This driver does not use DM, so use log_xxx instead.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Tested-by: Patrick Delaunay <patrick.delaunay@st.com>
Move this uncommon header out of the common header.
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
At present devres.h is included in all files that include dm.h but few
make use of it. Also this pulls in linux/compat which adds several more
headers. Drop the automatic inclusion and require files to include devres
themselves. This provides a good indication of which files use devres.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
The BITMAP related operations can now be moved to ./include/linux/bitmap.h
file to mimic the Linux kernel directory tree.
This change also allows to remove the lin_gadget_compat.h header file
(which is a legacy code only for composite U-boot layer).
It was also possible to remove #includes from several USB gadget drivers.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
devm_zalloc() is already defined in dm/device.h header, so
devm_zalloc can be removed from linux_compact.h beader file.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_AM57XX is just an unnecessary macro that is redundant given So,
remove the same instead of spreading through out the u-boot source
code and getting in the way to maintain common code for DRA7x family.
Acked-by: Andrew F. Davis <afd@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Added support to power on/power off the second USB PHY present in
DRA7xx and AM57xx.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Added a single driver for both USB2 PHY programming and USB3 PHY
programming.
USB3 PHY is taken from drivers/phy/phy-ti-pipe3.c in linux kernel.
commit 56042e : phy: ti-pipe3: Fix suspend/resume and module reload.
USB2 PHY is taken from drivers/phy/phy-omap-usb2.c in linux kernel.
commit eb82a3 : phy: omap-usb2: Balance pm_runtime_enable() on probe
failure and remove.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
