It should return -EINPROGRESS if successful otherwise sysreset-uclass
will continue to the next sysreset device.
Signed-off-by: Jonathan Liu <net147@gmail.com>
This converts 2 usages of this option to the non-SPL form, since there is
no SPL_DISPLAY_AER_BRIEF defined in Kconfig
The SPL_TPL part is in the wrong place. Fix it.
Fixes: 71d4393f846 ("sysreset: Add Atmel/Microchip sysreset driver")
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Add support for at91 reset controller's basic assert/deassert
operations. Since this driver conflicts with the
SYSRESET driver because they both bind to the same RSTC node,
implement a custom bind hook that would manually bind the
sysreset driver, if enabled, to the same RSTC DT node.
Furthermore, delete the no longer needed compatibles from the
SYSRESET driver and rename it to make sure than any possible
conflicts are avoided.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
Tested-by: Mihai Sain <mihai.sain@microchip.com>
As documented in bindings doc in kernel 6.0:
https://elixir.bootlin.com/linux/v6.0/source/Documentation/devicetree/bindings/reset/atmel,at91sam9260-reset.yaml
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
There is a number of users that use uclass_first_device to access the
first and (assumed) only device in uclass.
Some check the return value of uclass_first_device and also that a
device was returned which is exactly what uclass_first_device_err does.
Some are not checking that a device was returned and can potentially
crash if no device exists in the uclass. Finally there is one that
returns NULL on error either way.
Convert all of these to use uclass_first_device_err instead, the return
value will be removed from uclass_first_device in a later patch.
Signed-off-by: Michal Suchanek <msuchanek@suse.de>
System reset via the SRST extension in the SBI should be the default.
The driver checks if the extension is available when probing.
So there is no risk in enabling it.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
This driver is a child of the rstmgr driver, both of which share the
same devicetree node. As a result, passing the child's udevice pointer
to dev_read_addr_ptr results in a failure of reading the #address-cells
property. Use the parent udevice pointer instead.
Signed-off-by: Paweł Anikiel <pan@semihalf.com>
Add VPL versions of commonly used Kconfig options.
This patch adds a sysreset driver for Atmel/Microchip platforms.
https://source.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2022.04-rc1
gpio:
- Add modepin driver
net:
- Save random mac addresses to eth variable
zynqmp gem:
- Add support for mdio bus DT description
- Add support for reset and SGMII phy configuration
- Reduce timeout for MDIO accesses
zynqmp clk:
- Fix clock handling for gem and usb
phy:
- Add zynqmp phy/serdes driver
serial:
- Add one missing compatible string
microblaze:
- Symbol alignement
- SPL fixups
- Code cleanups
zynqmp:
- Various dt changes, DP pre-reloc, gem resets, gem clocks
- Switch SOM to shared psu configuration
- Move dcache handling to firmware driver
- Workaround gmii2rgmii DT description issue
- Enable broadcasts again
- Change firmware enablement logic
- Small adjustement in firmware driver
versal:
- Support new mmc@ DT nodes
- Fix run time variable handling
- Add missing I2C_PMC ID for power domain
Current code assumes that the vector base address is always at 0x0.
However, this value is configurable for MicroBlaze using the
CONFIG_XILINX_MICROBLAZE0_VECTOR_BASE_ADDR Kconfig option. Update the
reset routines to branch to this location instead.
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
Link: https://lore.kernel.org/r/20211130163358.2531677-10-ovidiu.panait@windriver.com
The watchdog system reset driver can reboot the device but it cannot power
it off. If power off is requested, the driver should not reset the system
but leave powering off to one of the other system reset drivers.
As power cycling is typically not a feature of a watchdog driver the reset
types SYSRESET_POWER and SYSRESET_POWER_OFF shall both be excluded.
Fixes: 17a0c14164dc ("dm: sysreset: add watchdog-reboot driver")
Add an option to automatically register watchdog devices with the
wdt_reboot driver for use with sysreset. This allows sysreset to be a
drop-in replacement for platform-specific watchdog reset code, without
needing any device tree changes.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Currently, the wdt_reboot driver always gets its watchdog device
reference from an OF node. This prevents selecting a watchdog at
runtime. Move the watchdog device reference to the plat data, so
the driver can be bound with the reference pre-provided. The
reference will still be acquired from the OF node if it is not
already provided.
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
These driver probe functions are not (and should not be) called from
outside the respective driver source files. Therefore, the functions
should be marked static.
None of the sysreset drivers do anything beyond providing sysreset
uclass ops. They should depend on the sysreset uclass.
Provide sysreset driver using the SBI system reset extension.
Reviewed-by: Sean Anderson <seanga2@gmail.com>
Tested-by: Samuel Holland <samuel@sholland.org>
Now that we have a 'positive' Kconfig option, use this instead of the
negative one, which is harder to understand.
Add additional param for reset cmd, which provides type of reset.
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Use psci driver exported functions for reset/poweroff, instead of
invoking directly invoke_psci_fn.
Prepare v2021.04-rc4
Create common macro TARGET_SOCFPGA_SOC64 for Stratix10 and Agilex.
Signed-off-by: Siew Chin Lim <elly.siew.chin.lim@intel.com>
sysreset uclass driver provides an implementation of 'reset'
command using the sysreset_ APIs unconditionally. It also
supports the 'poweroff' command using the sysreset_ APIs,
but under a Kconfig option CONFIG_SYSRESET_CMD_POWEROFF.
Let's do the same for the 'reset' command, by introducing a
new Kconfig option CONFIG_SYSRESET_CMD_RESET, and set it to
on by default, to allow a board that don't have a sysreset
reset driver yet, but have a sysreset poweroff driver to
compile without any issue.
