path: root/drivers/video/tegra.c
2015-01-29dm: tegra: video: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-21common/lcd.c: remove global lcd_baseJeroen Hofstee
lcd_base is available as gd->fb_base as well, there is no need to keep a seperate copy. For completeness the ack of Bo Shen is for the atmel part. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fix cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21common/lcd.c: cleanup use of global variablesJeroen Hofstee
console_col, console_row, lcd_line_length, lcd_console_address had to be declared in board / driver specific code, but were not actually used there on many boards. Get rid of the global variables. for completeness, the ack of Bo Shen is for the atmel part Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: rebased and fixed cm_t35 board] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21lcd, tegra: remove unused cursor functionsJeroen Hofstee
cc: Anatolij Gustschin <agust@denx.de> cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21common/lcd.c: cleanup use of global variablesWolfgang Denk
lcd_color_fg and lcd_color_bg had to be declared in board specific code, but were not actually used there; in addition, we have getter / setter functions for these, which were not used either. Get rid of the global variables, and use the getter function where needed (so far no setter calls are needed). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fixed cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-01-16video: tegra: Update line length to match resolutionThierry Reding
Instead of storing the computed line length in a local variable, store it in the global lcd_line_length variable to make sure the LCD subsystem can properly draw content for the display resolution. This probably wasn't noticed yet because the only board where LCD support is currently enabled is Seaboard, which runs at a 1366x768 resolution. As it happens this is the maximum resolution supported and also the default that is used to initialize the framebuffer before the configuration from DT is available. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Support control of cache settings for LCDSimon Glass
Add support for selecting the required cache mode for the LCD: off, write-through or write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD driverSimon Glass
This driver supports driving a single LCD and providing a U-Boot console on it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
