path: root/drivers/video
2012-10-01video: cfb_console: add function to plot the logo area blackBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rini <trini@ti.com> CC: Stefano Babic <sbabic@denx.de>
2012-10-01video: cfb_console: logo can be positioned via the splashpos variableBastian Ruppert
Extend the driver for placing the video/bmp logo as specified by "splashpos" environment variable. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> CC: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-29Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-25Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2012-09-24i.MX: mxc_ipuv3_fb: add ipuv3_fb_shutdown() routine to stop IPU frame bufferEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-21video/powerpc: don't touch DIU registers that we don't needTimur Tabi
Several DIU registers were being initialized either unnecessarily or to wrong values. 1) All interrupts were enabled even though there's no interrupt handler. Interrupts were left enabled when booting Linux. 2) Don't configure a dummy area descriptor, since we don't support ADs in U-Boot. 3) Don't configure any write-back buffer registers, since we don't use that mode. 4) The default values for the THRESHOLDS, SYN_POL, and PLUT registers should be used, so don't touch those registers either. Signed-off-by: Timur Tabi <timur@freescale.com>
2012-09-04video: drop duplicate set of DISPC_CONFIG registerStefano Babic
2012-09-01video: support exynos pwm backlight driverDonghwa Lee
This patch support exynos pwm backlight driver. It can control backlight power and brightness by using pwm. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: exynos fb driver supports display port featureDonghwa Lee
If dp_enabled was set, exynos fb driver support display port feature. This patch depends on [PATCH] video: support exynos fimd driver for various exynos series. http://marc.info/?l=u-boot&m=134119605104467&w=2 Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: support exynos display port driversDonghwa Lee
This patch set supports exynos display port drivers. DisplayPort is an industry standard device to accommodate the increasing board adoption of digital display technology within the PC and consumer electronics. The interface supports internal chip-to-chip and external box-to-box digital display connections. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01video: support exynos fimd driver for various exynos seriesDonghwa Lee
This patch supports exynos fimd driver for various exynos series different from existing it supports only exynos4 chip. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-07-10ipu_common: Add ldb_clk for use in parenting the pixel clockEric Nelson
Add ldb_clk for use in parenting the pixel clock. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Do not hardcode the ipu_clk frequencyFabio Estevam
Do not hardcode the ipu_clk frequency and let the board file pass this value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Rename MXC_CCM_BASEFabio Estevam
Rename MXC_CCM_BASE to CCM_BASE_ADDR as this is already defined for MX6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Let clk_ipu_enable/disable only run on MX51 and MX53Fabio Estevam
The registers accessed inside clk_ipu_enable/disable are not present on MX6, so make sure they only run on MX51 and MX53. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Only apply the erratum to MX51Fabio Estevam
The following erratum : "ENGcm08316 IPU: Clarification regarding the bypass mode registers setup for display and camera interfaces" only applies to mx51, so restrict its usage for this SoC only. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10video: Rename CONFIG_VIDEO_MX5Fabio Estevam
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10mx6: Allow mx6 to access the IPUv3 registersFabio Estevam
Adjust the IPUv3 registers, so that the IPUv3 driver can be extended for mx6 as well. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-08Remove remaining mdelay() macrosAnatolij Gustschin
Drop mdelay() macros since we already have a common mdelay() func. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07TRATS: initialize panel_info data structure in board fileDonghwa Lee
panel_info data structure is gloable variable, so, I have initialized it in board file. If it is initialized in init_panel_info() like existing, it can't be used in drv_lcd_init() in common/lcd.c because init_panel_info() is called after drv_lcd_init(). Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-06-05video: atmel/lcd: add LCD driver for new Atmel SoCBo Shen
