path: root/drivers/usb
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-26Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-10-25ehci-hcd.c: make local functions staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-25usb: use __weakJeroen Hofstee
2014-10-23keystone: usb: add support of usb xhciWingMan Kwok
Add support of usb xhci. xHCI controls all USB speeds of the Host mode, that is, the SS through the SS PHY, as well as the HS, FS, and LS through the USB2 PHY. xHCI replaces and supersedes all previous host HCIs (HS-only EHCI, FS/LS OHCI and UHCI), and is therefore not backwards compatible with any of them. The USB3SS’s USB Controller is fully compliant with xHC. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-22usb: dwc2: Add driver for Synopsis DWC2 USB IP blockOleksandr Tymoshenko
This is the USB host controller used on the Altera SoCFPGA and Raspbery Pi. This code has three checkpatch warnings, but to make sure it stays at least readable and clear, these are not fixed. These bugs are in the USB request handling combinatorial logic, so any abstracting of those is out of question. Tested on DENX MCV (Altera SoCFPGA 5CSFXC6C6U23C8N) and RPi B+ (BCM2835). Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Vince Bridgers <vbridger@altera.com> Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-10-22net: asix: Add support for AX88772BAlexandre Courbot
This USB device works as-is on this driver. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
2014-10-11Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-10-08Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
The single file conflict below is actually trivial. Conflicts: board/boundary/nitrogen6x/nitrogen6x.c
2014-10-06usb: gadget: fastboot: terminate commands with NULLEric Nelson
Without NULL termination, various commands will read past the end of input. In particular, this was noticed with error() calls in cb_getvar and simple_strtoul() in cb_download. Since the download callback happens elsewhere, the 4k buffer should always be sufficient to handle command arguments. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06usb: musb-new: core: set MUSB_POWER_HSENAB in MUSB_POWER for host modeDaniel Mack
This bit allows the MUSB controller to negotiate for high-speed mode when the device is reset by the hub. If unset, Babble errors occur with high-speed mass storage devices right after the first packet. This condition is not caught by the interrupt handles in U-Boot, so no recovery is done, and the USB communication is stuck. To fix this, set the bit unconditionally, not only for CONFIG_USB_GADGET_DUALSPEED but also for host-only modes. Signed-off-by: Daniel Mack <zonque@gmail.com>
2014-10-06usb: tegra: ULPI regression on tegra20Marcel Ziswiler
Trying to enumerate USB devices connected via ULPI to T20 failed as follows: USB2: ULPI integrity check failed Git bisecting revealed the following commit being at odds: commit 2d34151f7501ddaa599897f0d89ad576126b03eb usb: tegra: refactor PHY type selection Looking at above commit one quickly identifies a copy paste error which this patch fixes. Happy ULPIing again (;-p). Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2014-10-06usb: gadget: fastboot: explicitly set radix of maximum download sizeEric Nelson
The processing of the max-download-size variable requires a radix specifier, or the fastboot host tool will interpret it as an octal number. See function get_target_sparse_limit() in file fastboot/fastboot.c in the AOSP: https://android.googlesource.com/platform/system/core/+/master Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06usb: gadget: fastboot: add max-download-size variableEric Nelson
Current Android Fastboot seems to use 'max-download-size' instead of 'downloadsize' variable to indicate the maximum size of sparse segments. See function get_target_sparse_limit() in file fastboot/fastboot.c in the AOSP: https://android.googlesource.com/platform/system/core/+/master Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06usb: ci_udc: respect CONFIG_USB_GADGET_DUALSPEEDEric Nelson
Force full-speed (12 Mbit/s) operation if CONFIG_USB_GADGET_DUALSPEED is not defined. The controller is capable of high-speed (480 Mbit/s) operation, but some designs may require the use of lower-speed operation. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06usb: gadget: fastboot: improve download progress barBo Shen
When download is ongoing, if the actual size of one transfer is not the same as BYTES_PER_DOT, which will cause the dot won't print anymore. Then it will let the user thinking it is stuck, actually it is transfering without dot printed. So, improve the method to show the progress bar (print dot). Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Marek Vasut <marex@denx.de>
2014-10-06usb: f_mass_storage: set removable flag in do_inquiry based on LUNEric Nelson
