path: root/drivers/ufs/ufs.c
2020-02-19dma-mapping: move dma_map_(un)single() to <linux/dma-mapping.h>Masahiro Yamada
The implementation of dma_map_single() and dma_unmap_single() is exactly the same for all the architectures that support them. Factor them out to <linux/dma-mapping.h>, and make all drivers to include <linux/dma-mapping.h> instead of <asm/dma-mapping.h>. If we need to differentiate them for some architectures, we can move the generic definitions to <asm-generic/dma-mapping.h>. Add some comments to the helpers. The concept is quite similar to the DMA-API of Linux kernel. Drivers are agnostic about what is going on behind the scene. Just call dma_map_single() before the DMA, and dma_unmap_single() after it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Require users of devres to include the headerSimon Glass
At present devres.h is included in all files that include dm.h but few make use of it. Also this pulls in linux/compat which adds several more headers. Drop the automatic inclusion and require files to include devres themselves. This provides a good indication of which files use devres. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-10-23ufs: Add Initial Support for UFS subsystemFaiz Abbas
Add Support for UFS Host Controller Interface (UFSHCI) for communicating with Universal Flash Storage (UFS) devices. The steps to initialize the host controller interface are the following: - Initiate the Host Controller Initialization process by writing to the Host controller enable register. - Configure the Host Controller base address registers by allocating a host memory space and related data structures. - Unipro link startup procedure - Check for connected device - Configure UFS host controller to process requests Also register this host controller as a SCSI host controller. Taken from Linux Kernel v5.2 (drivers/scsi/ufs/ufshcd.c) and ported to U-boot. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
