path: root/drivers/usb/ulpi
2018-02-05usb: ulpi: kconfig: Remove meaningless choice defaultUlf Magnusson
'default' on a choice refers to the symbol selected by default, not to the choice mode, so 'default n' is meaningless. No functional changes. Optional choices implicitly default to n mode (and there is no way to make them default to another mode). Discovered in Kconfiglib (https://github.com/ulfalizer/Kconfiglib), which prints the following warning: warning: the default selection n (undefined) of <choice> (defined at drivers/usb/ulpi/Kconfig:3) is not contained in the choice I've added a corresponding warning to the C tools too, which is currently in linux-next: https://patchwork.kernel.org/patch/9983667/ Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
2016-04-01usb: ulpi: Fix compile warning in read/write on 64-bit machines.Mateusz Kulikowski
ulpi_read and ulpi_write are used to read/write registers via ULPI bus. Code generates compilation warnings on 64-bit machines where pointer is cast to u32. This patch drops all but last 8 bits of register address. It is possible, because addresses on ULPI bus are 6- or 8-bit. It is not possible (according to ULPI 1.1 spec) to have more than 8-bit addressing. This patch should not cause regressions as all calls to ulpi_read/write use either structure pointer (@ address 0) or integer offsets cast to pointer - addresses requested are way below 8-bit range. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2016-04-01usb: ulpi: Add Kconfig options for ULPIMateusz Kulikowski
The following options can be now enabled via defconfig: - CONFIG_USB_ULPI - CONFIG_USB_ULPI_VIEWPORT - CONFIG_USB_ULPI_VIEWPORT_OMAP Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2013-10-31drivers: usb: convert makefiles to Kbuild styleMasahiro Yamada
2013-07-02usb: omap: ulpi: fix ulpi transceiver accessMichael Trimarchi
This patch fix the omap access to the transceiver configuration registers using the ulpi bus. As reported by the documentation the bit31 is used only to check if the transaction is done or still running and the reading and writing operation have different offset and have different values. What we need to do at the end of a transaction is leave the bus in done state. Anyway an error using the ulpi omap register is not recoverable so any error give out the usage of this interface. Tested on a custom OMAP5430 board with a TUSB1210 ULPI PHY on USBB1. Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2012-10-15usb: ulpi: add indicator configuration functionLucas Stach
Allows for easy configuration of the VBUS indicator related ULPI config bits. Also move the external indicator setup from ulpi_set_vbus() to the new function. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12usb: ulpi: Extend the existing ulpi framework.Govindraj.R
Extend the existing ulpi viewport framework to pass the port number information for any ulpi ops. Fix the usage of ulpi api's accordingly. Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2011-12-16USB: ULPI: increase error case verbosityIgor Grinberg
Add the argument value to the error message. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-16USB: ULPI: clean a mixup of return typesIgor Grinberg
Clean a mixup between u32 and int as a return type for functions returning error values. Use int as it is native (and widely used) return type. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-16USB: ULPI: switch argument type from u8 to unsignedIgor Grinberg
There is no benefit in using u8, so switch to unsigned to reduce the binary image size (by 20 bytes). Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-11USB: Add generic ULPI layer and a viewportJana Rapava
Add partial ULPI specification implementation that should be enough to interface the ULPI PHYs in the boot loader context. Add a viewport implementation for Chipidea/ARC based controllers. Signed-off-by: Jana Rapava <fermata7@gmail.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Remy Bohmer <linux@bohmer.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Simon Glass <sjg@chromium.org>
