path: root/drivers/video
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-03-29video: bcm2835: fix build issuesAnatolij Gustschin
After merging LCD patches for v2013.04 the bcm2835 video driver building is broken due to removal of many global variables. Fix the driver. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-03-29Merge branch 'for-v2013.04'Anatolij Gustschin
Conflicts: drivers/video/Makefile Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-27video: exynos_dp: Add function to parse DP DT nodeAjay Kumar
Add function to parse the required platform data fron DP DT node and fill the edp_info structure. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_dp: Make dp_regs globalAjay Kumar
dp_regs variable was redundantly defined across all the functions in the driver even though it contains just the same address. We make it global and initialize it once using exynos_dp_set_base_addr(). >From then on, other funtions can use the address stored in the global variable. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_fb: add DT support for FIMD driverAjay Kumar
Add function to parse FIMD data from device tree. The driver still supports non-DT case. Define panel_info statically in some file if you are not using DT. If you have defined DT node for FIMD, panel_info will be filled using the bindings of FIMD DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_fb: Make fimd_ctrl globalAjay Kumar
fimd_ctrl variable was redundantly defined across all the functions in the driver even though it contains just the same address. We make it global and initialize it in exynos_fimd_lcd_init. From then on, other funtions can use the data in the global variable. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_dp: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_fb: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. This patch is tested only on SMDK5250. For Trats and universal_c210 board, it is only compile tested. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-21video: Fix splash screen alignmentMatthias Weisser
commit d484b52 "video: Skip bitmaps which do not fit into the screen in cfb_console" breaks splash screen alignment which is passed in as magic (BMP_ALIGN_CENTER) x/y coordinates. Moving the check after the alignment block fixes this. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-03-21lcd, fb: remove duplicated prototypes and unused codeJeroen Hofstee
cc: Anatolij Gustschin <agust@denx.de> cc: Cliff Brake <cliff.brake@gmail.com> cc: John Zhan <zhanz@sinovee.com> cc: Marek Vasut <marek.vasut@gmail.com> cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21common/lcd.c: remove global lcd_baseJeroen Hofstee
lcd_base is available as gd->fb_base as well, there is no need to keep a seperate copy. For completeness the ack of Bo Shen is for the atmel part. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fix cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21common/lcd.c: cleanup use of global variablesJeroen Hofstee
console_col, console_row, lcd_line_length, lcd_console_address had to be declared in board / driver specific code, but were not actually used there on many boards. Get rid of the global variables. for completeness, the ack of Bo Shen is for the atmel part Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: rebased and fixed cm_t35 board] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21lcd, pxafb: move the pxafb to drivers/videoJeroen Hofstee
Since the lcd code was compiled unconditionally for pxa also add CONFIG_PXA_LCD to the boards using this framebuffer. Since driver/video contains video and lcd drivers, add lcd to the name to make clear it belongs to common/lcd.c. cc: Anatolij Gustschin <agust@denx.de> cc: Cliff Brake <cliff.brake@gmail.com> cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21lcd, mpc8xx: move the mpc8xx driver to drivers/videoJeroen Hofstee
Since the lcd code was compiled unconditionally in arch also add CONFIG_MPC8XX_LCD to the boards using this driver. cc: Anatolij Gustschin <agust@denx.de> cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21lcd, tegra: remove unused cursor functionsJeroen Hofstee
cc: Anatolij Gustschin <agust@denx.de> cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21lcd, amba: remove this driver since it is not usedJeroen Hofstee
Since CONFIG_VIDEO_AMBA is not set by any board, it does not seem to be used, so remove it since there is no way to (compile) test it. cc: Alessandro Rubini <rubini@unipv.it> cc: Anatolij Gustschin <agust@denx.de> Acked-by: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21common/lcd.c: cleanup use of global variablesWolfgang Denk
lcd_color_fg and lcd_color_bg had to be declared in board specific code, but were not actually used there; in addition, we have getter / setter functions for these, which were not used either. Get rid of the global variables, and use the getter function where needed (so far no setter calls are needed). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fixed cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-20video: add a driver for the bcm2835Stephen Warren
The firmware running on the bcm2835 SoC's VideoCore CPU manages the display controller. Add a simple "LCD" driver that communicates with the firmware using the property mailbox protocol. This configures the display and frame-buffer to match whatever physical resolution the firmware chosen when booting, which is typically the native resolution of the attached display device, presumably unless otherwise specified in config.txt on the boot media. Enable this driver in the Raspberry Pi board configuration. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-03-08omap3: allow dynamic selection of gfx_formatNikita Kiryanov
Currently, omap3_dss_panel_config() sets gfx_format to a value that is hardcoded in the code. This forces anyone who wants to use a different gfx_format to make adjustments after calling omap3_dss_panel_config(). This could be avoided if the value of gfx_format were parameterized as input for omap3_dss_panel_config(). Make gfx_format a field in struct panel_config, and update existing structs to set this field to the value that was originally hard coded. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-01-16video: tegra: Update line length to match resolutionThierry Reding
Instead of storing the computed line length in a local variable, store it in the global lcd_line_length variable to make sure the LCD subsystem can properly draw content for the display resolution. This probably wasn't noticed yet because the only board where LCD support is currently enabled is Seaboard, which runs at a 1366x768 resolution. As it happens this is the maximum resolution supported and also the default that is used to initialize the framebuffer before the configuration from DT is available. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-14video: exynos_fb: Make a call to draw_logo only when CONFIG_CMD_BMP is selectedAjay Kumar
