add support for Renesas R8A66597 usb controller.
This patch supports USB Host mode.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Add support to drivers/usb/usbdcore_omap1510.c for OMAP5912 and OMAP16xx devices.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
This patch fixes bugs in usbdcore*.c related to the use of devices
with multiple configurations.
The original code made mistakes about the meaning of configuration value and
configuration index, and the resulting off-by-one errors resulted in:
* SET_CONFIGURATION always selected the first configuration, no matter what
wValue is being passed.
* GET_DESCRIPTOR/CONFIGURATION always returned the descriptor for the first
configuration (index 0).
Signed-off-by: Harald Welte <laforge@openmoko.org>
Acked-by: Markus Klotzbuecher <mk@denx.de>
Signed-off-by: Christian Eggers <ceggers@gmx.de>
Add new configuration variable CONFIG_PCI_OHCI_DEVNO.
In case of several PCI USB controllers on a board this variable
specifys which controller to use.
Also add USB support for sokrates board.
See doc/README.generic_usb_ohci for details.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: gururaja hebbar <gururajakr@sanyo.co.in>
This patch adds CFG_OHCI_USE_NPS to the common USB-OHCI driver. This
way a board just needs to define this new option to enable the "force
NoPowerSwitching mode" instead of adding new CPU/architecture defines
to the USB source itself.
This new option will be used first with the new AMCC 460EX Canyonlands
board port, which will be posted in a few days.
This patch also fixes a small compilation problem when DEBUG is enabled.
(needed for M5475EVB)
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
