path: root/drivers/video/bus_vcxk.c
2015-06-10Remove typedefs from bmp_layout.hSimon Glass
We try to avoid typedefs and these ones are easy enough to remove. Before changing this header in the next patch, remove the typedefs. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2013-11-13video: remove AT91 legacy API from bus_vcxkAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-11-14Video: fix compiler warnings in bus_vcxkJens Scharsig (BuS Elektronik)
if a board uses the vcxk driver option CONFIG_SYS_VCXK_DOUBLEBUFFERD, compilier shows warnings. This patch will fix it. Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2011-11-16drivers/video/bus_vcxk.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: bus_vcxk.c: In function 'vcxk_display_bitmap': bus_vcxk.c:396:16: warning: variable 'compression' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-27GCC4.6: Squash warning in bus_vcxk.cMarek Vasut
bus_vcxk.c:167:2: warning: format '%d' expects type 'int', but argument 2 has type 'u_long' bus_vcxk.c:167:2: warning: format '%d' expects type 'int', but argument 3 has type 'u_long' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2010-02-12convert common files to new SoC accessJens Scharsig
* add's a warning to all files, which need update to new SoC access * convert common files in cpu/../at91 and a lot of drivers to use c stucture SoC access Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-08-09bus_vcxk.c: fix warning: unused variable 'lineptr'Jens Scharsig
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2009-07-26video: bus_vcxk.c: fix style issues added by 50217deeAnatolij Gustschin
2009-07-26new video driver for bus vcxk framebuffersJens Scharsig
This patch adds a new video driver * adds common bus_vcxk framebuffer driver Signed-off-by: Jens Scharsig <esw@bus-elektronik.de> [agust@denx.de: fixed lots of style issues before applying] Signed-off-by: Anatolij Gustschin <agust@denx.de>
