path: root/drivers/sysreset
2019-05-10sysreset: select DM_GPIO instead of GPIOChris Packham
CONFIG_GPIO does not exist. sysreset_gpio.c uses the DM gpio APIs so the correct option to select is DM_GPIO. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-09Merge tag 'rockchip-for-v2019.07-rc1' of git://git.denx.de/u-boot-rockchipTom Rini
Improvements and new features: - split more rockchip pinctrl_core feature into per SoC - enable TPL for evb-rk3399 board - enable TPL/SPL for evb-px5 board - enable TPL and OP-TEE support for evb-rk3229 - update fix in arm common assembly start code for rockchip header file - update default SPL_FIT_GENERATOR for rockchip - rk3399 boards update to use '-u-boot.dtsi' - add new rk3399 boards: Nanopi M4, Nanopc T4 - enable sound for chromebook_minnie
2019-05-08sysreset: enable driver support in SPL/TPLKever Yang
SPL/TPL also need use sysreset for some feature like panic callback. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08x86: sysreset: Implement the get_last() methodSimon Glass
Add a default implementation of this method which always indicates that the last reset was a power-on reset. This is the most likely type of reset and without a PCH-specific driver we cannot determine any other type. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: sysreset: Implement power-off if availableSimon Glass
On modern x86 devices we can power the system off using the power- management features of the PCH. Add an implementation for this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: sysreset: Separate out the EFI codeSimon Glass
The EFI implementation of reset sits inside the driver and is called directly from outside the driver, breaking the normal driver-model conventions. Worse, it passed NULL as the device pointer, hoping that the called function won't use it, which breaks as soon as code is added to use it. Separate out the implementation to improve the situation enough to allow a future patch to add new sysreset features. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-01rockchip: use 'arch-rockchip' as header file pathKever Yang
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common header file path, so that we can get the correct path directly. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-04-26sysreset: syscon: remove POWER reset causePatrick Delaunay
The sysreset of 'POWER' type is a PMIC reset defined as 'remove and restore power'. So normally only COLD/WARN is supported by sysreset_syscon. This modification allows to use the function sysreset_walk(SYSRESET_POWER) when it is supported by PMIC driver (see example in stpmic1). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-11sysreset: use syscon_regmap_lookup_by_phandlePatrick Delaunay
Use the new function syscon_regmap_lookup_by_phandle() to simplify the code. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-11x86: Add efi runtime resetAlexander Graf
Our selftest will soon test the actual runtime reset function rather than the boot time one. For this, we need to ensure that the runtime version actually succeeds on x86 to keep our travis tests work. So this patch implements an x86 runtime reset function. It is missing shutdown functionality today, but OSs usually implement that via ACPI and this function does more than the stub from before, so it's at least an improvement. Eventually we will want to have full DM functionality in runtime services. But this fixes a travis failure and doesn't clutter the code too heavily, so we should pull it in without the amazing new RTS DM framework. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-05sandbox: sysreset: Update to support power-on resetSimon Glass
If U-Boot is started from SPL or TPL, then those earlier phases deal with the reset cause. On real hardware this cause may be lost once it is read. Emulate that behaviour in sandbox by reporting a warm reset when a previous phase has run since start-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-14sysreset: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-09sysreset: Add a way to find the last resetSimon Glass
We have a method to return the last reset as a string for humans, but not a method that allows it to be used programmatically. Add a new method that returns the last reset as an enum. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sysreset: Tidy up a few comments and loggingSimon Glass
Some comments are incorrect or missing pieces. Fix these and use logging to print the error. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-18mpc83xx: Add sysreset driverMario Six
Add a sysreset driver for the MPC83xx platform. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18test: Add tests for sysreset_get_statusMario Six
Add some tests for sysreset_get_status. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18sysreset: Add get_status methodMario Six
It's useful to have the reset status of the SoC printed out during reset (e.g. to learn whether the reset was caused by software or a watchdog). As a first step to implement this, add a get_status method to the sysreset class, which enables the caller to get printable information about the reset status (akin to get_desc in the CPU uclass). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-11sysreset: Add TI System Control Interface (TI SCI) sysreset driverAndreas Dannenberg
Devices from the TI K3 family of SoCs like the AM654x contain a Device Management and Security Controller (SYSFW) that manages the low-level device control (like clocks, resets etc) for the various hardware modules present on the SoC. These device control operations are provided to the host processor OS through a communication protocol called the TI System Control Interface (TI SCI) protocol. This patch adds a system reset driver that communicates to the system controller over the TI SCI protocol for allowing to perform a system- wide SoC reset. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-07-20Merge git://git.denx.de/u-boot-x86Tom Rini
2018-07-20sysreset: syscon: update regmap access to sysconPatrick Delaunay
Use new API syscon_node_to_regmap in sysreset_syscon driver for compatible "syscon-reboot"; that's avoid the need of explicit syscon binding for "regmap" handle. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-07-20dm: sysreset: Add a standard message when doing resetBin Meng
It's good to print a message when doing reset. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-20dm: sysreset: x86: Add a sysreset driverBin Meng
This adds a generic reset driver for x86 processor. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19sysreset: Add support for Microblaze soft reset jumpMichal Simek
