- fdt_support: Add fdt_for_each_node_by_compatible() helper macro
(Marek)
- turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob (Pali)
- pci_mvebu: Add support for Kirkwood PCIe controllers (Pali)
- SPL: More verifications for kwbimage in SPL (Pali)
- mvebu: Remove comphy_update_map() (Pali)
- Minor misc stuff
Add macro fdt_for_each_node_by_compatible() to allow iterating over
fdt nodes by compatible string.
Convert various usages of
off = fdt_node_offset_by_compatible(fdt, start, compat);
while (off > 0) {
code();
off = fdt_node_offset_by_compatible(fdt, off, compat);
and similar, to
fdt_for_each_node_by_compatible(off, fdt, start, compat)
code();
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Two displays supported by the sunxi display driver (each one used by a
single board) require initialization over I2C. Both previously used
i2c_soft; replace this with the i2c-gpio instance that already exists in
those boards' device trees (sun5i-a13-utoo-p66 and sun6i-a31-colombus).
Since the i2c-gpio nodes are not referenced by any other node in the
device trees (the device trees have no panel node), the I2C bus is
selected by its node name.
This panel initialization code was the only i2c_soft user, so the
i2c_soft GPIO setup code can be removed now as well.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
This clarifies which callers must be updated to complete the DM_GPIO
conversion.
The only remaining caller of name_to_gpio in generic code is inside the
!DM_GPIO block in cmd/gpio.c. DM_GPIO is always selected on sunxi, so
that code cannot be reached. And after this commit, there are only two
remaining implementations of name_to_gpio.
Acked-by: Andre Przywara <andre.przywara@arm.com>
As part of migrating to DM_GPIO and DM_PINCTRL, eventually we will
remove the asm/arch/gpio.h header. In preparation, clean up the various
files that include it.
Some files did not contain any GPIO code at all, so this header was
completely unused.
A few files contained only legacy platform-specific GPIO code for
setting up pin muxes. They were left unchanged, as that code will be
completely removed by the DM_PINCTRL migration.
The remaining files contain some combination of DM_GPIO and legacy GPIO
code. For those, switch to including asm/gpio.h (if it wasn't included
already). Right now, this header provides both sets of functions,
because ARCH_SUNXI selects GPIO_EXTRA_HEADER. This will still be the
right header to include once the DM_GPIO migration is complete and
GPIO_EXTRA_HEADER is no longer needed.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Currently DE2 driver uses functions which are defined in internal
headers. They are not meant to be used outside of uclass framework.
Switch DE2 driver to public ones. This has additional benefit that
device_probe doesn't need to be called manually.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
There is no real need to read source_id at probe time. It also doesn't
make sense to store it in driver private data since it's already stored
in class platform data. While this looks like cleanup (and it is), it's
also important for DE2 driver rework because this info will be filled
later (after probe is already executed).
TV driver was never fully implemented. Remove search for it from DE2
driver.
No Allwinner board with DW-HDMI controller use separate I2C bus for
EDID read. Remove that check.
It turns out that there are two ways how hot plug detection can be done.
One is standard way for DW HDMI controller - checking bit 2 in 0x3004
register. Another way is applicable only to Allwinner custom PHY - by
checking bit 19 in register 0x10038. Both methods are equally good as
far as we know.
Use standard method in order to reduce amount of custom code.
Currently driver accepts all resolution which won't work on 4k screens.
Add validation callback which limits acceptable resolutions to 297 MHz.
Currently sunxi Makefile manually specifies full path to dw-hdmi common
code. However, that is not needed because it can be selected in Kconfig
instead.
Select proper symbol in Kconfig and drop path from Makefile.
DM_VIDEO migration deadline is already expired, but around
80 Allwinner boards are still using video in a legacy way:
===================== WARNING ======================
This board does not use CONFIG_DM_VIDEO Please update
the board to use CONFIG_DM_VIDEO before the v2019.07 release.
Failure to update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
Convert the legacy video driver over to the DM_VIDEO framework. This is
a minimal conversion: it doesn't use the DT for finding its resources,
nor does it use DM clocks or DM devices for the outputs (LCD, HDMI, CVBS).
Tested in Bananapi M1+ Plus 1920x1200 HDMI out. (Jagan)
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
[Andre: rebase and smaller fixes]
Acked-by: Maxime Ripard <mripard@kernel.org>
Reviewed-by: Jernej Skrabec <jernej.skrabec@siol.net>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The current macro is a misnomer since it does not declare a device
directly. Instead, it declares driver_info record which U-Boot uses at
runtime to create a device.
The distinction seems somewhat minor most of the time, but is becomes
quite confusing when we actually want to declare a device, with
of-platdata. We are left trying to distinguish between a device which
isn't actually device, and a device that is (perhaps an 'instance'?)
It seems better to rename this macro to describe what it actually is. The
macros is not widely used, since boards should use devicetree to declare
devices.
Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is
declaring a new driver_info record, not a device.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
Move this uncommon header out of the common header.
Move this header out of the common header.
Virtually all callers of this function do the rounding on their own.
Some do it right, some don't. Instead of doing this in each caller,
do the rounding in efi_add_memory_map(). Change the size parameter
to bytes instead of pages and remove aligning and size calculation in
all callers.
There is no more need to make the original efi_add_memory_map() (which
takes pages as size) available outside the module. Thus rename it to
efi_add_memory_map_pg() and make it static to prevent further misuse
outside the module.
