path: root/drivers/video/cfb_console.c
2009-06-12video: Add an option to skip video initializationWolfgang Denk
This patch adds an option to skip the video initialization on for all video drivers. This is needed for the CPCI750 which can be built as CPCI host and adapter/target board. And the adapter board can't access the video cards located on the CompactPCI bus. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Rebased against simplifying patch. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12drv_video_init(): simplify logicWolfgang Denk
Simplify nesting of drv_video_init() and use a consistent way of indicating failure / success. Before, it took me some time to realize which of the returns was due to an error condition and which of them indicated success. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2009-04-28video: fix bug in cfb_console.c codeAnatolij Gustschin
Fix bug in drawing long version/info strings: U-Boot version string like "U-Boot 2009.03-05647-g7c51e06 (Apr 23 2009 - 12:40:00) MPC83XX" is long and doesn't wrap around correctly while drawing beside the logo. Such long strings partially overwrite the logo. This patch is an attempt to fix it. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-07clean up some #if !defined() in drivers/video/cfb_console.cAndrew Dyer
rearrange some #if !defined() / #else / #endif statements to remove the negative logic. Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
2008-08-18video: Clean drivers/video/MakefileMichal Simek
2008-08-11video: fix bug in cfb_console codeAnatolij Gustschin
FILL_15BIT_555RGB macro extension for pixel swapping by commit bed53753dd1d7e6bcbea4339be0fb7760214cc35 introduced a bug in cfb_console: Bitmaps with odd-numbered width won't be rendered correctly and even U-Boot crashes are observed on some platforms while repeated rendering of such bitmaps with "bmp display". Also if a bitmap is rendered to an odd-numbered x starting position, the same problem occurs. This patch is an attempt to fix it. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-08-11video: fix bug in logo_plotAnatolij Gustschin
If logo_plot() should ever be called with x starting position other than zero and for pixel depths greater than 8bpp, logo colors distortion will be observed. This patch fixes the issue. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-04-21video: Add missing free for logo memoryMatthias Fuchs
This patch adds two missing free()s. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-11Add Fujitsu CoralP/Lime video driverAnatolij Gustschin
Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Rodolfo Giometti <giometti@linux.it>
2008-01-11Fix video console newline and carriage return handlingAnatolij Gustschin
Lines of the lenght CONSOLE_COLS or greater than CONSOLE_COLS are not displayed correctly. This is an attempt to fix this issue. Also add carriage return handling. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Rodolfo Giometti <giometti@linux.it>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-11-25drivers/video : move video drivers to drivers/videoJean-Christophe PLAGNIOL-VILLARD
