path: root/drivers/usb
2015-05-05Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2015-05-04drivers: usb: fsl: Workaround for Erratum A004477Nikhil Badola
Add a delay of 1 microsecond before issuing soft reset to the controller to let ongoing ULPI transaction complete. This prevents corruption of ULPI Function Control Register which eventually prevents phy clock from entering to low power mode Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04sunxi: usb: Do not call phy_probe from hcd codeHans de Goede
The 2/3 usb-phys on the sunxi SoCs are really a single separate functional block, and are modelled as such in devicetree. So once we've moved all the sunxi usb code to the driver-model then phy_probe will be called once for the entire block from the driver-model enumeration code. Move to this now as this also avoids problems with phy_probe being called multiple times once we introduce ohci support. This also allows us to get rid of the sunxi_usb_phy_enabled_count variable as phy_probe now is guaranteed to be called only once. Since we're effectively rewriting the probe / remove functions, move them to the end of the file while we are at it, as that is the most logical place for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: usb: Rename the usbc.? files to usb_phy.?Hans de Goede
The usbc.? files now only contain usb-phy related code, rename them to make this clear. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: usb: Rename sunxi_usbc_foo functions to sunxi_usb_phy_barHans de Goede
Rename the sunxi_usbc_foo functions to sunxi_usb_phy_bar to make it clear that these are usb-phy functions. Also change the verbs & nouns in the suffix to match the verbs & nouns used in the Linux kernels generic phy framework. This patch purely renames things, it contains no functional changes. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: usb: Remove sunxi_usbc_get_io_base functionHans de Goede
This is the only function left in sunxi/usbc.c which is not phy related, so remove it. This is a preparation patch for turning the usbc.c code into a proper usb phy driver. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: usb: Move setup of host controller clocks to the host controller driversHans de Goede
The sunxi "usbc" code is mostly about phy setup, but currently also sets up the host controller clocks, which is something which really belongs in the host controller drivers, so move it there. This is a preparation patch for moving the sunxi ehci code to the driver model and for adding ohci support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Add basic A33 basic supportVishnu Patekar
Enable full support for the A33 SoC including display, otg-usb, etc. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-04-23Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-04-23usb: host: Add ehci-vf USB driver for ARM Vybrid SoC'sSanchayan Maity
This driver adds support for the USB peripheral on Freescale Vybrid SoC's. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-04-22dm: usb: Add a terminator to the string destructor listSimon Glass
The terminator is missing. Add it for completeness. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-21drivers:usb: Check if USB Erratum A005697 is applicable on BSC913xNikhil Badola
Check if USB Erratum A005697 is applicable on BSC913x and add corresponding property in the device tree via device tree fixup which is used by linux driver Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21drivers:usb: Add device-tree fixup to identify socs having dual phyNikhil Badola
Identify soc(s) having dual phy so as to add "utmi_dual" as phy_mode for all these socs. This is required for supporting deel-sleep feature in linux for usb driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: exynos: Adjust XHCI driver to support driver modelSimon Glass
Support driver model in the exynos XHCI driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Rename the XHCI HCD to U-BootSimon Glass
This should be "U-Boot", not "u-boot". Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Support driver model in XHCISimon Glass
Add driver model support in the XHCI support code so that it can be used by XHCI USB drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Factor out common init/uninitSimon Glass
Since driver model will want to use most of the same code for XHCI init and uninit, put it in a separate function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Use explicit parameters for xhci_setup_addressable_virt_dev()Simon Glass
This function should not be delving into struct usb_device. Pass in the parameters it needs directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Use explicit parameters for xhci_alloc_virt_device()Simon Glass
2015-04-18dm: usb: xhci: Use a function to get xhci_ctrlSimon Glass
Rather than getting this directly from struct usb_device, call a function to obtain it. This will make it possible for driver model to provide it another way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Add driver model support to tegra EHCISimon Glass
Update this driver with driver model support for USB. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Move most of init/uninit into a functionSimon Glass
We want to use mostly the same init and uninit code for driver model, so move the common part into two functions. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Tidy up error handling and a static functionSimon Glass
Try to return useful error numbers where possible. Also avoid swallowing an error number when it is returned by a called function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Remove the port_addr_clear_csc variableSimon Glass
This variable is a bit of a hack. We can obtain the same information from the normal device config. This will fit better with driver model, where global variables are best avoided. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Add driver model support to exynos EHCISimon Glass
2015-04-18dm: usb: Add support for USB ethernet devices with driver modelSimon Glass
Add support for scanning USB etghernet devices with driver model. This mostly involves scanning all buses since device numbering is not unique across buses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add a driver for sandboxSimon Glass
This driver supports using emulation devices to provide a USB bus within sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add an emulator for USB hub emulationSimon Glass
All USB controllers need a root hub. Add a sandbox emulation for this so that we can add USB devices to sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add an emulator for USB flash devicesSimon Glass