Without this flag, tools like Alex Page's USB Image Tool won't see drives exposed over USB Gadget as removable, and won't allow access to them. http://www.alexpage.de/usb-image-tool/ The code was pulled from the main-line kernel: drivers/usb/gadget/function/f_mass_storage.c Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2014-10-06usb: dfu: add fullspeed support for DFUHeiko Schocher
DFU now can use also fullspeed. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Liu Bin <b-liu@ti.com> Cc: Lukas Stockmann <lukas.stockmann@siemens.com>
2014-10-06usb: dfu: thor: gadget: Remove dead codeLukasz Majewski
This code is not used anymore in the current DFU implementation and can be safely removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-10-06usb: ehci: Make periodic_schedules a per controller variableHans de Goede
Periodic schedules tracks how many int_queue-s are active, and decides whether or not to en/disable the periodic schedule based on this. This is clearly a per controller thing. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-06usb: ehci: poll_int_queue check real qtd, not the overlayHans de Goede
When we first start an int queue, the qh's overlay area is all zeros. This gets filled by the hc with the actual qtd values as soon as it advances the queue, but we may call poll_int_queue before then, in which case we would think the transfer has completed as the hc has not yet copied the qt_token to the overlay, so the active flag is not set. This fixes this by checking the actual qtd token, rather then the overlay. This also fixes a (theoretical) race where we see the completion in the overlay and free and re-use the qtd before the hc has completed writing back the overlay to the actual qtd. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-06usb: ehci: Add missing cache flush to destroy_int_queueHans de Goede
2014-10-06usb: ehci: Properly set hub devnum and portnr with usb-1 hubs in the chainHans de Goede
For full / low speed devices we need to get the devnum and portnr of the tt, so of the first upstream usb-2 hub, not of the parent device (which may be a usb-1 hub). Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-29usb: ehci-mx6: Rename the USB register base addressYe.Li
The mx6sl/mx6sx has 2 OTG and 1 host. So they have name "USBO2H_USB_BASE_ADDR" in imx-regs.h. The driver hard codes the USB base address name to "USBOH3", which causes the driver failed to build for mx6sl/mx6sx. This patch uniform the address name to "USB_BASE_ADDR" for all mx6 series. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-29usb: ehci: mxs: Add board-specific callbacksMarek Vasut
Add board-specific callbacks for enabling/disabling port power into the MXS EHCI controller driver. This is in-line with the names of callbacks on other systems. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24usb/gadget: fastboot: minor cleanupSteve Rae
- update static function - additional debugging statements - update "fastboot command" information - add missing include file - update spelling Signed-off-by: Steve Rae <srae@broadcom.com>
2014-09-24usb/gadget: fastboot: add support for flash commandSteve Rae
- implement 'fastboot flash' for eMMC devices Signed-off-by: Steve Rae <srae@broadcom.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-09-19USB: ehci-atmel: use pcr to enable or disable clockBo Shen
If the SoC has pcr, we use pcr (peripheral control register) to enable or disable clock. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-09-19USB: ohci-at91: use pcr to enable or disable clockBo Shen
2014-09-16net: usb: Add SMSC copyright to smsc95xx driverSimon Glass
This driver was upstreamed without an SMSC copyright, even thought it seems that SMSC was the original author. See the kernel version for a code comparison: http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=2f7ca802bdae2ca41022618391c70c2876d92190 It's not clear who actually moved this code, or whether the kernel was the original source, or somewhere else, but it probably should still have the SMSC copyright. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-09-02USB: gadget: s3c: get rid of debug compile warningBo Shen
When enable debug option to compile, it will give the following warning, this patch is used to get rid of it. --->8--- warning: 'flags' is used uninitialized in this function [-Wuninitialized] ---8<--- Signed-off-by: Bo Shen <voice.shen@atmel.com>
2014-09-02USB: gadget: atmel: get rid of debug compile warningBo Shen
2014-09-02usb: ci_udc: implement dfu_usb_get_resetStephen Warren
This allows the USB code to determine whether a USB bus reset was issued, which in turn allows the code to differentiate between a detach (return to shell prompt) and a board reset/reboot request. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-09-02udc: dfu: s3c_udc: Provide function to check if USB reset was assertedLukasz Majewski
New dfu_usb_get_reset() method is necessary to distinct two different use cases of dfu-util program. This method checks if the USB bus reset has been really performed after DFU DETACH. Without this function the previous DFU behavior is preserved. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-09-02dfu: Provide means to find difference between dfu-util -e and -RLukasz Majewski
