path: root/drivers/usb
2010-05-06drivers/*/Makefile: fix conditional compile rule.Ender.Dai
Fix conditional compile rule for twl4030.c and videomodes.c. Signed-off-by: Ender.Dai <ender.dai@gmail.com>
2010-04-13mips: Move cpu/mips/* to arch/mips/cpu/*Peter Tyser
2010-04-08EHCI: add NEC PCI IDSergei Shtylyov
Add NEC EHCI controller to the list of the supported devices. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com> drivers/usb/host/ehci-pci.c | 1 + 1 file changed, 1 insertion(+)
2010-04-08EHCI: fix port reset reportingSergei Shtylyov
Commit b416191a14770c6bcc6fd67be7decf8159b2baee (Fix EHCI port reset.) didn't move the code that checked for successful clearing of the port reset bit from ehci_submit_root(), relying on wait_ms() call instead. The mentioned code also erroneously reported port reset state when the reset was already completed. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
2010-04-08EHCI: fix off-by-one error in ehci_submit_root()Sergei Shtylyov
USB devices on the 2nd port are not detected and I get the following message: The request port(1) is not configured That's with default CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS value of 2. 'req->index' is 1-based, so the comparison in ehci_submit_root() can't be correct. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
2010-04-08EHCI: fix root hub device descriptorSergei Shtylyov
On little endian machines, EHCI root hub's USB revision is reported as 0.2 -- cpu_to_le16() was missed in the initializer for the 'bcdUSB' descriptor field. The same should be done for the 'bcdDevice' field. Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
2010-04-03at91: use C structs for AT91 OHCI codeMatthias Fuchs
This patch is part of migrating the AT91 support towards using C struct for all SOC access. It removes one more CONFIG_AT91_LEGACY warning. at91_pmc.h needs cleanup after migration of the drivers has been done. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-02-12convert common files to new SoC accessJens Scharsig
* add's a warning to all files, which need update to new SoC access * convert common files in cpu/../at91 and a lot of drivers to use c stucture SoC access Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-03musb: Add host support for DM365 EVMPrathap Srinivas
Add support for musb host on DM365 EVM. Signed-off-by: Prathap Srinivas <msprathap@ti.com>
2010-02-03usb: musb: fix Blackfin DMA register paddingCliff Cai
The conversion from offsets to C structs lost a little padding in the DMA register map. Accessing endpoints other than ep0 with DMA would fail as the addresses wouldn't be adjusted correctly. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-23SPEAr : usbd driver support for SPEAr SoCsVipin KUMAR
SPEAr SoCs contain a synopsys usb device controller. USB Device IP can work in 2 modes - DMA mode - Slave mode The driver adds support only for slave mode operation of usb device IP. This driver is used along with standard USBTTY driver to obtain a tty interface over USB on the host Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2010-01-12usb: musb: add virtual root hub control supportBryan Wu
For MUSB devices that do not support multipoint (hubs), we have to emulate a root hub so that we can support core operations like resetting ports. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-09Add ppc440epx USB ehci support.Chris Zhang
Currently ppc440epx uses OHCI for USB full-speed support. This change adds support for EHCI. Signed-off-by: Chris Zhang <chris@seamicro.com>
2010-01-09Fix EHCI port reset.Chris Zhang
In USB ehci driver, the port reset is not terminated. EHCI spec says "A host controller must terminate the reset and stabilize the state of the port within 2 milliseconds". Without termination, a port stays at reset state. This is observed on ppc4xx(sequoia) boards. Signed-off-by: Chris Zhang <chris@seamicro.com>
2010-01-09omap3: fix compile warningSanjeev Premi
This patch fixes this warning during compile: omap3.c: In function 'musb_platform_init': omap3.c:126: warning: label 'end' defined but not used Problem reported by: Dirk Behme[dirk.behme@googlemail.com] Signed-off-by: Sanjeev Premi <premi@ti.com>
2010-01-09usb: musb: add support for Blackfin MUSBBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-01-09usb: musb: change rxcsr register from write to read/modify/writeBryan Wu
The RX Control/Status register has bits that we want to preserve, so don't just write out a single bit. Preserve the others bits in the process. The original code posted to the u-boot list had this behavior, but looks like it was lost somewhere along the way to merging. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-01-09usb: musb: make multipoint optionalBryan Wu
The multipoint handling under MUSB is optional, and some parts (like the Blackfin processor) do not implement support for it. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-01-09usb: musb: make fifo support configurableBryan Wu
The dynamic FIFO handling under MUSB is optional, and some parts (like the Blackfin processor) do not implement support for it. Due to this, the FIFO reading/writing steps need special handling, so mark the common versions weak so drivers can override. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-01-09usb: musb: make sure the register layout is packedMike Frysinger
2010-01-09DA8xx: Add MUSB host supportAjay Kumar Gupta
Tested USB host functionality on DA830 EVM. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com>
2009-12-20OMAP3 USB Initialize twl4030 only if requiredTom Rix
OMAP3EVM uses ISP1504 phy and so twl4030 related init is not required. Submitted-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20OMAP3 Add usb device supportTom Rix
