Add support for display and bits-per-pixel properties.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Extend the driver to build with DM_VIDEO enabled. DTS files
must additionally include 'u-boot,dm-pre-reloc' property in
soc and child nodes to enable driver binding to fsl_dcu_fb device.
Currently display timings aren't obtained from DT.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
Adding the HDP firmware loading to the build.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit d4702582552aa1921fce58329ae40c24481fba3a)
This adds a command to load the HDP firmware and supporting libraries.
(cherry picked from downstream commit 94c9c7022c5b6cffb74bb2e34336cffc2790d0d8)
(cherry picked from downstream commit 21edff320e763585ebc6ab2d997c994561b69292)
set_pwm() will always fail with -ENOSYS if pwm_ops set_invert() is
not implemented, leaving the backlight dark. Fix this by returning
no error if set_invert() is not implemented and no polarity change
is requested.
Fixes: 57e7775413 ("video: backlight: Parse PWM polarity cell")
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Some boards don't have such a regulator, and don't need one to enable
HDMI display. Make it optional, fixing hdmi display for those boards.
Also surround the regulator code with a config check on DM_REGULATOR.
Reported-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Tested-by: Mohammad Rasim <mohammad.rasim96@gmail.com>
soc and child nodes to enable driver binding to mxsfb device.
Refactor video_hw_init() function, and introduce an independent function
for the common procedure of initialization.
Currently video_hw_init() is only in charge of parsing configuration from
env("videomode") and filling struct GraphicPanel, and new
mxs_probe_common() does hw specific initialization (invocation of
mxs_lcd_init() etc.)
Follow alphabetical order of includes, which simplifies detecting duplicate
includes etc.
Provide directly framebuffer address instead of pointer to
GraphicDevice struct, which will let to re-use this function in
DM_VIDEO configurations.
- update for using splashfile instead of location->name
when loading the splash image from a FIT
- updates for loading internal and external splash data from FIT
- DM_GPIO/DM_VIDEO migration for mx53 cx9020 board
- fix boot issue on mx6sabresd board after DM_VIDEO migration
- increase the max preallocated framebuffer BPP to 32 in ipuv3
driver to prepare for configurations with higher color depth
- allow to use vidconsole_put_string() in board code for text
output on LCD displays
Pull the vidconsole_put_string() function from DM tests, make it
available to e.g. boards that want to display information on the
LCD on boot.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
The IPUv3 can handle 1920x1080x32bpp displays , set the max preallocated
framebuffer BPP to 32 to cater for all eventualities.
This code also works with imx53 ipus so we can enable it for them.
Signed-off-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances
where these configuration items are conditional on SPL. This commit adds SPL
variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates
the configurations as required.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Make the default depend on the setting for full U-Boot, update
more zynq hardware]
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common
header file path, so that we can get the correct path directly.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Move to DM
- DM support in sata
- Toradex Board to DM
- wandboard to DM
- tbs2910 to DM
- GE boards to DM
- VHybrid boards to DM
- DM_VIDEO for i.MX
In the sunxi-common.h config header we unconditionally define
CONFIG_SYS_WHITE_ON_BLACK, although it's actually a Kconfig option which
could be individually selected by a user.
Remove this #define from the header and let it default to "y" on sunxi
boards (like we do for other platforms).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
In preparation for doing character set translations, factor out the
actual glyph display functionality into a separate function.
This will be used in a subsequent patch.
There is a standard ANSI terminal escape sequence to clear a whole line
of text. So far the DM_VIDEO console was missing this code.
Detect the sequence and use vidconsole_set_row with the background
colour to fix this omission.
The ANSI terminal escapce sequence standard defines relative cursor
movement commands (ESC [ A-F). So far the DM_VIDEO console code was
ignoring them.
Interpret those sequences and move the cursor by the requested amount of
rows or columns in the right direction. This brings the code on par with
the legacy video console driver (cfb_console).
The video console for DM_VIDEO compliant drivers only understands a very
small number of ANSI sequences. First and foremost it misses the "reverse
video" command, which is used by our own bootmenu command to highlight
the selected entry.
To avoid forcing people to use their imagination when using the
bootmenu, let's just implement the rather simple reverse effect. We need
to store the background colour index for that, so that we can
recalculate both the foreground and background colour pixel values.
[agust: merged BG color escape seq change to fix "ut dm video_ansi" test]
When the character to be printed on a DM_VIDEO console is from the
"extended ASCII" range (0x80 - 0xff), it will be treated as a negative
number, as it's declared as a signed char. This leads to negative array
indicies into the glyph bitmap array, and random garbled characters.
Cast the character to an unsigned type to make the index always positive
and avoid an out-of-bounds access.
This patch enables the reading of the polarity cell from a PWM
phandle and calls pwm_set_invert().
Not all platforms have polarity cell, so skip if it's not pressent.
Signed-off-by: Stefan Mavrodiev <stefan@olimex.com>
Spotted two missing spaces in comments.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Place ipuv3 files and headers in custom driver subdirectory.
soc and ipu nodes to enable driver binding to ipu device.
Currently, HDMI driver doesn't consider minimum and maximum allowed rate
of pll3 (video PLL). It works most of the time, but not always.
Consider monitor with resolution 1920x1200, which has pixel clock rate
of 154 MHz. Current code would determine that pll3 rate has to be set to
154 MHz. However, minimum supported rate is 192 MHz. In this case video
output just won't work.
