path: root/drivers/video/ipu_regs.h
2015-11-30video: ipu: fix out of bounds accessPeng Fan
We need to access reg stp_rep9, but not stp_rep[(9 - 1) / 2]. If using "__raw_writel(0, DI_STP_REP(disp, 9))", this will exceeds the size of stp_rep array. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Liu Ying <Ying.Liu@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2014-08-11video: ipu_disp: wait for DP SF end irq when disabling sync BG flowsLiu Ying
Instead of waiting for DC triple buffer to be cleared, this patch changes to wait for a relevant DP sync flow end interrupt to come when disabling sync BG flows. In this way, we align the implement to the freescale internal IPUv3 driver. After applying this patch, an uboot hang up issue at the arch_preboot_os() stage, where we disable a relevant ipu display channel, is not observed any more on some MX6DL platforms. Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2014-01-12video: ipu reg: Correct reserved array size in struct ipu_idmacLiu Ying
The array reserved as a placeholder in the structure ipu_idmac should contain 44 32bit unsigned integer entries instead of 45 ones, because the placeholder is located bewteen the register IDMAC_SC_CORD1 and the register IDMAC_CH_BUSY_1 with the address offsets of 0x804c and 0x8100 respectively. Reported-by: Robin Gong <b38343@freescale.com> Acked-by: Robin Gong <b38343@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2014-01-12video: ipu reg: Correct reserved1 array size in struct ipu_cmLiu Ying
The array reserved1 as a placeholder in the structure ipu_cm should contain 4 32bit unsigned integer entries instead of 16 ones, because the placeholder is located bewteen the register IPU_CH_DB_MODE_SEL_1 and the register IPU_ALT_CH_DB_MODE_SEL_0 with the address offsets of 0x154 and 0x168 respectively. Reported-by: Robin Gong <b38343@freescale.com> Acked-by: Robin Gong <b38343@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
2012-11-10mx6: use CONFIG_MX6 instead of CONFIG_MX6QTroy Kisky
Use CONFIG_MX6 when the particular processor variant isn't important. Reserve the use of CONFIG_MX6Q to specifically test for quad cores variant. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-10mx6: Allow mx6 to access the IPUv3 registersFabio Estevam
Adjust the IPUv3 registers, so that the IPUv3 driver can be extended for mx6 as well. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-25mx53: Allow IPUv3 driver to also work on mx53Fabio Estevam
Adjust the IPU base registers so that ipuv3 driver can work on both mx51 and mx53 SoCs. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-01GCC4.6: Squash warnings in ipu_disp.cMarek Vasut
ipu_disp.c: In function ‘ipu_disp_set_global_alpha’: ipu_disp.c:1237:11: warning: variable ‘flow’ set but not used [-Wunused-but-set-variable] ipu_disp.c: In function ‘ipu_disp_set_color_key’: ipu_disp.c:1302:16: warning: variable ‘flow’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2010-10-22MX51: Add IPU driver for video supportStefano Babic
The patch is a porting of the IPU Linux driver developed by Freescale to have framebuffer functionalities in u-boot. The port is based on kernel 2.6.31 commit cc4fe714041805997b601fe8e5dd585d8a99297f, as delivered by Freescale [i.MX BSP]. Most features are dropped from the original driver and only LCD support is the goal of this porting. Signed-off-by: Stefano Babic <sbabic@denx.de>
