path: root/drivers/video/cfb_console.c
2015-11-05video: Drop DEV_EXT_VIDEO flagBin Meng
DEV_EXT_VIDEO does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26video: cfb_console: Allow VGA device to work without i8042 keyboardBin Meng
So far if CONFIG_VGA_AS_SINGLE_DEVICE is not defined, the VGA device will try to initialize a keyboard device (for x86, it is i8042). But if i8042 controller initialization fails (eg: there is no keyboard connected to the PS/2 port), drv_video_init() just simply returns. This kills the opportunity of using a usb keyboard later with the vga console, as the vga initialization part is actually ok, only keyboard part fails. Change the code logic to allow this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-14cfbconsole: Add support for stride != widthHans de Goede
cfbconsole currently assumes that the width and stride of the framebuffer are the same, in most places where stride matters it uses a VIDEO_LINE_LEN helper macro. This commit changes the few places not using VIDEO_LINE_LEN to also use VIDEO_LINE_LEN, and protects the default VIDEO_LINE_LEN with a #ifndef guard, allowing the boards config.h to override and, and thus support cases where stride != width. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-14cfbconsole: Remove width argument from the logo functionsHans de Goede
The passed in width is always VIDEO_COLS. This is a preparation patch for adding stride != width support to the cfbconsole code. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-06-10Remove typedefs from bmp_layout.hSimon Glass
We try to avoid typedefs and these ones are easy enough to remove. Before changing this header in the next patch, remove the typedefs. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-16x86: video: Allow keyboard presence to be controlled by device treeSimon Glass
At present a VGA console assumes a keyboard unless a CONFIG option is set. This difference can be dealt with by a device tree option, allowing boards that are otherwise the same to use the same configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: video: Add support for CONFIG_CONSOLE_SCROLL_LINESSimon Glass
Some machines are very slow to scroll their displays. To cope with this, support the CONFIG_CONSOLE_SCROLL_LINES option. Setting this to 5 allows the display to operate at an acceptable speed by scrolling 5 lines at a time. This same option is available for LCDs so when these systems are unified this code can be unified also. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-16ppc4xx: remove dead codeMasahiro Yamada
Since commit 843125daebd7 (ppc4xx: remove HH405 board), CONFIG_HH405 is not defined. Since commit d52633047913 (ppc4xx: remove PMC405), CONFIG_PMC405 is not defined. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-30video: speedup writing strings to fb consoleSoeren Moch
With enabled framebuffer console the printenv command can take several seconds to complete. This patch temporarily disables cache flush when writing strings to fb console. Then there is no noticable delay anymore. Tested with imx6 hdmi framebuffer. Signed-off-by: Soeren Moch <smoch@web.de> Acked-by: Stefano Babic <sbabic@denx.de>
2014-10-25serial: make local functions staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-25video: use __weakJeroen Hofstee
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-07-23stdio: Remove redundant code around stdio_register() callsSimon Glass
There is no point in setting a structure's memory to NULL when it has already been zeroed with memset(). Also, there is no need to create a stub function for stdio to call - if the function is NULL it will not be called. This is a clean-up, with no change in functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-03-10cfb_console: align fields in gzipped .bmp filesEric Nelson
.bmp files contain 32-bit integers aligned at offsets of +2, +6, et cetera within the bmp_header structure (see include/bmp_layout.h). Support for gzip-compressed .bmp files is present in the cfb_console display subsystem by uncompressing them prior to use. This patch forces the in-memory header to be aligned properly for these compressed images by extracting them to a 2-byte offset in the memory returned by malloc. Since malloc will always return a 4-byte aligned value, this forces the .bmp header fields to be naturally aligned on 4-byte addresses. Refer to these files for more details: doc/README.displaying-bmps Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-10-30video, cfb_console: make background and foreground color configurableHeiko Schocher
make CONSOLE_BG_COL/CONSOLE_FG_COL configurable through board config file. Clear video screen in video_init(). Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2013-08-12video: Encapsulate font in video_font_data.hMarek Vasut
This patch moves all the font configuration values into video_font_data.h so they are all in the right place with the font. The video_font.h now only includes video_font_data.h and will allow us to select and include different font once more fonts are added. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [agust: fixed build warning for mcc200] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-08-10video: add an option to skip cfb console initHeiko Schocher
This patch add an option to skip cfb console init for boards who want to show a logo, but not use the cfb console. This is needed for the siemens boards, which have a bmp bootlogo, but do not need the cfb console. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [agust: use '__weak int board_cfb_skip(void)'] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-08-10video: Fix cfb_console for 4-bit wide fontMarek Vasut
The cfb_console can't handle 4-bit wide font properly, since with 4-bit wide font, all 8 bits are drawn. Unbreak the video_drawchars() function to correctly render 4-bits only on such fonts. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2013-07-08video: consolidate splash screen alignment codeAnatolij Gustschin
Code for checking "splashpos" environment variable is duplicated in drivers, move it to the common function. Call this function also in the bmp display command to consider "splashpos" settings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-01video: lcd: Add CONFIG_SPLASH_SCREEN_PREPARE support to CONFIG_VIDEORobert Winkler
Create splash.c/h to put the function and any future common splash screen code in. Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-06-07Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2013-05-06arm: mxs: Add MXS LCDIF driverMarek Vasut
Add basic LCD driver for i.MX233 and i.MX28. This driver allows framebuffer console and framebuffer logo. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-05-06cfb_console: flush FB cache at end of public functionsEric Nelson
Removed internal cache_flush operations and placed a flush of the entire frame-buffer at the end of each public function. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-21video: Fix splash screen alignmentMatthias Weisser