The new Atmel SoC (at91sam9x5 series and at91sam9n12) add a totally different LCD controller. Add this new driver to support it. Using CONFIG_ATMEL_HLCD (distinguish with CONFIG_ATMEL_LCD) to enable this in board configuration file. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-05video: cfb_console: flush dcache for frame buffer in DRAMAnatolij Gustschin
Data cache flushing is required for frame buffer in RAM to fix the distorted console text output. Currently this text distortion is observed with cfb on beagleboard and N900 when running with data cache enabled. Reported-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-05cfb_console: Ignore bell characterPali Rohár
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
2012-06-04cfb_console: Add console_clear_line functionPali Rohár
console_clear_line() clears part of specified line or the full line. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-04cfb_console: Fix function console_backPali Rohár
* Do not disable and enable the cursor again. console_back() is called only from video_putc() which already turns the cursor off at the beginning and turns it on at the end, so there is no need to change the cursor in console_back(). Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-25omap3_dss: cosmetic changesJeroen Hofstee
Remove unnecessary brackets. Unwrap lines which are below 80 chars. Single line comment as single line (as the rest). Moved init values to the source code. cc: s-paulraj@ti.com cc: khasim@ti.com Signed-off-by: Jeroen Hofstee <jhofstee@victronenergy.com>
2012-05-25omap3_dss: add optional framebufferJeroen Hofstee
The beagle board uses the background color to show an orange screen during startup. This patch adds the ability to add a frame buffer, with the intention not to break the beagle board use case (I don't have one). videomodes.c is not used. Scrolling depends on this patch: http://patchwork.ozlabs.org/patch/155662/ cc: trini@ti.com cc: s-paulraj@ti.com cc: khasim@ti.com Signed-off-by: Jeroen Hofstee <jhofstee@victronenergy.com>
2012-05-25mx5: Rename mx51_fb_init()Fabio Estevam
The ipuv3 driver is currently only used on mx51, but it can be extended to work on mx53 and mx6 as well. Rename mx51_fb_init(), so that it can be used by other SoCs. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2012-05-25mx53: Allow IPUv3 driver to also work on mx53Fabio Estevam
Adjust the IPU base registers so that ipuv3 driver can work on both mx51 and mx53 SoCs. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-25EXYNOS: display 32bpp bitmap TIZEN logoDonghwa Lee
This patch supports drawing 32bpp bitmap TIZEN logo in exynos fb. "tizen_hd_logo.h" data is compressed from trats_logo.bmp to trats_logo.bmp.gz by gzip and converted to tizen_hd_logo.h header file format by some application. The logo data is decompressed in the exynos fb driver by bmp_display(). Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-25LCD: support another s6e8ax0 panel typeDonghwa Lee
s6e8ax0 panel has many panel of types. This patch support another panel on TIZEN lunchbox board(HWREVISION 2). This panel has reversed panel display type. So, I had added necessary command. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-25LCD: change s6e8ax0 panel gamma valueDonghwa Lee
s6e8ax0 panel init gamma value is changed because existing it was not proper value for this panel. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2012-05-15EXYNOS: Change bits per pixel value proper for u-boot.Donghwa Lee
vl_bpix of vidinfo_t was changed proper value for u-boot. It is used to multiple of 2 by using NBITS() macro. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15LCD: support S6E8AX0 amoled driver based on EXYNOS MIPI DSIDonghwa Lee
This patch support S6E8AX0 amoled driver based on EXYNOS MIPI DSI interface. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-05-15EXYNOS: support EXYNOS MIPI DSI interface driver.Donghwa Lee
EXYNOS SoC platform has MIPI-DSI controller and MIPI-DSI based LCD Panel could be used with it. This patch supports MIPI-DSI driver based Samsung SoC chip. LCD panel driver based MIPI-DSI should be registered to MIPI-DSI driver at board file and LCD panel driver specific function registered to mipi_dsim_ddi structure at lcd panel init function called system init. In the MIPI-DSI driver, find lcd panel driver by using registered lcd panel name, and then initialize lcd panel driver. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-05-15EXYNOS: support EXYNOS framebuffer and FIMD display drivers.Donghwa Lee
