path: root/drivers/video/tegra.c
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-05tegra: video: Always use write-through cache on LCDSimon Glass
This seems to give the best performance, so let's use it always. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-07-05video: tegra: Move to using simple-panel and pwm-backlightSimon Glass
We have standard drivers for panels and backlights which can do most of the work for us. Move the tegra20 LCD driver over to use those instead of custom code. This patch includes device tree changes for the nvidia boards. I have only been able to test seaboard. If this patch is applied, these boards will also need to be synced with the kernel, and updated to use display-timings: - colibri - medcom-wide - paz00 - tec Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-17video: tegra: refuse to bind to disabled dcsStephen Warren
This prevents the following boot-time message on any board where only the first DC is in use, yet the DC's DT node is enabled: stdio_add_devices: Video device failed (ret=-22) (This happens on at least Harmony, Ventana, and likely any other Tegra20 board with display enabled other than Seaboard). The Tegra DC's DT node represents a display controller. It may itself drive an integrated RGB display output, or be used by some other display controller such as HDMI. For this reason the DC node itself is not enabled/disabled in DT; the DC itself is considered a shared resource, not the final (board-specific) display output. The node should instantiate a display output driver only if the rgb subnode is enabled. Other output drivers are free to use the DC if they are enabled and their DT node references the DC's DT node. Adapt the Tegra display drivers' bind() routine to only bind to the DC's DT node if the RGB subnode is enabled. Now that the display driver does the right thing, remove the workaround for this issue from Seaboard's DT file. Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-16tegra: video: Move LCD driver to use the DM PWM driverSimon Glass
Use the driver-model PWM driver in preference to the old code. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Move all fdt-decoding into a single functionSimon Glass
Join the two functions which decode the device tree and put them in the ofdata_to_platdata() method. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Move LCD enums into the driverSimon Glass
There is no need to have these in a separate file as they are not referenced from anywhere else. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Remove the static variablesSimon Glass
We can move the static variables into the driver-private data. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Convert tegra20 LCD driver to driver modelSimon Glass
Move this driver over to use driver model. This involves rearranging the code somewhat. The effect is that everything is run from the probe() method. Boards which use this are fixed up, but only seaboard is tested. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Merge the two config structures togetherSimon Glass
We have a structure for the display panel and another for the controller. There is some overlap between them. Merge them to simplify the driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Move the check for CONFIG_OF_CONTROL to KconfigSimon Glass
We can check this in Kconfig now. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Merge the display driver into one fileSimon Glass
At present we have code in arch/arm and code in drivers/video. Move it all into drivers/video since it is a display driver and our current approach is to put all driver code in drivers/. Make a few functions static now that they are not used outside the file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-06lib/fdtdec: Fix compiling warning caused by changing fdt_addr_t typeYork Sun
fdt_addr_t is changed to phys_addr_t. The format in debug should be updated to %pa to match the type. Signed-off-by: York Sun <yorksun@freescale.com> CC: Simon Glass <sjg@chromium.org>
2015-01-29dm: tegra: video: Remove use of fdtdec GPIO supportSimon Glass
These functions are going away, so use the new uclass support instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-21common/lcd.c: remove global lcd_baseJeroen Hofstee
lcd_base is available as gd->fb_base as well, there is no need to keep a seperate copy. For completeness the ack of Bo Shen is for the atmel part. Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fix cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21common/lcd.c: cleanup use of global variablesJeroen Hofstee
console_col, console_row, lcd_line_length, lcd_console_address had to be declared in board / driver specific code, but were not actually used there on many boards. Get rid of the global variables. for completeness, the ack of Bo Shen is for the atmel part Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: rebased and fixed cm_t35 board] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21lcd, tegra: remove unused cursor functionsJeroen Hofstee
cc: Anatolij Gustschin <agust@denx.de> cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21common/lcd.c: cleanup use of global variablesWolfgang Denk
lcd_color_fg and lcd_color_bg had to be declared in board specific code, but were not actually used there; in addition, we have getter / setter functions for these, which were not used either. Get rid of the global variables, and use the getter function where needed (so far no setter calls are needed). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fixed cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-01-16video: tegra: Update line length to match resolutionThierry Reding
Instead of storing the computed line length in a local variable, store it in the global lcd_line_length variable to make sure the LCD subsystem can properly draw content for the display resolution. This probably wasn't noticed yet because the only board where LCD support is currently enabled is Seaboard, which runs at a 1366x768 resolution. As it happens this is the maximum resolution supported and also the default that is used to initialize the framebuffer before the configuration from DT is available. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Support control of cache settings for LCDSimon Glass
Add support for selecting the required cache mode for the LCD: off, write-through or write-back. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add LCD driverSimon Glass
This driver supports driving a single LCD and providing a U-Boot console on it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