The reason why the driver is written in the way it is, is that at the
time HDMI PHY and clock configuration wasn't fully understood. But now
we have needed knowledge, so the issue can be fixed.
With this fix, clock configuration routine uses full range (1-16) for
clock divider instead of limited one (1, 2, 4, 11). It also considers
minimum and maximum allowed rate for pll3.
Fixes: 56009451d843 ("sunxi: video: Add A64/H3/H5 HDMI driver")
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
This patch adds support to load 24bpp BMP files on 16bpp displays. This
will be used by the theadorable board. The "old" bmp command did support
this operartion mode and to not break compatibility with the move to
DM_VIDEO, we need to add this support to the "new" bmp code.
Acked-by: Anatolij Gustschin <agust@denx.de>
There are HDMI displays where hpd pin is not connected, thus
we cannot get it to work unless we specifically set the resolution.
Rework the display probing, so hotplug detect failure causes
fallback to probing ddc for EDID data.
Signed-off-by: Priit Laes <priit.laes@paf.com>
Move PLL initialization code to single place so
we won't call it every time we query for EDID data.
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this
move, the legacy interface board_video_init() is removed from the
theadorable board code (only user of this video driver). The support
via DT will be added in a separate patch.
This patch also enables DM_VIDEO for the theadorable board, as this is
needed to not break git bisect'ability.
- ihs and imx driver fixes
- relax EDID validation checks for 0 hsync/vsync
pulse width (support some quirky displays)
This adds video output support for Amlogic GXBB/GXL/GXM chips.
The supported ports are CVBS and HDMI (based on DW_HDMI).
When using HDMI, only DMT modes are supported.
There is support for simple-framebuffer (CONFIG_VIDEO_DT_SIMPLEFB)
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Jorge Ramire-Ortiz <jramirez@baylibre.com>
[narmstrong: fixed defines alignment in meson_canvas.c]
Some IPs like the meson VPU can only feed a particular pixel format to
dw_hdmi. As of now, the driver is hardcoded to use RGB888 as input.
This commit enables different pixel format inputs, with the appropriate
CSC configuration.
Some IPs like the meson VPU have a specific way to write to dw_hdmi
registers. Make it configurable.
Signed-off-by: Jorge Ramirez-Ortiz <jramirez@baylibre.com>
[added commit description]
The ihs_video_out driver's error handling is incorrect in two places
(one is a missing negation, and in one place a error should be ignored).
Fix these two instances.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Current EDID detailed timing parser errors out when either
horizontal or vertical pulse sync width is 0, thus not
allowing a display with EDID listed below work properly.
EDID below works ok within Linux although it warns about
these two fields being 0. Therefore relax the checks a bit
so we can actually use this the screen out of the box.
Of-course, this display itself is somewhat quirky display with
following anti-features:
- HPD pin is not usable
- although resolution is 640x480, only top 240 pixels are visible
$ xxd -p display.edid
00ffffffffffff0005a1e00301000000150f0103800f05780a0f6ea05748
9a2610474f200000010101010101010101010101010101012a08804520e0
0b1020004000953600000018000000fd0034441a2403000a202020202020
0000001000310a20202020202020202020200000001000002a4030701300
782d1100001e006b
$ edid-decode display.edid
EDID version: 1.3
Manufacturer: AMA Model 3e0 Serial Number 1
Digital display
Maximum image size: 15 cm x 5 cm
Gamma: 2.20
RGB color display
First detailed timing is preferred timing
Display x,y Chromaticity:
Red: 0.6250, 0.3398
Green: 0.2841, 0.6044
Blue: 0.1494, 0.0644
White: 0.2802, 0.3105
Established timings supported:
640x480@60Hz 4:3 HorFreq: 31469 Hz Clock: 25.175 MHz
Standard timings supported:
Detailed mode: Clock 20.900 MHz, 149 mm x 54 mm
640 672 672 709 hborder 0
480 484 484 491 vborder 0
-hsync -vsync
VertFreq: 60 Hz, HorFreq: 29478 Hz
Monitor ranges (GTF): 52-68Hz V, 26-36kHz H, max dotclock 30MHz
Dummy block
Dummy block
Checksum: 0x6b (valid)
Signed-off-by: Priit Laes <plaes@plaes.org>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
At present it is possible to enable TrueType support but not include any
fonts. This results in a blank display. Select Nimbus as the default font
to avoid this.
Minor sandbox enhancements / fixes
tpm improvements to clear up v1/v2 support
buildman toolchain fixes
New serial options to set/get config
This has an extra argument. Remove it.
Drop BMP_ALIGN_CENTER define in lcd.c and video_bmp.c as it is
already defined by splash.h. Include splash.h in bmp code.
At present line_length is always calculated in video_post_probe(). But
some hardware may use a different line length, e.g. with a 1366-wide
display.
Allow the driver to set this value if needed.
There was an incorrect check when looping and finding the first
fast enough frequency in the freq_rang table. The code did
actually return the first that was either exactly correct or
too slow.
Signed-off-by: Richard Röjfors <richard@puffinpack.se>
There was a copy and paste error where the data
enable setting was written to the version register.
It is useful to be able to invert the colours in some cases so that the
text matches the background colour. Add a parameter to the function to
support this.
It is strange that function takes a private data structure from another
driver as an argument. It seems better to pass the device and have the
function internally work out how to find its required information.
The terminal escape sequence ESC [ <x> ; <y> H is used to set the cursor
position. According to the ECMA 48 standard the upper left corner in the
escape sequences is [1, 1]. The video uclass uses [0, 0] as upper left
corner.
