path: root/drivers/video/sunxi_display.c
2014-11-25sunxi: video: Add simplefb supportLuc Verhaegen
Add simplefb support, note this depends on the kernel having support for the clocks property which has recently been added to the simplefb devicetree binding. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Use pre-populated simplefb node under /chosen as disussed on the devicetree list] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>.
2014-11-25sunxi: video: Add sun6i supportHans de Goede
Besided needing the usual sun6i specific ahb1_reset bits poking, it turns out that sun6i also needs the drc to be taken out of reset and clocked even though it is in pass-through mode. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-25sunxi: video: Add cfb console driver for sunxiLuc Verhaegen
This adds a fixed mode hdmi driver for the sunxi platform. The fixed mode is a relatively safe 1024x768, more complete EDID handling is currently not provided. Only HDMI is supported today. This code is enabled when HPD detects an attached monitor. Current config is such that 8MB is shaved off at the top of the RAM. This avoids several memory handling issues, most significant is the fact that on linux on ARM you are not allowed to remap known RAM as IO. A clued in display driver will be able to recycle this reserved RAM in future though. cfbconsole was chosen as it provides the most important functionality: a working u-boot console, allowing for the debugging of certain issues without the need for a UART. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Major cleanups and some small bugfixes] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