This patch support EXYNOS FB and FIMD display drivers. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-12-07video: cfb_console: fix build warningsAnatolij Gustschin
Fix: cfb_console.c:371: warning: 'cursor_state' defined but not used cfb_console.c:372: warning: 'old_col' defined but not used cfb_console.c:373: warning: 'old_row' defined but not used cfb_console.c:435: warning: 'video_invertchar' defined but not used Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Wolfgang Denk <wd@denx.de>
2011-12-05video: cfb_console: Make the software cursor non-destructiveGabe Black
When printing the string "\r\n" to the framebuffer console, the first character of the current line was being replaced with a space. The "boot" prompt would become the "oot" prompt. This change makes the cursor non-destructive so that no matter where it goes on its way to where it's supposed to be, the end result is that the cursor is where it's supposed to be with the other text preserved. Signed-off-by: Gabe Black <gabeblack@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-29DIU: 1080P and 720P supportJerry Huang
Add the 1920x1080 and 1280x720 resolution support. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> CC: Anatolij Gustschin <agust@denx.de>
2011-11-29CFB: Fix font rendering on mx5 framebufferMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-11-16drivers/video/bus_vcxk.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: bus_vcxk.c: In function 'vcxk_display_bitmap': bus_vcxk.c:396:16: warning: variable 'compression' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-16drivers/video/da8xx-fb.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: da8xx-fb.c: In function 'video_hw_init': da8xx-fb.c:688:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-16drivers/video/ct69000.c: Fix GC 4.6 build warningWolfgang Denk
Convert custom debug code to use standard debug() facility. This also fixes these build warning: ct69000.c: In function 'FindAndSetPllParamIntoXrRegs': ct69000.c:706:28: warning: variable 'new_pixclock' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-11-15font: split font data from video_font.hChe-Liang Chiou
While video_font.h is useful even without referencing the font data, it is not possible to be included multiple times because it defines font data array right in the header. This patch splits the font data array into video_font_data.h and so now video_font.h can be included multiple times. This at least solves the code duplication in board/mcc200/lcd.c. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-15tools: logo: split bmp arrays from bmp_logo.hChe-Liang Chiou
The generated header bmp_logo.h is useful even outside common/lcd.c for the logo dimension. However, the problem is, the generated bmp_logo.h cannot be included multiple times because bmp_logo_palette[] and bmp_logo_bitmap[] are defined in the bmp_logo.h. This patch fixes this by defining these arrays in another header bmp_logo_data.h and in bmp_logo.h only declaring these arrays. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-10VIDEO: mx3fb: GCC4.6 fix build warningsStefano Babic
Fix: mx3fb.c: In function 'video_hw_init': mx3fb.c:827:30: warning: variable 'vesa_idx' set but not used Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Anatolij Gustschin <agust@denx.de>
2011-11-10Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bugJerry Huang
When the resolution is set to 800x600 and 1024x768, but, the driver will use 1280x1024 resolution to set the DIU register Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2011-11-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board arm: jadecpu: Readd MACH_TYPE_JADECPU at91: defined mach-types for otc570 board in board config file at91: defined mach-types for meesc board in board config file mx31pdk: Enable D and I caches ehci-mxc: remove incorrect comment README: Fix supported i.MX SoC list for CONFIG_MXC_SPI mx53: Turn off child clocks before reconfigure perclk_root qong: enable support for compressed images imx: imx31_phycore.h: fix checkpatch warnings vision2: Remove unused get_board_rev function mx53smd: Remove unused get_board_rev function mx53ard: Remove unused get_board_rev function mx53evk: Remove unused get_board_rev function mx53evk: Add RTC support mx53loco: