path: root/drivers/video/mx3fb.c
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-12-17video/mx3fb: fix clock dividerStefano Babic
Fix clock divider for COM57H5M10XRC display. The previous setting caused flicker. Tested on Qong (EVBLite with COM57H5M10XRC). Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2010-10-13MX31: add support for setting pin padsStefano Babic
The patch adds a utility function and defines to set the pad as it is done in linux. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-05-19MX31: Added support for the Casio COM57H5M10XRC to QONGStefano Babic
The patch adds setup to connect a CASIO COM57H5M10XRC (640x480 TFT display) to the QONG module. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-27MX31: Added LCD support for QONG moduleStefano Babic
Added support for LCD and splash image to the QONG module. The supported display is VBEST-VGG322403. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-02-24video: add an i.MX31 framebuffer driverGuennadi Liakhovetski
Add a driver for the Synchronous Display Controller and the Display Interface on i.MX31, using IPU for DMA channel setup. So far only displaying of bitmaps is supported, no text output. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