commit d484b52 "video: Skip bitmaps which do not fit into the screen in cfb_console" breaks splash screen alignment which is passed in as magic (BMP_ALIGN_CENTER) x/y coordinates. Moving the check after the alignment block fixes this. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Simon Glass <sjg@chromium.org>
2012-12-06video: Check for valid FB pointer before clearingDuncan Laurie
This command will start erasing at memory address zero if there is not a valid framebuffer address that was found during video_init(). This is a common case with Chrome OS devices in normal mode when we do not execute the video option rom in coreboot. Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-07video: Skip bitmaps which do not fit into the screen in cfb_consoleVadim Bendebury
The cfb console driver is trying to prevent bitmaps to spill over the screen, but the calculations assume that at least part of the bitmap fits into the screen area. In reality there could be bitmap elements which are completely out of the screen area, they just need to be discarded. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-07video: Implement additional video API functions in cfb_consoleStefan Reinauer
Implement the new video API functions to provide access to screen size, etc. Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-30cfb_console: Add support for some ANSI terminal escape codesPali Rohár
Add optional support for some ANSI escape sequences to the cfb_console driver. Define CONFIG_CFB_CONSOLE_ANSI to enable cursor moving, color reverting and clearing the cfb console via ANSI escape codes. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-01video: cfb_console: add function to plot the logo area blackBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rini <trini@ti.com> CC: Stefano Babic <sbabic@denx.de>
2012-10-01video: cfb_console: logo can be positioned via the splashpos variableBastian Ruppert
Extend the driver for placing the video/bmp logo as specified by "splashpos" environment variable. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> CC: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-07-10video: Rename CONFIG_VIDEO_MX5Fabio Estevam
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-05video: cfb_console: flush dcache for frame buffer in DRAMAnatolij Gustschin
Data cache flushing is required for frame buffer in RAM to fix the distorted console text output. Currently this text distortion is observed with cfb on beagleboard and N900 when running with data cache enabled. Reported-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-05cfb_console: Ignore bell characterPali Rohár
2012-06-04cfb_console: Add console_clear_line functionPali Rohár
console_clear_line() clears part of specified line or the full line. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-06-04cfb_console: Fix function console_backPali Rohár
* Do not disable and enable the cursor again. console_back() is called only from video_putc() which already turns the cursor off at the beginning and turns it on at the end, so there is no need to change the cursor in console_back(). Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-07video: cfb_console: fix build warningsAnatolij Gustschin
Fix: cfb_console.c:371: warning: 'cursor_state' defined but not used cfb_console.c:372: warning: 'old_col' defined but not used cfb_console.c:373: warning: 'old_row' defined but not used cfb_console.c:435: warning: 'video_invertchar' defined but not used Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Wolfgang Denk <wd@denx.de>
2011-12-05video: cfb_console: Make the software cursor non-destructiveGabe Black
When printing the string "\r\n" to the framebuffer console, the first character of the current line was being replaced with a space. The "boot" prompt would become the "oot" prompt. This change makes the cursor non-destructive so that no matter where it goes on its way to where it's supposed to be, the end result is that the cursor is where it's supposed to be with the other text preserved. Signed-off-by: Gabe Black <gabeblack@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-29CFB: Fix font rendering on mx5 framebufferMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-11-15font: split font data from video_font.hChe-Liang Chiou
While video_font.h is useful even without referencing the font data, it is not possible to be included multiple times because it defines font data array right in the header. This patch splits the font data array into video_font_data.h and so now video_font.h can be included multiple times. This at least solves the code duplication in board/mcc200/lcd.c. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-15tools: logo: split bmp arrays from bmp_logo.hChe-Liang Chiou
The generated header bmp_logo.h is useful even outside common/lcd.c for the logo dimension. However, the problem is, the generated bmp_logo.h cannot be included multiple times because bmp_logo_palette[] and bmp_logo_bitmap[] are defined in the bmp_logo.h. This patch fixes this by defining these arrays in another header bmp_logo_data.h and in bmp_logo.h only declaring these arrays. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-07drivers/video/cfb_console.c:Fix GCC 4.6 build warningWolfgang Denk
Silence this warning: cfb_console.c: In function 'video_logo': cfb_console.c:1563:18: warning: variable 'y_off' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-10-27GCC4.6: Squash warning in cfb_console.cMarek Vasut
cfb_console.c: In function 'video_display_bitmap': cfb_console.c:1148: warning: format '%d' expects type 'int', but argument 2 has type 'long unsigned int' cfb_console.c:1148: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-13video: Moving mx3fb.c to CONFIG_VIDEOHelmut Raiger
mx3fb.c was based on CONFIG_LCD and is moved by this patch to CONFIG_VIDEO, which has greater freedom in selecting videomodes even at runtime. This renders the accumulating list of display defines (CONFIG_DISPLAY_VBEST..., CONFIG_DISPLAY_C057...) obsolete as these may be setup through env variables: uboot> setenv mydisplay 'video=ctfb:x:240,y:320,depth:16,mode:0,pclk:185925, le:9,ri:17,up:7,lo:10,hs:1,vs:1,sync:100663296,vmode:0' uboot> setenv videomode ${mydisplay} This commit also fixes the board config files for qong and imx31_phycore boards as needed. The videomode settings of previously supported displays are added to CONFIG_EXTRA_ENV_SETTINGS now. CONFIG_SYS_MALLOC_LEN for imx31_phycore board is increased to make the frame buffer allocation working with the changed driver. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-08-01cfb_console.c: checkpatch cleanupWolfgang Denk
Fix the following: ERROR: do not initialise statics to 0 or NULL ERROR: do not use assignment in if condition Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-08-01cfb_console.c: drop custom PRINTD() and use debug() insteadWolfgang Denk
