path: root/drivers/video/mxsfb.c
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-04-05ARM: mxs: Rename M28EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-02-22video: mxsfb: Fix reset hang when videomode variable is not presentFabio Estevam
Currently the system hangs when the 'videomode' variable is not present and a reset command is issued: => setenv videomode => saveenv => reset (Board hangs) lcdif_power_down() assumes that the LCDIF controller has been properly configured and enabled, which may not be true. To fix this issue check whether panel.frameAdrs has been initialized and in case it has not been initialized, do not continue with the LCDIF powerdown sequence. Tested on a imx7dsabresd board. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-11-12video: mxsfb: introduce lcdif_power_downPeng Fan
Introudce a new function lcdif_power_down. 1. Waits for a VSYNC interrupt to guarantee the reset is done at the VSYNC edge, which somehow makes the LCDIF consume the display FIFO(?) and helps the LCDIF work normally at the kernel stage. 2. Add power down function to stop lcdif. The reason to introduce lcdif_power_down is that we want lcdif to be in initial state when doing uboot reset or before kernel boot to make system stable, otherwise system may hang. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-11-12mxs: add parameter base_addr for mxs_set_lcdclkPeng Fan
Change mxs_set_lcdclk prototype to add a new parameter base_addr. There are two LCD interfaces for i.MX6SX, we may support LCDIF1 or LCDIF2. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-08-09video: Implement continuous screen refresh for SmartLCD into mxsfbMarek Vasut
The LCDIF interface doesn't give us any means to do continuous refresh when driving a SmartLCD. To work this around, we produce a special circular DMA descriptor, which only writes the HW_LCDIF_CTRL0 register and sets the RUN bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-08-09video: Add System-Mode configuration hook into mxsfbMarek Vasut
Add hook that allow configuring SmartLCD attached the MXS LCDIF controller operating in System-Mode. This hook can be overriden by a platform-specific SmartLCD programming routine, which writes the SmartLCD specific values into it's registers. Also, this patch makes sure the SYNC signals are off for the SmartLCD case. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-08-09video: Allocate the MXSFB framebuffer alignedMarek Vasut
Allocate the framebuffer aligned so it can be flushed and the flush_dcache_range() function won't complain. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-06-28video: mxsfb: Break the line in videomode messageFabio Estevam
Currently we have the following on boot: CPU: Freescale i.MX28 rev1.2 at 454 MHz BOOT: SSP SD/MMC #0, 3V3 DRAM: 128 MiB MMC: MXS MMC: 0 Video: MXSFB: 'videomode' variable not set!In: serial Break the line of the warning message in order to have a better reading format. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-05-16video: mxsfb: Add an entry for mx23evk/mx28vk video modesFabio Estevam
Currently the mxsfb driver takes the display timings from the 'videomode' environment variable. Provide an example on how to set 'videomode' for using splash screen on mx23evk and mx28vk boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Marek Vasut <marex@denx.de>
2013-05-06arm: mxs: Add MXS LCDIF driverMarek Vasut
Add basic LCD driver for i.MX233 and i.MX28. This driver allows framebuffer console and framebuffer logo. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
