path: root/drivers/usb/phy
2016-06-02usb: phy: omap_usb_phy: Fix USB3_PHY DPLL configurationRoger Quadros
The index returned by get_sys_clk_index() is not exactly what we expect. Let's not rely on that and use get_sys_clk_freq() instead. This fixes missing USB3 devices in the Linux kernel when USB is started in u-boot. It still doesn't fix missing USB3 devices in u-boot though. Signed-off-by: Roger Quadros <rogerq@ti.com>
2015-07-22usb: xhci: omap: Remove common dwc3 drv functions callsRamneek Mehresh
Remove all redundant dwc3 driver function calls that are defined by dwc3 driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-04-16ti: dwc3: Enable clocks in enable_basic_clocks() in hw_data.cKishon Vijay Abraham I
Commit d3cfcb3 (ARM: DRA7: Enable clocks for USB OTGSS and USB PHY) changed the member names of prcm_regs from cm_l3init_usb_otg_ss_clkctrl to cm_l3init_usb_otg_ss1_clkctrl and from cm_coreaon_usb_phy_core_clkctrl to cm_coreaon_usb_phy1_core_clkctrl in order to differentiate between the two dwc3 controllers present in dra7xx/am43xx and enabled these clocks in enable_basic_clocks() in hw_data.c. However these clocks continued to be enabled in board files/driver files for dwc3 host mode functionality causing compilation break with few configs. Fixed it here by making all the clocks enabled in enable_basic_clocks() and removing it from board files/driver files here. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-12-04usb: phy: omap_usb_phy: fix build breakageFelipe Balbi
there's no such function usb3_phy_power(), it's likely that author meant to call, usb_phy_power() instead, but that's already called properly from xhci-omap.c. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-09usb: phy: omap_usb_phy: implement usb_phy_power() for AM437xFelipe Balbi
Newer AM437x silicon requires us to explicitly power up the USB2 PHY. By implementing usb_phy_power() we can achieve that. Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-10-31drivers: usb: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-20usb: am437x: Add support for am437x xhci USB hostDan Murphy
Add the support for the am437x xhci usb host. The xHCI host on AM437 is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: dra7xx: Add support for dra7xx xhci USB hostDan Murphy
Add the support for the dra7xx xhci usb host. dra7xx does not contain an EHCI controller so the headers can be removed from the board file. The xHCI host on dra7xx is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: omap: Move the usb phy code to the usb/phy directoryDan Murphy
Moving the usb/phy code from xhci-omap to the usb/phy directory and moving the associated phy code over to the new file. Newer TI processors adding xHCI support will have different PHY configurations so therefore abstracting this code away will prevent messing around with the xhci-omap file itself. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-05-10twl4030: make twl4030_i2c_read_u8 prototype consistentNishanth Menon
u-boot standard i2c read prototype is i2c_read(addr, reg, 1, &buf, 1) twl4030_i2c_read_u8(u8 addr, u8 *val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_read_u8(u8 addr, u8 reg, u8 *val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-05-10twl4030: make twl4030_i2c_write_u8 prototype consistentNishanth Menon
u-boot standard i2c register write prototype is i2c_reg_write(u8 addr, u8 reg, u8 val) twl4030_i2c_write_u8(u8 addr, u8 val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_write_u8(u8 addr, u8 reg, u8 val) Signed-off-by: Nishanth Menon <nm@ti.com>
2010-05-06drivers/*/Makefile: fix conditional compile rule.Ender.Dai
Fix conditional compile rule for twl4030.c and videomodes.c. Signed-off-by: Ender.Dai <ender.dai@gmail.com>
2009-12-20TWL4030 Add usb PHY supportTom Rix
The twl4030 provides a PHY device for connecting a link device, like musb, to physical connection. This change adds the twl4030 usb registers and functions for initializing the PHY as required by omap3. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
