path: root/drivers/timer/cadence-ttc.c
2018-11-14timer: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-15timer: cadence: Implement timer_get_boot_usMichal Simek
This function is required for adding bootstage support. Also enable it directly for ZynqMP R5 configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-31timer: cadence: Use live-tree functionsMichal Simek
Use live-tree functions. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-11timer: Add Cadence TTC timer counter supportMichal Simek
This driver was tested on Xilinx ZynqMP SoC. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
