path: root/drivers/video
2013-01-14video: exynos_fb: Make a call to draw_logo only when CONFIG_CMD_BMP is selectedAjay Kumar
Previously, the call to draw_logo() was happening irrespective of whether we have selected logo or LCD console. With this patch we call draw_logo() only when CONFIG_CMD_BMP is selected. This would even fix the following compilation warning: exynos_fb.c: In function 'draw_logo': exynos_fb.c:74:8: warning: variable 'addr' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:9: warning: variable 'y' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:6: warning: variable 'x' set but not used [-Wunused-but-set-variable] Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-14video: exynos_dp: Remove unused variable disp_infoAjay Kumar
Remove unused variable disp_info to fix the following compilation warning: exynos_dp.c: In function 'exynos_init_dp': exynos_dp.c:860:23: warning: variable 'disp_info' set but not used [-Wunused-but-set-variable] Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-10video: Modify exynos_fimd driver to support LCD consoleAjay Kumar
Currently, exynos FIMD driver is being used to support only TIZEN LOGOs. In order to get LCD console, we need to enable half word swap feature of FIMD and use 16 BPP. LCD console and proprietary Logo cannot be used simultaneously. We use "logo_on" field inside vidinfo_t structure to decide whether user wants Logo or Console. Define CONFIG_CMD_BMP and make logo_on = 1 to get Logo on screen. Use logo_on = 0 to get output console on LCD. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-09video:cache:fix: Enable dcache flush at LCD subsystem for Exynos based boardsŁukasz Majewski
lcd_set_flush_dcache(1) function is called from exynos_fb.c configuration file to enable lcd_sync function. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-06video: Check for valid FB pointer before clearingDuncan Laurie
This command will start erasing at memory address zero if there is not a valid framebuffer address that was found during video_init(). This is a common case with Chrome OS devices in normal mode when we do not execute the video option rom in coreboot. Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: video: Add coreboot framebuffer supportStefan Reinauer
Add a basic driver for the coreboot framebuffer. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-19tegra: Support control of cache settings for LCDSimon Glass
Add support for selecting the required cache mode for the LCD: off, write-through or write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD driverSimon Glass
This driver supports driving a single LCD and providing a U-Boot console on it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-15drivers: video: fix image positionPiotr Wilczek
This patch fixes image position on screen when images's height or width is biger then the lcd's. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15drivers: video: Add ld9040 video driverPiotr Wilczek
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-14Video: fix compiler warnings in bus_vcxkJens Scharsig (BuS Elektronik)
if a board uses the vcxk driver option CONFIG_SYS_VCXK_DOUBLEBUFFERD, compilier shows warnings. This patch will fix it. Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-11-10video: atmel: implement lcd_setcolreg functionBo Shen
implement the common api lcd_setcolreg in include/lcd.h Signed-off-by: Bo Shen <voice.shen@atmel.com> [agust: fixed commit log and gcc 4.6 -Wparentheses warnings] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-10mx6: use CONFIG_MX6 instead of CONFIG_MX6QTroy Kisky
Use CONFIG_MX6 when the particular processor variant isn't important. Reserve the use of CONFIG_MX6Q to specifically test for quad cores variant. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-11-07video: Skip bitmaps which do not fit into the screen in cfb_consoleVadim Bendebury
The cfb console driver is trying to prevent bitmaps to spill over the screen, but the calculations assume that at least part of the bitmap fits into the screen area. In reality there could be bitmap elements which are completely out of the screen area, they just need to be discarded. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-07video: Implement additional video API functions in cfb_consoleStefan Reinauer
Implement the new video API functions to provide access to screen size, etc. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-06ipu common: reset ipuv3 correctlyLiu Ying
This patch checks self-clear sw_ipu_rst bit in SCR register of SRC controller to be cleared after setting it to high to reset IPUv3. This makes sure that IPUv3 finishes sofware reset. A timeout mechanism is added to stop polling on the bit status in case the bit could not be cleared by the hardware automatically within 10 millisecond. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-10-30cfb_console: Add support for some ANSI terminal escape codesPali Rohár
Add optional support for some ANSI escape sequences to the cfb_console driver. Define CONFIG_CFB_CONSOLE_ANSI to enable cursor moving, color reverting and clearing the cfb console via ANSI escape codes. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-16i.MX video: struct fb_videomode can be constEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-15mx5: Use explicit clock gate namesBenoît Thébaudeau
Use clock gate definitions having names showing clearly the gated clock instead of names giving only a register field index. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15i.MX6: provide functional names for CCM_CCGR0-CCGR6 bit fieldsEric Nelson
Add meaningful constants for each clock channels and use them for enabling and disabling i.MX6 clocks. Includes an update to enable/disable the IPU1 clock in drivers/video/ipu_common to remove IMX5x register access when used on i.MX6 as discussed in V1: http://patchwork.ozlabs.org/patch/185129/ Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-01video: cfb_console: add function to plot the logo area blackBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rini <trini@ti.com> CC: Stefano Babic <sbabic@denx.de>
2012-10-01video: cfb_console: logo can be positioned via the splashpos variableBastian Ruppert
