path: root/drivers/usb/Kconfig
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01usb: ulpi: Add Kconfig options for ULPIMateusz Kulikowski
The following options can be now enabled via defconfig: - CONFIG_USB_ULPI - CONFIG_USB_ULPI_VIEWPORT - CONFIG_USB_ULPI_VIEWPORT_OMAP Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: Kconfig support for USB_MUSB_HOST and USB_MUSB_GADGETPaul Kocialkowski
Having MUSB_HOST and MUSB_GADGET in Kconfig allows more flexibility with regard to what Kconfig options to enable, such as USB_STORAGE or USB_KEYBOARD. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-08-05usb: Generic USB Kconfig option, that fits both host and gadget and commentsPaul Kocialkowski
There is no particular reason why the USB Kconfig option should be specific to host mode. In prevision of adding MUSB host and gadget to Kconfig, this moves the title and help message of the USB Kconfig option to a more generic format. Adding comments to the usb Kconfig allows for a better separation and more readability in generated configs and in menuconfig. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-08-05usb: USB_ARCH_HAS_HCD Kconfig option removalPaul Kocialkowski
The USB_ARCH_HAS_HCD currently serves no purpose and adds some confusion to the required Kconfig options that are required to have USB support. Dropping it makes things easier and doesn't break anything, since it was unused anyways. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-08-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-08-02usb: kconfig: create a menu for usbNikita Kiryanov
With recent additions to USB Kconfig the number of USB options had grown large enough to warrant a separate menu for USB. Add a Kconfig menu for USB. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-08-02usb: kconfig: usb keyboard kconfigNikita Kiryanov
Add Kconfig options for USB keyboard and use them for cm-fx6. Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-07-21dm: usb: Adjust the USB_DEVICE() macro namingSimon Glass
In Linux USB_DEVICE() is used to declare a USB device by vendor/device ID. We should follow the same convention in U-Boot. Rename the existing USB_DEVICE() macro to U_BOOT_USB_DEVICE() and bring in the USB_DEVICE() macro from Linux for use in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: sandbox: Add a uclass for USB device emulationSimon Glass
With sandbox we want to be able to emulate USB devices so that we can test the USB stack. Add a uclass to support this. It implements the same operations as a normal USB device driver, but in this case passes them on to an emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Add a uclass for USB controllersSimon Glass
Add a uclass that can represent a USB controller. For now we do not create devices for things attached to the controller. This will be added later. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2014-11-12usb: add basic USB configs in KconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
