path: root/drivers/video/lg4573.c
2015-09-02video, lg4573: make spi bus and cs configurableHeiko Schocher
make the spi bus and the spi chipselect configurable for the lg4573 driver. Use it on the aristainetos boards. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-04-20video, lg4573: add support for the lg4573 displayHeiko Schocher
