path: root/drivers/video
2015-06-10Remove typedefs from bmp_layout.hSimon Glass
We try to avoid typedefs and these ones are easy enough to remove. Before changing this header in the next patch, remove the typedefs. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-09tegra: lcd: Tidy up clock initSimon Glass
Use the correct function for clock init. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-04x86: Move FRAMEBUFFER_SET_VESA_MODE etc to video KconfigBin Meng
CONFIG_FRAMEBUFFER_SET_VESA_MODE and CONFIG_FRAMEBUFFER_VESA_MODE are not x86-specific, so move them to drivers/video/Kconfig and make them depend on VIDEO_VESA driver. Some cosmetic fixes are applied to the Kconfig help text as well. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04video: Kconfig: Make VESA driver avaiable for non-x86 boardsBin Meng
There is no reason to prevent CONFIG_VIDEO_VESA driver working on non-x86 boards, so remove such limitation. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-28cosmetic: change Author/MAINTAINER Name from Petermaier to SchmelzerHannes Schmelzer
Since i've been married, i also have a new surname. Mr. Petermaier moved to Mr. Schmelzer. In this patch i update all files in which my (old) name is present. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-05-19sunxi: video: Fix lvds panel support for sun6i+Hans de Goede
We've never tested the lvds panel support on sun6i+ SoCs until now, and unsurprisingly the lvds code needed some fixes to work on my ga10h A33 tablet with lvds panel. This makes the panel on that tablet actually work. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-13tegra124: video: Add full link training for eDPSimon Glass
Add full link training as a fallback in case the fast link training fails. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: video: support eDP displays on Tegra124 devicesSimon Glass
Connect up the clocks and the eDP driver to make these displays work with Tegra124-based devices. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: video: Add Embedded DisplayPort driverSimon Glass
This interface is used on laptop devices based on Tegra. Add a driver which provides access to the eDP interface. The driver uses the display port uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra: video: Support serial output resource (SOR) on tegra124Simon Glass
The SOR is required for talking to eDP LCD panels. Add a driver for this which will be used by the DisplayPort driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13dm: video: Add a uclass for display portSimon Glass
eDP (Embedded DisplayPort) is a standard widely used in laptops to drive LCD panels. Add a uclass for this which supports a few simple operations. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-04sunxi: display: Fix gpio handling to work with the driver-modelHans de Goede
The driver-model gpio functions may return another value then -1 as error, make the sunxi display code properly handle this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Add basic A33 basic supportVishnu Patekar
Enable full support for the A33 SoC including display, otg-usb, etc. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Introduce a hidden SUNXI_GEN_SUNxI Kconfig boolHans de Goede
sun6i and newer (derived) SoCs such as the sun8i-a23, sun8i-a33 and sun9i have a various things in common, like having separate ahb reset control registers, the SID living inside the pmic, custom pmic busses, new style watchdog, etc. This commit introduces a new hidden SUNXI_GEN_SUN6I Kconfig bool which can be used to check for these features avoiding the need for an ever growing list of "#if defined CONFIG_MACH_SUN?I" conditionals as we add support for more "new style" sunxi SoCs. Note that this commit changes the behavior of the gmac and hdmi code for sun8i and the upcoming sun9i devices. This does not matter as sun8i does not have gmac nor hdmi, and sun9i has new hardware-blocks for these so the old code will not work there. Also this is intentional as if a sun8i / sun9i variant which does use the old hwblocks shows up then the GEN_SUN6I code paths will be the right ones to use. For completeness this also adds a SUNXI_GEN_SUN4I bool for A10/A13/A20. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-20Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2015-04-20video, lg4573: add support for the lg4573 displayHeiko Schocher
2015-04-20video, ipu: make ldb clock frequency overwritable through board codeHeiko Schocher
the ldb clock can be setup in board code (for example set through PLL5). Update the ldb_clock rate also through board code. This should be removed, if a clock framework is availiable. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
2015-04-20video, ipu: make ldb_clock configurableHeiko Schocher