This emulator supports USB enumeration and allows a local file to be provided as the contents of the emulated flash stick. U-Boot can then use the file as it would a normal device, with all access passing through the usb_stor layer and the USB stack. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Reset emulation devices in usb stop()Simon Glass
These devices must have their addresses removed ready for the next USB bus enumeration. Add this logic to usb_stop(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add a uclass for USB device emulationSimon Glass
With sandbox we want to be able to emulate USB devices so that we can test the USB stack. Add a uclass to support this. It implements the same operations as a normal USB device driver, but in this case passes them on to an emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Allow setting up a USB controller as a device/gadgetSimon Glass
Some controllers support OTG (on-the-go) where they can operate as either host or device. The gadget layer in U-Boot supports this. While this layer does not interact with driver model, we can provide a function which sets up the controller in the correct way. This way the code at least builds (although it likely will not work). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Bind generic USB devices when there is no driverSimon Glass
At present USB devices with no driver model driver cannot be seen in the device list, and we fail to set them up correctly. This means they cannot be used. While having real drivers that support driver model for all USB devices is the eventual goal, we are not there yet. As a stop-gap, add a generic USB driver which is bound when we do not have a real driver. This allows the device to be set up and shown on the bus. It also allows ad-hoc code (such as usb_ether) to find these devices and set them up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Allow USB drivers to be declared and auto-probedSimon Glass
USB devices in U-Boot are currently probed only after all devices have been enumerated. Each type of device is probed by custom code, e.g.: - USB storage - Keyboard - Ethernet With driver model this approach doesn't work very well. We could build a picture of the bus and then go back and add the devices later, but this means that the data structures are incomplete for quite a while. It also does not follow the model of being able to bind a device when we discover it. We would prefer to have devices automatically be bound as the device is enumerated. This allows us to attach drivers to particular USB classes or product/vendor IDs. This is the method used by Linux. Add the required #defines from Linux, a way of declaring a USB driver and the logic to locate the correct driver given the USB device's descriptors. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Add driver model support to EHCISimon Glass
Add a way for EHCI controller drivers to support driver model. Drivers can call ehci_register() to register themselves in their probe() methods. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Change ehci_reset() to use a pointerSimon Glass
The index cannot be used with driver model, and isn't needed anyway. Change the parameter to a pointer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Drop the EHCI weak functionsSimon Glass
These are a pain with driver model because we might have different EHCI drivers which want to implement them differently. Now that they use consistent function signatures, we can in good conscience move them to a struct. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> Fix non-driver-model EHCI to set up the EHCI operations correctly: Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-18dm: usb: Refactor EHCI initSimon Glass
Move the bulk of the code in usb_lowlevel_init() into a separate function which will also be used by driver model. Keep the CONFIG options out of this function by providing a tweak flag for Faraday. We need to avoid using CONFIG options in driver model code where possible, since it makes it impossible to use multiple controllers in that code where they have different options. The CONFIG_EHCI_HCD_INIT_AFTER_RESET option is also kept out of the common init function. With driver model the controller will be able to perform this extra init itself after registering with the EHCI layer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: ehci: Use a function to find the controller from struct udeviceSimon Glass
With driver model we want to remove the controller pointer in struct udevice and use driver model data structures instead. To prepare for this, move access to this field to a function which can provide a different implementation for driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Pass EHCI controller pointer to ehci_get_portsc_register()Simon Glass
Adjust this function so that it is passed an EHCI controller pointer so that implementations can look up their controller. This makes the weak functions use a consistent API. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Pass EHCI controller pointer to ehci_set_usbmode()Simon Glass
2015-04-18dm: usb: tegra: Drop use of global controller variableSimon Glass
We don't need this anymore, so adjust the code to avoid using it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Pass EHCI controller pointer to ehci_powerup_fixup()Simon Glass
Adjust this function so that it is passed an EHCI controller pointer so that implementations can look up their controller. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Store the controller type explicitlySimon Glass
At present the tegra driver uses a separate pointer to know which controller type is in use. This works because only one controller type is used at a time. With driver model we want to make the controller state hermetic in the sense that it is not necessary to look elsewhere to know the controller type. This will permit a controller to implement the EHCI weak functions without reference to global data structures. To achieve this, define an enum for the controller type and store it with the information on each EHCI controller. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Allow ECHI to hold private data for the controllerSimon Glass
Add a private data pointer that clients of EHCI can use to access their private information. This establishes a link between struct ehci_ctrl and its associated controller data structure. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Pass EHCI controller pointer to ehci_get_port_speed()Simon Glass
2015-04-18dm: usb: Move all the EHCI weak functions together and declare themSimon Glass
Put these at the top of the file so they are in one place. Also add function prototypes to the header file to avoid call site mismatches. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