This commit provides distinction between DFU device detach and reset. The -R behavior is preserved with proper handling of the dfu-util's -e switch, which detach the DFU device. By running dfu-util -e; one can force device to finish the execution of dfu command on target and execute some other scripted commands. Moreover, some naming has been changed - the dfu_reset() method now is known as dfu_detach(). New name better reflects the purpose of the code. It was also necessary to increase the number of usb_gadget_handle_interrupts() calls since we also must wait for detection of the USB reset event. Example usage: 1. -e (detach) switch dfu-util -a0 -D file1.bin;dfu-util -a3 -D uImage;dfu-util -e access to u-boot prompt. 2. -R (reset) switch dfu-util -a0 -D file1.bin;dfu-util -R -a3 -D uImage target board reset Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2014-08-28Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-08-25lib, linux: move linux specific defines to linux/compat.hHeiko Schocher
- move linux specific defines from usb and video code into linux/compat.h - move common linux specific defines from include/ubi_uboot.h to linux/compat.h - add for new mtd/ubi/ubifs sync new needed linux specific defines to linux/compat.h Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from usb/lin_gadet_compat.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-21omap: remove omap5912osk board supportMasahiro Yamada
Emails to the board maintainer "Rishi Bhattacharya <rishi@ti.com>" have been bouncing. Tom suggested to remove this board. Remove also omap1510_udc.c because this is the last board to enable it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Tom Rini <trini@ti.com>
2014-08-09omap: clean-up dead configsMasahiro Yamada
The following configs are not defined at all. - CONFIG_OMAP1510 - CONFIG_OMAP_1510P1 - CONFIG_OMAP_SX1 - CONFIG_OMAP3_DMA - CONFIG_OMAP3_ZOOM2 - CONFIG_OMAP_INNOVATOR Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2014-08-09usb: ehci: rmobile: Remove xHCI addressNobuhiro Iwamatsu
echi-rmobile does not support xHCI. This removes xHCI address from address table. And this revise a value of CONFIG_USB_MAX_CONTROLLER_COUNT for lager board and koelsh board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-09usb: ehci: rmobile: Add support R8A7794Nobuhiro Iwamatsu
R8A7794 has same IP of USB controller as R8A7790 and R8A7791. This addes support for R8A7794. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-09dfu: allow backend to specify a maximum buffer sizeStephen Warren
CONFIG_SYS_DFU_DATA_BUF_SIZE may be large to allow for FAT/ext layouts to transfer large files. However, this means that individual write operations will take a long time. Allow backends to specify a maximum buffer size, so that each write operation is limited to a smaller data block. This prevents the DFU protocol from timing out when e.g. writing to SPI flash. I would guess that NAND might benefit from setting this value too, but I can't test that. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: add write error handlingStephen Warren
Fix calls to dfu_write() and dfu_flush() to detect errors in the I/O itself. This could happen due to problems with the storage medium, or simply when trying to write a FAT/ext file that is larger than the buffer dfu_mmc.c maintains for this purpose. Signal the error by switching the DFU state/status. This will be picked up by the DFU client when it sends the next DFU request. Note that errors can't simply be returned from e.g. dnload_request_complete(), since that function has no way to pass errors back to the DFU client; a call to dnload_request_complete() simply means that a USB OUT completed. This error state/status needs to be cleared when the next DFU client connects. While there is a DFU_CLRSTATUS request, no DFU client seems to send this. Hence, clear this when selecting the USB alternate setting on the USB interface. Finally, dfu.c relies on a call to dfu_flush() to clear up the internal state of the write transaction. Now that errors in dfu_write() are detected, dfu_flush() may no longer be called for every transaction. Separate out the cleanup code into a new function, and call it whenever dfu_write() fails, as well as from any call to dfu_flush(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-31sunxi: add USB EHCI driverRoman Byshko
The Allwinner aka sunxi SoCs have one or more USB host controllers. This adds a driver for their EHCI. Signed-off-by: Roman Byshko <rbyshko@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-22driver/usb: include upper/lower_32_bits() from linux/compat.hLijun Pan
upper_32_bits() and lower_32_bits() have been ported into linux/compat.h. Start use them now in drivers/usb/host/xhci.h. Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
2014-07-09usb: phy: omap_usb_phy: implement usb_phy_power() for AM437xFelipe Balbi
Newer AM437x silicon requires us to explicitly power up the USB2 PHY. By implementing usb_phy_power() we can achieve that. Signed-off-by: Felipe Balbi <balbi@ti.com>