Extend the driver for placing the video/bmp logo as specified by "splashpos" environment variable. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> CC: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-29Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-25Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2012-09-24i.MX: mxc_ipuv3_fb: add ipuv3_fb_shutdown() routine to stop IPU frame bufferEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-21video/powerpc: don't touch DIU registers that we don't needTimur Tabi
Several DIU registers were being initialized either unnecessarily or to wrong values. 1) All interrupts were enabled even though there's no interrupt handler. Interrupts were left enabled when booting Linux. 2) Don't configure a dummy area descriptor, since we don't support ADs in U-Boot. 3) Don't configure any write-back buffer registers, since we don't use that mode. 4) The default values for the THRESHOLDS, SYN_POL, and PLUT registers should be used, so don't touch those registers either. Signed-off-by: Timur Tabi <timur@freescale.com>
2012-09-04video: drop duplicate set of DISPC_CONFIG registerStefano Babic
2012-09-01video: support exynos pwm backlight driverDonghwa Lee
This patch support exynos pwm backlight driver. It can control backlight power and brightness by using pwm. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: exynos fb driver supports display port featureDonghwa Lee
If dp_enabled was set, exynos fb driver support display port feature. This patch depends on [PATCH] video: support exynos fimd driver for various exynos series. http://marc.info/?l=u-boot&m=134119605104467&w=2 Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: support exynos display port driversDonghwa Lee
This patch set supports exynos display port drivers. DisplayPort is an industry standard device to accommodate the increasing board adoption of digital display technology within the PC and consumer electronics. The interface supports internal chip-to-chip and external box-to-box digital display connections. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: support exynos fimd driver for various exynos seriesDonghwa Lee
This patch supports exynos fimd driver for various exynos series different from existing it supports only exynos4 chip. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-07-10ipu_common: Add ldb_clk for use in parenting the pixel clockEric Nelson
Add ldb_clk for use in parenting the pixel clock. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Do not hardcode the ipu_clk frequencyFabio Estevam
Do not hardcode the ipu_clk frequency and let the board file pass this value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Rename MXC_CCM_BASEFabio Estevam
Rename MXC_CCM_BASE to CCM_BASE_ADDR as this is already defined for MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Let clk_ipu_enable/disable only run on MX51 and MX53Fabio Estevam
The registers accessed inside clk_ipu_enable/disable are not present on MX6, so make sure they only run on MX51 and MX53. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Only apply the erratum to MX51Fabio Estevam
The following erratum : "ENGcm08316 IPU: Clarification regarding the bypass mode registers setup for display and camera interfaces" only applies to mx51, so restrict its usage for this SoC only. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10video: Rename CONFIG_VIDEO_MX5Fabio Estevam
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10mx6: Allow mx6 to access the IPUv3 registersFabio Estevam
Adjust the IPUv3 registers, so that the IPUv3 driver can be extended for mx6 as well. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-08Remove remaining mdelay() macrosAnatolij Gustschin
Drop mdelay() macros since we already have a common mdelay() func. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07TRATS: initialize panel_info data structure in board fileDonghwa Lee
panel_info data structure is gloable variable, so, I have initialized it in board file. If it is initialized in init_panel_info() like existing, it can't be used in drv_lcd_init() in common/lcd.c because init_panel_info() is called after drv_lcd_init(). Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-06-05video: atmel/lcd: add LCD driver for new Atmel SoCBo Shen
The new Atmel SoC (at91sam9x5 series and at91sam9n12) add a totally different LCD controller. Add this new driver to support it. Using CONFIG_ATMEL_HLCD (distinguish with CONFIG_ATMEL_LCD) to enable this in board configuration file. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-05video: cfb_console: flush dcache for frame buffer in DRAMAnatolij Gustschin
Data cache flushing is required for frame buffer in RAM to fix the distorted console text output. Currently this text distortion is observed with cfb on beagleboard and N900 when running with data cache enabled. Reported-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-05cfb_console: Ignore bell characterPali Rohár
2012-06-04cfb_console: Add console_clear_line functionPali Rohár
console_clear_line() clears part of specified line or the full line. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-04cfb_console: Fix function console_backPali Rohár
* Do not disable and enable the cursor again. console_back() is called only from video_putc() which already turns the cursor off at the beginning and turns it on at the end, so there is no need to change the cursor in console_back(). Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-25omap3_dss: cosmetic changesJeroen Hofstee
Remove unnecessary brackets. Unwrap lines which are below 80 chars. Single line comment as single line (as the rest). Moved init values to the source code. cc: s-paulraj@ti.com cc: khasim@ti.com Signed-off-by: Jeroen Hofstee <jhofstee@victronenergy.com>
2012-05-25omap3_dss: add optional framebufferJeroen Hofstee
The beagle board uses the background color to show an orange screen during startup. This patch adds the ability to add a frame buffer, with the intention not to break the beagle board use case (I don't have one). videomodes.c is not used. Scrolling depends on this patch: http://patchwork.ozlabs.org/patch/155662/ cc: trini@ti.com cc: s-paulraj@ti.com cc: khasim@ti.com Signed-off-by: Jeroen Hofstee <jhofstee@victronenergy.com>