make the ldb_clock configurable through the new define CONFIG_SYS_LDB_CLOCK. This is needed as the ldb clock is not always 650000000, for example on the aristainetos2 board, where the ldb clock derives from PLL5 clock. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Eric Nelson <eric.nelson@boundarydevices.com>
2015-04-16x86: video: Allow keyboard presence to be controlled by device treeSimon Glass
At present a VGA console assumes a keyboard unless a CONFIG option is set. This difference can be dealt with by a device tree option, allowing boards that are otherwise the same to use the same configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-15sunxi: GPIO pin mux hardware-feature-specific function index definesPaul Kocialkowski
Each hardware feature exposed through the GPIO pin mux is usually using the same function index (for a given port), so there is no need to define one value per pin: one value per hardware feature per port is sufficient, avoids duplication and makes everything easier to understand. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-06video: parade: configure SLP and RST GPIOs if specified in DTAjay Kumar
Add support to configure EDP_RST GPIO and EDP_SLP GPIO, if provided in parade DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-04-06video: exynos_fb: configure backlight GPIOs if specified in DTAjay Kumar
Add support to configure PWM_OUT(PWM output) GPIO and BL_EN(backlight enable) GPIO, if provided in FIMD DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-03-05drivers/video/am335x-fb: Add possibility to wait for stable power/pictureHannes Petermaier
Often on boards exists a circuit which switches power on/off to LCD display. Due to the need of limiting the in-rush current the output voltage from this circuit rises "slowly", so it is necessary to wait a bit (VCC ramp up time) before starting output on LCD-pins. This time is specified in <n> ms within the panel-settings, called "pup_delay" Further some LCDs need a couple of frames to stabilize the image on it. We have now the possibility to wait some time after starting output on LCD. This time is also specified in <n> ms within panel-settings, called "pon_delay" Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-02-20sunxi: video: Add support for tl059wv5c0 lcd panelsHans de Goede
Add support for the 6" 480x800 tl059wv5c0 panel used on e.g. Utoo P66 and Aigo M60/M608/M606 tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-20sunxi: video: Add support for LCD reset pinHans de Goede
On some boards there is a gpio to reset the LCD panel, add support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16sunxi: video: Dynamically reserve framebuffer memoryHans de Goede
Only use CONFIG_SUNXI_MAX_FB_SIZE to reserve memory at the top when relocating u-boot, and calculate the actual amount of memory necessary when setting up the video-mode and use only that, freeing up some additional memory for use by the kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-16sunxi: video: Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebufferHans de Goede
Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebuffer, instead override board_get_usable_ram_top to make sure that u-boot is not relocated into the area where we want to use the framebuffer, and patch the devicetree from sunxi_simplefb_setup() to tell the kernel to not touch the framebuffer. This makes u-boot properly see the framebuffer as dram, and initalize the level 2 cache for it, fixing the very slow cfb scrolling problem. As an added bonus this stops us from reserving the framebuffer when simplefb is not used because an older kernel is booted, or hdp is used and no hdmi cable was plugged in, freeing up the memory for kernel use in these cases. Reported-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-10lcd: introduce lcd_set_cmapNikita Kiryanov
Reduce the lcd_display_bitmap #ifdef complexity by extracting Atmel-specific code for setting cmap for bitmap images into a new function lcd_set_cmap(). A default version is implemented with the remainder of the code. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: mpc823: move mpc823-specific lcd_logo_set_cmap code to mpc8xx_lcd.cNikita Kiryanov
Reduce the bitmap_plot #ifdef complexity by extracting MPC823-specific code for setting cmap into its own implementation of lcd_logo_set_cmap(), implemented in mpc8xx_lcd.c. In the MPC823 implementation, ARRAY_SIZE(bmp_logo_palette) is switched for BMP_LOGO_COLORS to avoid having to include bmp_logo_data.h, which would cause a compilation error because the logo data and palette arrays would be defined twice. This is a step towards cleaning bitmap_plot() of platform-specific code. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: atmel: introduce lcd_logo_set_cmapNikita Kiryanov
