path: root/drivers/tigon3.h
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-06-07cosmetic changes to bcm570x driverVadim Bendebury
This is a cosmetic only changes submission. It affects files relevant to bcm570x driver. the commands used to generate this change was cd drivers Lindent -pcs -l80 bcm570x.c bcm570x_lm.h bcm570x_mm.h tigon3.c tigon3.h The BMW target (the only one using this chip so far) builds cleanly, the `before and after' generated object files for drivers/bcm570x.c and drivers/tigon3.o are identical as reported by objdump -d Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
