path: root/drivers/tigon3.c
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-08-13Sync'd u-boot-net with mainlineBen Warren
Merge git://www.denx.de/git/u-boot Conflicts: drivers/bcm570x.c drivers/tigon3.c
2007-07-10drivers/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09drivers/[n-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04drivers/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-07cosmetic changes to bcm570x driverVadim Bendebury
This is a cosmetic only changes submission. It affects files relevant to bcm570x driver. the commands used to generate this change was cd drivers Lindent -pcs -l80 bcm570x.c bcm570x_lm.h bcm570x_mm.h tigon3.c tigon3.h The BMW target (the only one using this chip so far) builds cleanly, the `before and after' generated object files for drivers/bcm570x.c and drivers/tigon3.o are identical as reported by objdump -d Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