Reduce the bitmap_plot #ifdef complexity by extracting Atmel-specific code for setting cmap into a new function lcd_logo_set_cmap(), which is implemented in atmel_lcdfb driver and defined as part of common/lcd.c api with a weak dummy version. In the Atmel implementation, ARRAY_SIZE(bmp_logo_palette) is switched for BMP_LOGO_COLORS to avoid having to include bmp_logo_data.h, which would cause a compilation error because the logo data and palette arrays would be defined twice. This is a step towards cleaning bitmap_plot() of platform-specific code. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: mpc8xx: move mpc823-specific fb_put_byte to mpc8xx_lcd.cNikita Kiryanov
Reduce the amount of platform-specific code in common/lcd.c by moving MPC823 implementation of fb_put_byte() to mpc8xx_lcd.c. Since we must also have a default implementation for everybody else, make the remainder of the code into a weak function. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: atmel: move atmel-specific fb_put_word to atmel_lcdfbNikita Kiryanov
Reduce the amount of platform-specific code in common/lcd.c by moving Atmel implementation of fb_put_word() to atmel_lcdfb.c. Since we must also have a default implementation for everybody else, make the remainder of the code into a weak function. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Bo Shen <voice.shen@atmel.com> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: split configuration_get_cmapNikita Kiryanov
configuration_get_cmap() is multiple platform-specific functions stuffed into one function. Split it into multiple versions, and move each version to the appropriate driver to reduce the #ifdef complexity. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-02-07ARM: atmel: cleanup: remove at91cap9 related codeBo Shen
As the at91cap9adk board is removed by commit: b5508344 (ARM: remove broken "at91cap9adk" board), so the at91cap9 code is not used anymore, and also the document for at91cap9 can not be found on www.atmel.com, so remove the at91cap9 related code. Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-05x86: bootstage: Add time measurement for vesa start-upSimon Glass
Since we must run a PCI BIOS ROM, and this can take a calamitous amount of time, measure it using bootstage. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-05x86: video: Allow video ROM execution to fall back to the other methodSimon Glass
If the BIOS emulator is not available, allow use of native execution if available, and vice versa. This can be controlled by the caller. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-05x86: video: Enable video for Minnowboard MaxSimon Glass
This board uses a new PCI ID. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-02Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2015-02-02sunxi: video: Force h/vsync active high when using ext. vga dac on some boardsHans de Goede
On both my A13-OLinuxIno and my A13-OLinuxIno-Micro, the vga output gives an unstable image when active low v or hsync is used. The problem seems to be specific to the OLinuxIno A13 (normal & micro) boards. I've just looked up the schematics and they use an opendrain driver for the vga sync lines, and with sync pulses it is the logical high->low edge of the pulse which counts for the timing, which with an active low sync is being driven by the pull-up, and that simply seems to not drive it hard enough to get a stable image. So force v and hsync active high on these boards. independent of what the modeline says. This fixes the unstable image. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-29dm: tegra: video: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: video: Add support for CONFIG_CONSOLE_SCROLL_LINESSimon Glass
Some machines are very slow to scroll their displays. To cope with this, support the CONFIG_CONSOLE_SCROLL_LINES option. Setting this to 5 allows the display to operate at an acceptable speed by scrolling 5 lines at a time. This same option is available for LCDs so when these systems are unified this code can be unified also. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-23x86: Drop the x86_fb driverSimon Glass
Now that we have a full VESA driver we may as well use that. We need to support the VESA layer being set up by early start-up code or by running a VGA ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Add a VESA video driverSimon Glass
Add a driver intended to cope with any VESA-compatible x86 graphics adapter. It will not support ROMs which use OpenFirmware (Forth) since there is no support for that in U-Boot. This means that MAC OS cards will not work. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-23sunxi: video: Make pwm polarity configurableHans de Goede
It turns out that there are some panels where the pwm input is not active low, so make it configurable. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: video: Add support for Hitachi tx18d42vm LVDS LCD panelsHans de Goede
Add support for Hitachi tx18d42vm LVDS LCD panels, these panels have a lcd controller which needs to be initialized over SPI, once that is done they work like a regular LVDS panel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
