path: root/drivers/usb/dwc3/core.h
2018-11-26usb: s/CONFIG_DM_USB/CONFIG_IS_ENABLED(DM_USB)/Sven Schwermer
This allows to disable the USB driver model in SPL because it checks the CONFIG_SPL_DM_USB variable for SPL builds. Nothing changes for regular non-SPL builds. Signed-off-by: Sven Schwermer <sven@svenschwermer.de>
2018-05-18usb: dwc3: Add dwc3_init/remove with DM_USBMugunthan V N
The patch is preparing dwc3 core for enabling DM_USB with peripheral driver with using driver model support. The driver will be bound by the DWC3 wrapper driver based on the dr_mode device tree entry. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> (Remove dwc3-omap changes) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-14usb: dwc3: make dwc3_set_mode to staticJoonyoung Shim
This commit makes the dwc3_set_mode() as static, to prevent collisions. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: Remove BIT(x) macro from DWC3's gadget codeLukasz Majewski
The BIT() macro is used only in those places, so it is reasonable to replace it by a constant value. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14dwc3: core: add support for multiple dwc3 controllersKishon Vijay Abraham I
Added support for multiple dwc3 controllers. This gives uboot the capability to control multiple dwc3 controllers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: core: make dwc3 core build in ubootKishon Vijay Abraham I
*) Changed the include header files to that used in u-boot. *) Removed phy_* APIs *) Removed jiffies and used a simple while loop *) Used dma_alloc_coherent and dma_free_coherent APIs of u-boot *) Fixed other misc warnings Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: ep0: make dwc3 ep0 build in ubootKishon Vijay Abraham I
*) Changed the included header files to that used in u-boot. *) added dwc3_ep_event_string() used in ep0.c *) Fixed other misc warnings Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: remove pm related operations from dwc3 driverKishon Vijay Abraham I
Removed all pm related operations including pm_runtime APIs, suspend/resume hooks as support for these are not present in u-boot. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: fix dwc3 header filesKishon Vijay Abraham I
Changed the header files included in core.h and io.h to the u-boot header files so that these files can be included in other dwc3 source files and be compiled in uboot. Also added otg.h which has the defines for dr_mode. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: Modify the file headers to u-boot formatKishon Vijay Abraham I
Modified the file header to the format that is used in u-boot. Also included in the header, the commit in linux kernel from which each of these files are added. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: add dwc3 folder from linux kernel to u-bootKishon Vijay Abraham I
Added dwc3 folder from linux kernel 3.19-rc1 (97bf6af1f9) to u-boot. This will be adapted to work with u-boot in the following patches. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