Signed-off-by: Michael Walle <michael@walle.cc>
Add missing comma in sunxi_display.c.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Since video_ctfb_mode_to_display_timing() has been implemented by moving
sunxi_ctfb_mode_to_display_timing() to video_modes.c and it's meant to be
used by other video subsystem, let's use it instead of local
sunxi_ctfb_mode_to_display_timing().
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
Reviewed-by: Anatolij Gustschin <agust@denx.de>
case
When building with gcc 9.2.0, the following build warning was seen:
drivers/video/sunxi/sunxi_display.c: In function 'video_hw_init':
drivers/video/sunxi/sunxi_display.c:1217:2:
error: '%s' directive argument is null [-Werror=format-overflow=]
Change sunxi_get_mon_desc() to not return NULL for the default case,
to fix the compiler warning.
Move this function into init.h which seems to be designed for this sort
of thing. Also update the header to declare struct global_data so that it
can be included without global_data.h being needed.
These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This function belongs in time.h so move it over and add a comment.
Currently we may end up with an LCD clock divider that differs from
the HDMI PHY clock divider if we can't exactly match the pixel clock.
Fix this by using DIV_ROUND_UP to calculate the divider. This works
since the PLL is chosen such that the resulting pixel clock is
never higher than the requested pixel clock.
Fixes: 1feed358ed15 ("sunxi: video: HDMI: Fix clock setup")
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Add support for the ddc-i2c-bus device tree property which allows
for using an external i2c master for reading the display's EDID.
Signed-off-by: Niklas Schulze <me@jns.io>
Currently, HDMI driver doesn't consider minimum and maximum allowed rate
of pll3 (video PLL). It works most of the time, but not always.
Consider monitor with resolution 1920x1200, which has pixel clock rate
of 154 MHz. Current code would determine that pll3 rate has to be set to
154 MHz. However, minimum supported rate is 192 MHz. In this case video
output just won't work.
The reason why the driver is written in the way it is, is that at the
time HDMI PHY and clock configuration wasn't fully understood. But now
we have needed knowledge, so the issue can be fixed.
With this fix, clock configuration routine uses full range (1-16) for
clock divider instead of limited one (1, 2, 4, 11). It also considers
minimum and maximum allowed rate for pll3.
Fixes: 56009451d843 ("sunxi: video: Add A64/H3/H5 HDMI driver")
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
There are HDMI displays where hpd pin is not connected, thus
we cannot get it to work unless we specifically set the resolution.
Rework the display probing, so hotplug detect failure causes
fallback to probing ddc for EDID data.
Signed-off-by: Priit Laes <priit.laes@paf.com>
Move PLL initialization code to single place so
we won't call it every time we query for EDID data.
DE2 SoCs can support LCDs up to 1080p (e.g. A64), and 3MHz step won't
let PLL_VIDEO be high enough for them.
Use 6MHz step for PLL_VIDEO when using DE2, to satisfy 1080p LCD.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Jagan Teki <jagan@openedev.com>
sunxi_rgb2yuv_coef is readonly and never modified.
Signed-off-by: Priit Laes <plaes@plaes.org>
Acked-by: Anatolij Gustschin <agust@denx.de>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Sometimes when a monitor without EDID information is plugged, the DE2
won't be probed (because of lack of timing information), but the HDMI
node is probed, thus a SimpleFB node with invalid information will be
populated.
Also detect whether DE2 is probed when creating SimpleFB node.
Fixes: be5b96f0e411 ("sunxi: setup simplefb for Allwinner DE2")
If compile with support for the efi loader we need to mark the pages
allocated for the framebuffer as reserved so the kernel won't attempt
to use them for other uses.
Signed-off-by: Emmanuel Vadot <manu@freebsd.org>
Acked-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
HSYNC is bit 8, and VSYNC is bit 9.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Inform the EFI subsystem that the framebuffer memory is reserved.
Without the patch the AllocatePool boot service allocates memory from the
framebuffer which will will be overwritten by screen output.
flags member of struct timing was not initialized,
this took to unpredictable behaviour of display flags,
such DISPLAY_FLAGS_HSYNC_HIGH instead of _LOW etc.
Init timing->flags = 0
Signed-off-by: Giulio Benetti <giulio.benetti@micronovasrl.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
These are actually different bits, and since some monitors (Benq BL2420PT)
have modes with different HSYNC and VSYNC polarity, we should set them
independently
Tested on Pine64-LTS with Benq BL2420PT monitor.
Add support for setting up SimpleFB for LCD display output in DE2
SimpleFB setup code.
When HDMI is not initialized (e.g. no monitor is plugged), the current
SimpleFB code will still create a broken SimpleFB node.
Detect whether HDMI is initialized when creating SimpleFB node.
Extend DE2 driver with LCD support. Tested on Pinebook which is based
on A64 and has ANX6345 eDP bridge with eDP panel connected to it.
[agust: rebased v5 on u-boot-video/master]
It will be reused in new DM LCD driver.
As the support of EFI boot on Allwinner H3 is broken, we still need to
use simplefb to pass the framebuffer to Linux.
Add code to setup simplefb for Allwinner DE2 driver.
As the DE2 simplefb setup code can also benefit from the simplefb match
code, extract it to a new source file.
Extend DE2 driver with support for TVE driver, which will be added in
next commit. TVE unit expects data to be in YUV format, so CSC support
is also added here.
Note that HDMI driver has higher priority, so TV out is not probed if
HDMI monitor is detected.