Microblaze is storing reset vector at address 0x0. It means soft reset can be done by just jumping to this address. This code was in platform code but sysreset interface is providing enough capabilities to have more options how to reset the system. It can go from gpio reset through watchdog reset till soft reset. The driver has not compatible string because this is cpu specific and DM core is not able to detect compatible string in DT root that's why this driver will be instantiated from platform code by calling device_bind_driver(gd->dm_root, "mb_soft_reset", "reset_soft", NULL); It should be bind as the last reset method to ensure that hw reset is called before this. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19sysreset: Add support for gpio-restartMichal Simek
The Linux kernel has binding for gpio-restart node. This patch is adding basic support without supporting any optional properties. This driver was tested on Microblaze system where gpio is connected to SoC reset logic. Output value is handled via gpios cells values. In gpio_reboot_request() set_value is writing 1 because dm_gpio_set_value() is capable to changing it when it is ACTIVE_LOW. ... if (desc->flags & GPIOD_ACTIVE_LOW) value = !value; ... Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19sysreset: dm: Support manual relocation for sysresetMichal Simek
Relocate sysreset ops as was done by: "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-07regmap: clean up regmap allocationMasahiro Yamada
Putting zero length array at the end of struct is a common technique to embed arbitrary length of members. There is no good reason to let regmap_alloc_count() branch by "if (count <= 1)". As far as I understood the code, regmap->base is an alias of regmap->ranges[0].start, but it is not helpful but make the code just ugly. Rename regmap_alloc_count() to regmap_alloc() because the _count suffix seems pointless. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: fixup cpu_info-rcar.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-10sysreset: syscon: convert to use live dtÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-15db410c: replace reset driver with psciJorge Ramirez-Ortiz
this should be the norm for armv8 platforms. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-12-12dm: reset: have the reset-command perform a COLD resetPhilipp Tomsich
The DM version of do_reset has been issuing a warm-reset, which (on some platforms keeps GPIOs and other parts of the platform active). This may cause unintended behaviour, as calling do_reset usually indicates a desire to reset the board/platform and not just the CPU. This changes do_reset to always request a COLD reset. Note that programmatic uses can still invoke a WARM reset through reset_cpu() or using sysreset_walk(). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21rockchip: sysreset: update Makefile to work with merged sysreset driverPhilipp Tomsich
After applying the merged sysreset driver, there are build failures due to an out-of-sync Makefile. This updates drivers/sysreset/Makefile to address these build failures. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-21rockchip: sysreset: merge into one common driverKever Yang
Use a common driver for all Rockchip SOC instead of one for each SoC. Use driver_data for reg offset. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-06sti: fix STMicroelectronics copyrightPatrice Chotard
Uniformize all STMicroelectronics copyrights headers for STi related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-18rockchip: enable rk322x sysreset driverKever Yang
The sysreset driver for rk322x is ready but not enabled, add it to Makefile to make sure it's enabled. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: rk322x: add sysreset driverKever Yang
Rockchip rk322x sysreset is much like rk3036 and other Rockchip SoCs, only difference is that the target register address is different. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: Add core Soc start-up code for rv1108Andy Yan
RV1108 is embedded with an ARM Cortex-A7 single core and a DSP core from Rockchip. It is designed for varies application scenario such as car DVR, sports DV, secure camera and UAV camera. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: rk3368: Add sysreset driverAndy Yan
Add sysreset driver to reset rk3368 SOC. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: sandbox: sysreset: Convert driver to livetreeSimon Glass
Update this driver to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: sysreset: add watchdog-reboot driverÁlvaro Fernández Rojas
Add a new sysreset driver that uses the recently added watchdog support. It performs a full SoC reset by calling wdt_expire_now op. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10sysreset: add syscon-reboot driverÁlvaro Fernández Rojas
Add a new sysreset driver based on linux/drivers/power/reset/syscon-reboot.c, which provides a generic driver for platforms that only require writing a mask to a regmap offset. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor AST2500 RAM Driver and Sysreset Drivermaxims@google.com
This change switches all existing users of ast2500 Watchdog to Driver Model based Watchdog driver. To perform system reset Sysreset Driver uses first Watchdog device found via uclass_first_device call. Since the system is going to be reset anyway it does not make much difference which watchdog is used. Instead of using Watchdog to reset itself, SDRAM driver now uses Reset driver to do that. These were the only users of the old Watchdog API, so that API is removed. This all is done in one change to avoid having to maintain dual API for watchdog in between. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-18sysreset: psci: support system reset in a generic way with PSCIMasahiro Yamada
If the system is running PSCI firmware, the System Reset function (func ID: 0x80000009) is supposed to be handled by PSCI, that is, the SoC/board specific reset implementation should be moved to PSCI. U-Boot should call the PSCI service according to the arm-smccc manner. The arm-smccc is supported on ARMv7 or later. Especially, ARMv8 generation SoCs are likely to run ARM Trusted Firmware BL31. In this case, U-Boot is a non-secure world boot loader, so it should not be able to reset the system directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-15rockchip: sysreset: rk3188: Make sure remap is off on warm-resetsHeiko Stübner
The warm-reset of rk3188 socs keeps the remap setting as it was, so if it was enabled, the cpu would start from address 0x0 of the sram instead of address 0x0 of the bootrom, thus making the reset hang. Therefore make sure the remap is disabled before attempting a warm reset. Cold reset is not affected by this at all. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3328: add sysreset driverKever Yang
Add rk3328 sysreset driver. Signed-off-by: William Zhang <william.zhang@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3188: Add sysreset driverHeiko Stübner
Driver for the sysreset of Rockchip rk3188 socs. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com>
