_wdt.c
This driver is a simplified version of linux/drivers/watchdog/bcm63xx_wdt.c
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Paolo Pisati <p.pisati@gmail.com>
This driver supports ast2500 and ast2400 SoCs.
Only ast2500 supports reset_mask and thus the option of resettting
individual peripherals using WDT.
Signed-off-by: Maxim Sloyko <maxims@google.com>
This is a simple uclass for Watchdog Timers. It has four operations:
start, restart, reset, stop. Drivers must implement start, restart and
stop operations, while implementing reset is optional: It's default
implementation expires watchdog timer in one clock tick.
These drivers have no user since commit ea3310e8aafa ("Blackfin:
Remove").
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
This driver implements the HW WATCHDOG functions. Which needs
to set CONFIG_HW_WATCHDOG to use them. This is disabled by default for
mx7ulp.
Use watchdog for reset cpu. Implement this in the driver.
Need to define CONFIG_ULP_WATCHDOG to build it.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Ye Li <ye.li@nxp.com>
Since commit 623d96e89aca6("imx: wdog: correct wcr register settings")
issuing a 'reset' command causes the system to hang.
Unlike i.MX and Vybrid, the watchdog controller on LS102x is big-endian.
This means that the watchdog on LS1021 has been working by accident as
it does not use the big-endian accessors in drivers/watchdog/imx_watchdog.c.
Commit 623d96e89aca6("imx: wdog: correct wcr register settings") only
revelead the endianness problem on LS102x.
In order to fix the reset hang, introduce a reset_cpu() implementation that
is specific for ls102x, which accesses the watchdog WCR register in big-endian
format. All that is required to reset LS102x is to clear the SRS bit.
This approach is a temporary workaround to avoid a regression for LS102x
in the 2015.10 release. The proper fix is to make the watchdog driver
endian-aware, so that it can work for i.MX, Vybrid and LS102x.
Reported-by: Sinan Akman <sinan@writeme.com>
Tested-by: Sinan Akman <sinan@writeme.com>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Add imx-common cpu support for imx7d SoC
- Update reset_cause for imx7d
- Enable watchdog driver built for imx7d
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
This is still a non-generic board.
Cc: Chan-Taek Park <c-park@ti.com>
The QorIQ LS1 family is built on Layerscape architecture,
the industry's first software-aware, core-agnostic networking
architecture to offer unprecedented efficiency and scale.
Freescale LS102xA is a set of SoCs combines two ARM
Cortex-A7 cores that have been optimized for high
reliability and pack the highest level of integration
available for sub-3 W embedded communications processors
with Layerscape architecture and with a comprehensive
enablement model focused on ease of programmability.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: Jingchang Lu <jingchang.lu@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
To add the DesignWare watchdog driver support. It required
information such as register base address and clock info from
configuration header file within include/configs folder.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Add TI OMAP 16xx & 24xx/34xx 32KHz (non-secure) watchdog support.
Reviewed-by: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
drivers/serial/Makefile
