path: root/drivers/tpm/sandbox_common.c
2021-08-01sandbox: tpm: Support the define-space commandSimon Glass
Add support for this command, moving away from the previous approach of hard-coding the initial data in the driver, now that the kernel-space data has to be set up by the higher-level vboot code. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-08-01sandbox: tpm: Split out common nvdata codeSimon Glass
We want to support nvdata in TPM2 as well. To avoid code duplicating the associated code, move it into a common file. Drop the special-case logic for the kernel space. This can be handled by the higher-level code now, i.e. in vboot itself. Signed-off-by: Simon Glass <sjg@chromium.org>
