path: root/drivers/video/mxsfb.c
2013-08-09video: Implement continuous screen refresh for SmartLCD into mxsfbMarek Vasut
The LCDIF interface doesn't give us any means to do continuous refresh when driving a SmartLCD. To work this around, we produce a special circular DMA descriptor, which only writes the HW_LCDIF_CTRL0 register and sets the RUN bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-08-09video: Add System-Mode configuration hook into mxsfbMarek Vasut
Add hook that allow configuring SmartLCD attached the MXS LCDIF controller operating in System-Mode. This hook can be overriden by a platform-specific SmartLCD programming routine, which writes the SmartLCD specific values into it's registers. Also, this patch makes sure the SYNC signals are off for the SmartLCD case. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-08-09video: Allocate the MXSFB framebuffer alignedMarek Vasut
Allocate the framebuffer aligned so it can be flushed and the flush_dcache_range() function won't complain. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-06-28video: mxsfb: Break the line in videomode messageFabio Estevam
Currently we have the following on boot: CPU: Freescale i.MX28 rev1.2 at 454 MHz BOOT: SSP SD/MMC #0, 3V3 DRAM: 128 MiB MMC: MXS MMC: 0 Video: MXSFB: 'videomode' variable not set!In: serial Break the line of the warning message in order to have a better reading format. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-05-16video: mxsfb: Add an entry for mx23evk/mx28vk video modesFabio Estevam
Currently the mxsfb driver takes the display timings from the 'videomode' environment variable. Provide an example on how to set 'videomode' for using splash screen on mx23evk and mx28vk boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Marek Vasut <marex@denx.de>
2013-05-06arm: mxs: Add MXS LCDIF driverMarek Vasut
Add basic LCD driver for i.MX233 and i.MX28. This driver allows framebuffer console and framebuffer logo. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
