path: root/drivers/usb/common
2020-05-29usb: dwc3: amend UTMI/UTMIW phy interface setupFrank Wang
Let move 8/16-bit UTMI+ interface initialization into DWC3 core init that is convenient for both DM_USB and u-boot traditional process. Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-03-30usb: Migrate to support live DT for some driverKever Yang
Use ofnode_ instead of fdt_ APIs so that the drivers can support live DT. This patch updates usb_get_dr_mode() and usb_get_maximum_speed() to use ofnode as parameter instead of fdt offset. And all the drivers who use these APIs update to use live dt APIs at the same time. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2018-11-26usb: Introduce CONFIG_SPL_DM_USBSven Schwermer
This allows building the SPL without driver model for USB. Since CONFIG_SPL_DM_USB is enabled if and only if CONFIG_DM_USB was enabled before, this patch does not change the build behaviour. Signed-off-by: Sven Schwermer <sven@svenschwermer.de>
2018-10-29fsl/usb: Workaround for USB erratum-A005275Chris Packham
Workaround makes FS as default mode on all affected socs. Add support to check erratum-A005275 validity for an soc. This info is required to determine whether a given soc is affected by this erratum. Add quirk for this erratum "has_fsl_erratum_a005275" . This quirk is used to enable workaround for the errata Force FS mode as default by: - making EPS as FS - setting PFSC bit to disable HS chirping This workaround can be disabled by mentioning "no_erratum_a005275" in hwconfig string Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-10-28drivers: cosmetic: Convert SPDX license tags to Linux Kernel stylePatrick Delaunay
Complete in the drivers directory the work started with commit 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style"). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-05-18usb: common: add support to get maximum speed from dtMugunthan V N
Add support to get maximum speed from dt so that usb drivers makes use of it for DT parsing. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> (rebase and fix errors) Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-13armv8: ls1043a/ls2080a: check SoC by device IDWenbin song
Check LS1043A/LS2080a by device ID without using personality ID to determine revision number. This check applies to all various personalities of the same SoC family. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-01fsl/usb: enable errata-a010151 for ls2088a and ls2081aSantan Kumar
Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-05common: arm: freescale: layerscape: Move header files out of common.hSimon Glass
We should not have an arch-specific header file in common.h. Adjust the board files a little so it is not needed, and drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05common: freescale: Move arch-specific declarationsSimon Glass
The declarations should not be in common.h. Move them to the arch-specific headers. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup thinko defined(FSL_LSCH3) -> defined(CONFIG_FSL_LSCH3)] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-17armv7: ls1021a: Drop macro CONFIG_LS102XAYork Sun
Use CONFIG_ARCH_LS1021A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-05fsl/usb: enable the errata-a005697 for ls1012ajerry.huang@nxp.com
Enable the errata-a005697 for ls1012a Signed-off-by: Changming Huang <jerry.huang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-30Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/dra7xx_evm.h
2016-09-28mpc85xx: powerpc: usb: Update the list of Socs afftected by erratum A006261Sriram Dash
Apply the erratum A006261 for the following Socs: P2041 rev 2.0, P2040 rev 2.0, P5040 rev 2.0, 2.1 Do not apply erratum A006261 for the following Socs: T4160, T4080, T1040, T1042, T1020, T1022, T2080, T2081 Erratum A006261 is applicable for the following Socs: P1010(1.0, 2.0), P2041(1.0, 1.1, 2.0, 2.1), P2040(1.0, 1.1, 2.0, 2.1), P3041(1.0, 1.1, 2.0, 2.1), P5010(1.0, 2.0), P5020(1.0, 2.0), P5021(1.0, 2.0), T4240(1.0, 2.0), P5040(1.0,2.0,2.1). Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-27drivers: usb: xhci-fsl: Implement Erratum A-010151 for FSL USB3 controllerSriram Dash
Currently the controller by default enables the Receive Detect feature in P3 mode in USB 3.0 PHY. However, USB 3.0 PHY does not reliably support receive detection in P3 mode. Enabling the USB3 controller to configure USB in P2 mode whenever the Receive Detect feature is required. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-09-27usb: fsl: Renaming fdt_fixup_erratum and fdt_fixup_usb_erratumSriram Dash
The functions fdt_fixup_erratum and fdt_fixup_usb_erratum are fsl/nxp specific. So, make them explicit by renaming them fsl_fdt_fixup_erratum and fsl_fdt_fixup_usb_erratum Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-06-28armv8: fsl-layerscape: Append "A" in SoC name for ARM based SoCsPrabhakar Kushwaha
Freescale ARMv8 SoC name ends with "A" to represent ARM SoCs. like LS2080A, LS1043A, LS1012A. So append "A" to SoC names. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-13usb: xhci: fsl: Add workaround for USB erratum A008751Sriram Dash
This patch is doing the following: 1. Implementing the errata for LS2080. 2. Adding fixup for fdt for LS2080. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-13fsl: usb: make errata function common for PPC and ARMSriram Dash
This patch does the following things: 1. Makes the errata checking code common for PPC and ARM 2. Moves all these static inline functions into a dedicated C file Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-13usb: xhci: fsl: code cleanup for device tree fixup for fsl usb controllersSriram Dash
Performs code cleanup for device tree fixup for fsl usb controllers by making functions to handle these similar errata checking code. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-05-17drivers: usb: common: add common code for usb drivers to useMugunthan V N
Add common usb code which usb drivers makes use of it. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-10drivers:usb:common:fsl-dt-fixup: fix return value of fdt_usb_get_node_typeSriram Dash
Changes the return type of fdt_usb_get_node_type from char* to int Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-04-10drivers:usb:common:fsl-dt-fixup: Add device-tree fixup support for xhci ↵Sriram Dash
controller Enables usb device-tree fixup code to incorporate xhci controller Signed-off-by: Ramneek Mehresh <ramneek.mehresh@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-04-10drivers:usb:common:fsl-dt-fixup: Remove code duplication for ↵Sriram Dash
fdt_usb_get_node_type Call fdt_usb_get_node_type() from fdt_fixup_usb_mode_phy_type() to avoid code duplication. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Acked-by: Marek Vasut <marex@denx.de>
2016-04-10drivers:usb:common:fsl-dt-fixup: Move device-tree fixup framework to common fileSriram Dash
Move usb device-tree fixup framework from ehci-fsl.c to common place so that it can be used by other drivers as well (xhci-fsl.c). Signed-off-by: Ramneek Mehresh <ramneek.mehresh@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Acked-by: Marek Vasut <marex@denx.de>