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Historically, the reset_cpu() function had an `addr` parameter which was
meant to pass in an address of the reset vector location, where the CPU
should reset to. This feature is no longer used anywhere in U-Boot as
all reset_cpu() implementations now ignore the passed value. Generic
code has been added which always calls reset_cpu() with `0` which means
this feature can no longer be used easily anyway.
Over time, many implementations seem to have "misunderstood" the
existence of this parameter as a way to customize/parameterize the reset
(e.g. COLD vs WARM resets). As this is not properly supported, the
code will almost always not do what it is intended to (because all
call-sites just call reset_cpu() with 0).
To avoid confusion and to clean up the codebase from unused left-overs
of the past, remove the `addr` parameter entirely. Code which intends
to support different kinds of resets should be rewritten as a sysreset
driver instead.
This transformation was done with the following coccinelle patch:
expression argvalue;
- reset_cpu(argvalue)
+ reset_cpu()
identifier argname;
type argtype;
- reset_cpu(argtype argname)
+ reset_cpu(void)
Signed-off-by: Harald Seiler <hws@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Add low level platform initialization for the AST2600 SoC.
The 2-stage booting with U-Boot SPL are leveraged to support
different booting mode.
However, currently the patch supports only the booting from
memory-mapped SPI flash.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Reviewed-by: Ryan Chen <ryan_chen@aspeedtech.com>
Driver model: make some udevice fields private
Driver model: Rename U_BOOT_DEVICE et al.
dtoc: Tidy up and add more tests
ns16550 code clean-up
x86 and sandbox minor fixes for of-platdata
dtoc prepration for adding build-time instantiation
Prepare v2021.01-rc5
The current macro is a misnomer since it does not declare a device
directly. Instead, it declares driver_info record which U-Boot uses at
runtime to create a device.
The distinction seems somewhat minor most of the time, but is becomes
quite confusing when we actually want to declare a device, with
of-platdata. We are left trying to distinguish between a device which
isn't actually device, and a device that is (perhaps an 'instance'?)
It seems better to rename this macro to describe what it actually is. The
macros is not widely used, since boards should use devicetree to declare
devices.
Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is
declaring a new driver_info record, not a device.
We have two functions which do the same thing. Standardise on
dev_has_ofnode() since there is no such thing as an 'invalid' ofnode in
normal operation: it is either null or missing.
Also move the functions into one place.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
With the new of-platdata, these need to be available to dt_platdata.c
so must be in header files. Move them and add the dtd struct too.
Use a minimal error message to save space. Sort the header files while we
are here.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
Rename this to be consistent with the change from 'platdata'.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
Update Patrick and my email address with the one dedicated to
upstream activities.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
patman status subcommand to collect tags from Patchwork
patman showing email replies from Patchwork
sandbox poweroff command
minor fixes in binman, tests
- Add a new SMBIOS parser and enable it when booting from coreboot
- Fix up various driver names to avoid dtoc warnings
- Fully enable ACPI support on Google Chromebook Coral
- Add a way to set SMBIOS properties using the devicetree
- Update existing boards to use devicetree for SMBIOS using a new
default sysinfo driver
Up to now the sandbox would shutdown upon a cold reset request. Instead it
should be reset.
In our coding we use static variables like LIST_HEAD(efi_obj_list). A reset
can occur at any time, e.g. via an UEFI binary calling the reset service.
The only safe way to return to an initial state is to relaunch the U-Boot
binary.
The reset implementation uses execv() to relaunch U-Boot.
At present there are a lot of dtoc warnings reported when building
chromebook_coral, of the form:
WARNING: the driver intel_apl_lpc was not found in the driver list
Correct these by using driver names that matches their compatible string.
Add GPIO poweroff driver, which is based on the Linux
driver and uses the same DT binding.
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Since sandbox's SPL is build with of-platadata, we should not use
U_BOOT_DEVICE() declarations as well. Drop them.
CONFIG_IS_ENABLED() takes the kconfig name without the CONFIG_ prefix,
e.g. CONFIG_IS_ENABLED(CLK) for CONFIG_CLK. Some of these were being
fixed every now and then, see:
commit 71ba2cb0d678 ("board: stm32mp1: correct CONFIG_IS_ENABLED usage for LED")
commit a5ada25e4213 ("rockchip: clk: fix wrong CONFIG_IS_ENABLED handling")
commit 5daf6e56d36c ("common: console: Fix duplicated CONFIG in silent env callback")
commit 48bfc31b6484 ("MIPS: bootm: Fix broken boot_env_legacy codepath")
Fix all files found by `git grep "CONFIG_IS_ENABLED(CONFIG"` by running
':%s/CONFIG_IS_ENABLED(CONFIG_\(\w+\))/CONFIG_IS_ENABLED(\1)/g' in vim.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Enable sysreset support for Agilex platform.
Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Rename the driver from S10 to SoC64 because Intel Agilex platform
also using the this SYSRESET SoCFPGA driver for S10.
The rst variable doesn't exist.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Tested-by: Patrick Delaunay <patrick.delaunay@st.com>
When you enable CONFIG_OF_LIVE, you will end up with a lot of
conversions.
To help this tedious work, this commit converts devfdt_get_addr_ptr()
to dev_read_addr_ptr() by coccinelle. I also removed redundant casts
because dev_read_addr_ptr() returns an opaque pointer.
To generate this commit, I ran the following semantic patch
excluding include/dm/.
<smpl>
type T;
expression dev;
-(T *)devfdt_get_addr_ptr(dev)
+dev_read_addr_ptr(dev)
expression dev;
-devfdt_get_addr_ptr(dev)
</smpl>
