* add's a warning to all files, which need update to new SoC access
* convert common files in cpu/../at91 and a lot of drivers to use
c stucture SoC access
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Currently ppc440epx uses OHCI for USB full-speed support. This change adds
support for EHCI.
Signed-off-by: Chris Zhang <chris@seamicro.com>
In USB ehci driver, the port reset is not terminated. EHCI spec says "A host
controller must terminate the reset and stabilize the state of the port within
2 milliseconds". Without termination, a port stays at reset state. This is
observed on ppc4xx(sequoia) boards.
The header files usb.h and usbdescriptors.h have the same nameed
structure definitions for
usb_config_descriptor
usb_interface_descriptor
usb_endpoint_descriptor
usb_device_descriptor
usb_string_descriptor
These are out right duplicates in usb.h
This one has extra unused elements
unsigned char bRefresh
unsigned char bSynchAddress;
These in usb.h have extra elements at the end of the usb 2.0
specified descriptor and are used.
The change is to consolidate the definition of the descriptors
to usbdescriptors.h. The dublicates in usb.h are removed.
The extra element structure will have their name shorted by
removing the '_descriptor' suffix.
So
usb_config_descriptor -> usb_config
usb_interface_descriptor -> usb_interface
For these, the common descriptor elements are accessed now
by an element 'desc'.
As an example
- if (iface->bInterfaceClass != USB_CLASS_HUB)
+ if (iface->desc.bInterfaceClass != USB_CLASS_HUB)
This has been compile tested on MAKEALL arm, ppc and mips.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This patch adds a unified s3c24x0 cpu header file that selects the header
file for the specific s3c24x0 cpu from the SOC and CPU configs defined in
board config file. This removes the current chain of s3c24-type #ifdef's
from the s3c24x0 code.
Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk>
This patch moves the s3c64xx header files from include/
to include/asm-arm/arch-s3c64xx
This change is cheked in Linux source and fix found to be in sync.
This patch is tested for USB host interface on Kirkwood based
Sheevaplug platform (ARM little endian board)
Risk: the impact of this patch is not validated on big endian board.
This need to be checked...
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
ehci-hcd.c: In function 'ehci_submit_root':
ehci-hcd.c:719: warning: value computed is not used
ehci-hcd.c:748: warning: value computed is not used
This driver is tested on Sheevaplug platform
This patch fixes the access to the 'ehci' struct elements which should
have been taken care off in 4ef01010aa4799c759d75e67007fdd3a38c88c8a
Sorry about that.
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
The following patch reorganizes/reworks the USB support for mpc83xx
as under:-
* Moves the 83xx USB clock init from drivers/usb/host/ehci-fsl.c to
cpu/mpx83xx/cpu_init.c
* Board specific usb_phy_type is read from the environment
* Adds USB EHCI specific structure in include/usb/ehci-fsl.h
* Copyrights revamped in most of the following files
The following patch moves 8xxx-specifc USB #defines from
drivers/usb/host/ehci-fsl.h to include/usb.
To prepare for the 85xx USB support, which requires interface enablement
only once in (specified) order, no different than instructions for
enabling the interface under 83xx. It is unknown why the original author
enabled the interface twice (checked for references in errata, etc).
This patch corrects the missing PLLB initialization in usb_cpu_init()
for AT91SAM9261.
Because of the missing PLLB initialization, the USB support for all
AT91SAM9261 based boards will work only if the PLLB is configured by a
precedent bootloader.
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
__attribute__ follows gcc's documented syntax and is generally more
common than __attribute. This change is only asthetic and should not
affect functionality.
calculate dynamically the clock rate and pllb setting for usb
move to linux usb driver organisation
as following
drivers/usb/gadget
drivers/usb/host
drivers/usb/musb
