path: root/drivers/video/display-uclass.c
2016-11-25video: Track whether a display is in useSimon Glass
Mark a display as in use when display_enable() is called. This can avoid a display being used by multiple video-output devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: video: Add a operation to display uclassJacob Chen
The current display class only allow to get timing from edid. So add a operation to get timing directly from driver. In driver, I will use fdtdec_decode_display_timing to get timing. Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21dm: video: Repurpose the 'displayport' uclass to 'display'Simon Glass
The current DisplayPort uclass is too specific. The operations it provides are shared with other types of output devices, such as HDMI and LVDS LCD displays. Generalise the uclass so that it can be used with these devices as well. Adjust the uclass to handle the EDID reading and conversion to display_timing internally. Also update nyan-big which is affected by this. Signed-off-by: Simon Glass <sjg@chromium.org>
