path: root/drivers/video/sm501.c
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-06-14video: sm501.c: add weak default functionsAnatolij Gustschin
For boards using sm501/sm502 on PCI bus some driver functions normaly defined in the board code are not needed and empty. Provide weak default functions for them and do not enforce board code to define empty functions. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-06-14video: sm501: add support for SM501 chips on PCI busAnatolij Gustschin
2010-06-14video: cfb_console: add weak default video_set_lut()Anatolij Gustschin
Do not enforce drivers to provide empty video_set_lut() if they do not implement indexed color (8 bpp) frame buffer support. Add default function to the cfb_console driver and remove empty video_set_lut() functions. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-08-18video: Clean drivers/video/MakefileMichal Simek
2007-11-25drivers/video : move video drivers to drivers/videoJean-Christophe PLAGNIOL-VILLARD