This change adds the usb device support for musb. Omap3 platform support added at the same level as davinci. The interface for usbtty to use the musb device support was added. Verified on omap3 beagle, zoom1 and zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20TWL4030 Add usb PHY supportTom Rix
The twl4030 provides a PHY device for connecting a link device, like musb, to physical connection. This change adds the twl4030 usb registers and functions for initializing the PHY as required by omap3. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20USB Consolidate descriptor definitionsTom Rix
The header files usb.h and usbdescriptors.h have the same nameed structure definitions for usb_config_descriptor usb_interface_descriptor usb_endpoint_descriptor usb_device_descriptor usb_string_descriptor These are out right duplicates in usb.h usb_device_descriptor usb_string_descriptor This one has extra unused elements usb_endpoint_descriptor unsigned char bRefresh unsigned char bSynchAddress; These in usb.h have extra elements at the end of the usb 2.0 specified descriptor and are used. usb_config_descriptor usb_interface_descriptor The change is to consolidate the definition of the descriptors to usbdescriptors.h. The dublicates in usb.h are removed. The extra element structure will have their name shorted by removing the '_descriptor' suffix. So usb_config_descriptor -> usb_config usb_interface_descriptor -> usb_interface For these, the common descriptor elements are accessed now by an element 'desc'. As an example - if (iface->bInterfaceClass != USB_CLASS_HUB) + if (iface->desc.bInterfaceClass != USB_CLASS_HUB) This has been compile tested on MAKEALL arm, ppc and mips. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27s3c64xx: move s3c64xx header files to asm-arm/arch-s3c64xxMinkyu Kang
This patch moves the s3c64xx header files from include/ to include/asm-arm/arch-s3c64xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-07-23usb: bugfix driver/usb/host/ehci-hcd.c function ehci_submit_rootPrafulla Wadaskar
This change is cheked in Linux source and fix found to be in sync. This patch is tested for USB host interface on Kirkwood based Sheevaplug platform (ARM little endian board) Risk: the impact of this patch is not validated on big endian board. This need to be checked... Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-11usb: Fix compiler warning with gcc4.4Kumar Gala
ehci-hcd.c: In function 'ehci_submit_root': ehci-hcd.c:719: warning: value computed is not used ehci-hcd.c:748: warning: value computed is not used Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-09usb: add Marvell Kirkwood ehci host controller driverPrafulla Wadaskar
This driver is tested on Sheevaplug platform Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-09mpc8xxx: USB: fix: access of ehci struct elementsVivek Mahajan
This patch fixes the access to the 'ehci' struct elements which should have been taken care off in 4ef01010aa4799c759d75e67007fdd3a38c88c8a Sorry about that. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-09usb: musb: add timeout via CONFIG_MUSB_TIMEOUTBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-07-09usb: musb: drop old musb read/write prototypesMike Frysinger
These functions are no longer defined, so remove their prototypes. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc83xx: USB: Reorganized its supportVivek Mahajan
The following patch reorganizes/reworks the USB support for mpc83xx as under:- * Moves the 83xx USB clock init from drivers/usb/host/ehci-fsl.c to cpu/mpx83xx/cpu_init.c * Board specific usb_phy_type is read from the environment * Adds USB EHCI specific structure in include/usb/ehci-fsl.h * Copyrights revamped in most of the following files Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc8xxx: USB: Relocates ehci-fsl.h to include/usbVivek Mahajan
The following patch moves 8xxx-specifc USB #defines from drivers/usb/host/ehci-fsl.h to include/usb. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc8xxx: USB: Removed reenablement of its interfaceVivek Mahajan
To prepare for the 85xx USB support, which requires interface enablement only once in (specified) order, no different than instructions for enabling the interface under 83xx. It is unknown why the original author enabled the interface twice (checked for references in errata, etc). Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-09at91: fix a USB problem for AT91SAM9261RONETIX - Ilko Iliev
This patch corrects the missing PLLB initialization in usb_cpu_init() for AT91SAM9261. Because of the missing PLLB initialization, the USB support for all AT91SAM9261 based boards will work only if the PLLB is configured by a precedent bootloader. Signed-off-by: Ilko Iliev <iliev@ronetix.at> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-28Replace __attribute references with __attribute__Peter Tyser
__attribute__ follows gcc's documented syntax and is generally more common than __attribute. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-06Support for PXA27X UDC.Remy Bohmer
This Patch adds Support for PXA27X UDC. (Rebased to drivers/usb reorganisation) Signed-off-by: Vivek Kutal <vivek.kutal@azingo.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-04-06drivers/usb: regorganisationJean-Christophe PLAGNIOL-VILLARD
move to linux usb driver organisation as following drivers/usb/gadget drivers/usb/host drivers/usb/musb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-04-04at91: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
2009-03-29s3c64xx: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
add CONFIG_USB_S3C64XX to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-22r8a66597-hcd: fix cannot use external hubYoshihiro Shimoda
Fix the problem that cannot use external hub, because this driver did not control correctly a DEVADDx register. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