Remove unused get_board_rev function mx53evk: Remove unneeded '1' from mx53evk.h OMAP3: mvblx: Initial support for mvBlueLYNX-X ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE omap3: mem: Move comments next to definitions omap3: mem: Clean-up whitespaces omap3: mem: Define and use common macros Davinci: ea20: added PREBOOT to configuration Davinci: ea20: added I2C support Davinci: ea20: added video support VIDEO: davinci: add framebuffer to da8xx ARM: Davinci: added missing registers to hardware.h Davinci: ea20: add gpios for LCD backlight control Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: Add default U-Boot environment Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add NAND support Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: set console on UART0 arm, davinci: add cam_enc_4xx support arm926ejs, davinci: add missing spi defines for dm365 arm926ejs, davinci: add cpuinfo for dm365 arm, davinci: add lowlevel function for dm365 soc arm, davinci: add header files for dm365 spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add support for new spl framework spl: add option for adding post memory test to the SPL framework net, davinci_emac: make clock divider in MDIO control register configurable arm, usb, davinci: make USBPHY_CTL register configurable usb, davinci: add enable_vbus() weak function omap3evm: fix errors caused by multiple definitions omap3evm: Add (quick) configuration for NAND only omap3evm: Add (quick) configuration for MMC/SD only omap3evm: move common config options to new file omap3evm: Prepare to split configuration omap3evm: Reorder related config options omap/spl: actually enable the console davinci_emac: compilation fix, phy is array now omap3evm: Set environment variable 'ethaddr' arm, arm926: fix missing symbols in NAND_SPL mode arm, davinci: Add function lpsc_syncreset() arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm/km: portl2 environment address update to P1B arm/km: adapt bootcounter evaluation arm/km: enable jffs2 cmds arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: add boardid and hwkey to kernel command line ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards netspace_v2: enable I2C EEPROM support netspace_v2: fix SDRAM configuration armada100: define CONFIG_SYS_CACHELINE_SIZE pantheon: define CONFIG_SYS_CACHELINE_SIZE kirkwood: define CONFIG_SYS_CACHELINE_SIZE kirkwood: drop empty asm-offsets.s file arm/km/mgcoge3un: enhance "waitforne" feature arm/km: add variable waitforne to mgcoge3un gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared ARM: dreamplug: fix compilation ARM: DockStar: fix compilation ARM: netspace_v2: fix warnings am335x: Drop board_sysinfo struct am335x: Temporarily add MACH_TYPE define misc:pmic:samsung Enable PMIC driver at C210 Universal target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target smdkv310: use macro for mmc data read function address smdkv310: use spl framework for mmc spl SMDKV310: use get_ram_size() to validate dram size SMDKV310: Initialize board id using CONFIG_MACH_TYPE ORIGEN : use absolute paths and fix tool naming ORIGEN : enable device tree support MX25: tx25: Fix building due to missing MACH_TYPE mx31: Add board support for HALE TT-01 mx31: add ESD control registers mx31: define pins and init for UART2 and CSPI3 MX35: add support for flea3 board MX51: vision2: add MACH_TYPE in config file vision2: Remove unused header file mx51evk: Remove unused get_board_rev function mx51evk: Remove unneeded '1' from mx51evk.h I2C: Fix mxc_i2c.c problem on imx31_phycore mx35pdk: Add RTC support mx51evk: Use GPIO API for configuring the IOMUX mx51evk: Add RTC support rtc: Make mc13783-rtc driver generic qong: remove unneeded IOMUX settings qong: Use mx31_set_gpr to setup USBH2 pins mx31: Introduce mx31_set_gpr function mx31pdk: Add MC13783 PMIC support qong: remove unneeded "1" from qong.h misc: pmic: fix regression in pmic_fsl.c (SPI) mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME MX35: Drop unnecessary prototypes from imx-regs.h I2C: added I2C-2 and I2C-3 to MX35 MX35: factorize common assembly code MX35: add reset cause as provided by other i.MX MX35: add pins definition for UART3 MX35: added ESDC structure to imx-regs
2011-11-07drivers/video/cfb_console.c:Fix GCC 4.6 build warningWolfgang Denk
Silence this warning: cfb_console.c: In function 'video_logo': cfb_console.c:1563:18: warning: variable 'y_off' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