Previously, the call to draw_logo() was happening irrespective of whether we have selected logo or LCD console. With this patch we call draw_logo() only when CONFIG_CMD_BMP is selected. This would even fix the following compilation warning: exynos_fb.c: In function 'draw_logo': exynos_fb.c:74:8: warning: variable 'addr' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:9: warning: variable 'y' set but not used [-Wunused-but-set-variable] exynos_fb.c:73:6: warning: variable 'x' set but not used [-Wunused-but-set-variable] Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-14video: exynos_dp: Remove unused variable disp_infoAjay Kumar
Remove unused variable disp_info to fix the following compilation warning: exynos_dp.c: In function 'exynos_init_dp': exynos_dp.c:860:23: warning: variable 'disp_info' set but not used [-Wunused-but-set-variable] Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-10video: Modify exynos_fimd driver to support LCD consoleAjay Kumar
Currently, exynos FIMD driver is being used to support only TIZEN LOGOs. In order to get LCD console, we need to enable half word swap feature of FIMD and use 16 BPP. LCD console and proprietary Logo cannot be used simultaneously. We use "logo_on" field inside vidinfo_t structure to decide whether user wants Logo or Console. Define CONFIG_CMD_BMP and make logo_on = 1 to get Logo on screen. Use logo_on = 0 to get output console on LCD. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-09video:cache:fix: Enable dcache flush at LCD subsystem for Exynos based boardsŁukasz Majewski
lcd_set_flush_dcache(1) function is called from exynos_fb.c configuration file to enable lcd_sync function. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-06video: Check for valid FB pointer before clearingDuncan Laurie
This command will start erasing at memory address zero if there is not a valid framebuffer address that was found during video_init(). This is a common case with Chrome OS devices in normal mode when we do not execute the video option rom in coreboot. Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: video: Add coreboot framebuffer supportStefan Reinauer
Add a basic driver for the coreboot framebuffer. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-19tegra: Support control of cache settings for LCDSimon Glass
Add support for selecting the required cache mode for the LCD: off, write-through or write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD driverSimon Glass
This driver supports driving a single LCD and providing a U-Boot console on it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-15drivers: video: fix image positionPiotr Wilczek
This patch fixes image position on screen when images's height or width is biger then the lcd's. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15drivers: video: Add ld9040 video driverPiotr Wilczek
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-14Video: fix compiler warnings in bus_vcxkJens Scharsig (BuS Elektronik)
if a board uses the vcxk driver option CONFIG_SYS_VCXK_DOUBLEBUFFERD, compilier shows warnings. This patch will fix it. Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-11-10video: atmel: implement lcd_setcolreg functionBo Shen
implement the common api lcd_setcolreg in include/lcd.h Signed-off-by: Bo Shen <voice.shen@atmel.com> [agust: fixed commit log and gcc 4.6 -Wparentheses warnings] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-10mx6: use CONFIG_MX6 instead of CONFIG_MX6QTroy Kisky
Use CONFIG_MX6 when the particular processor variant isn't important. Reserve the use of CONFIG_MX6Q to specifically test for quad cores variant. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-11-07video: Skip bitmaps which do not fit into the screen in cfb_consoleVadim Bendebury
The cfb console driver is trying to prevent bitmaps to spill over the screen, but the calculations assume that at least part of the bitmap fits into the screen area. In reality there could be bitmap elements which are completely out of the screen area, they just need to be discarded. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-07video: Implement additional video API functions in cfb_consoleStefan Reinauer
Implement the new video API functions to provide access to screen size, etc. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-11-06ipu common: reset ipuv3 correctlyLiu Ying
This patch checks self-clear sw_ipu_rst bit in SCR register of SRC controller to be cleared after setting it to high to reset IPUv3. This makes sure that IPUv3 finishes sofware reset. A timeout mechanism is added to stop polling on the bit status in case the bit could not be cleared by the hardware automatically within 10 millisecond. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2012-11-03Merge remote-tracking branch 'u-boot-ti/master'Albert ARIBAUD
2012-10-30cfb_console: Add support for some ANSI terminal escape codesPali Rohár
Add optional support for some ANSI escape sequences to the cfb_console driver. Define CONFIG_CFB_CONSOLE_ANSI to enable cursor moving, color reverting and clearing the cfb console via ANSI escape codes. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-16i.MX video: struct fb_videomode can be constEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-15mx5: Use explicit clock gate namesBenoît Thébaudeau
Use clock gate definitions having names showing clearly the gated clock instead of names giving only a register field index. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15i.MX6: provide functional names for CCM_CCGR0-CCGR6 bit fieldsEric Nelson
Add meaningful constants for each clock channels and use them for enabling and disabling i.MX6 clocks. Includes an update to enable/disable the IPU1 clock in drivers/video/ipu_common to remove IMX5x register access when used on i.MX6 as discussed in V1: http://patchwork.ozlabs.org/patch/185129/ Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-10-01video: cfb_console: add function to plot the logo area blackBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rini <trini@ti.com> CC: Stefano Babic <sbabic@denx.de>
2012-10-01video: cfb_console: logo can be positioned via the splashpos variableBastian Ruppert
Extend the driver for placing the video/bmp logo as specified by "splashpos" environment variable. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> CC: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-29Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-25Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2012-09-24i.MX: mxc_ipuv3_fb: add ipuv3_fb_shutdown() routine to stop IPU frame bufferEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-21video/powerpc: don't touch DIU registers that we don't needTimur Tabi
Several DIU registers were being initialized either unnecessarily or to wrong values. 1) All interrupts were enabled even though there's no interrupt handler. Interrupts were left enabled when booting Linux. 2) Don't configure a dummy area descriptor, since we don't support ADs in U-Boot. 3) Don't configure any write-back buffer registers, since we don't use that mode. 4) The default values for the THRESHOLDS, SYN_POL, and PLUT registers should be used, so don't touch those registers either. Signed-off-by: Timur Tabi <timur@freescale.com>
