path: root/drivers/sysreset
2018-05-07regmap: clean up regmap allocationMasahiro Yamada
Putting zero length array at the end of struct is a common technique to embed arbitrary length of members. There is no good reason to let regmap_alloc_count() branch by "if (count <= 1)". As far as I understood the code, regmap->base is an alias of regmap->ranges[0].start, but it is not helpful but make the code just ugly. Rename regmap_alloc_count() to regmap_alloc() because the _count suffix seems pointless. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: fixup cpu_info-rcar.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-10sysreset: syscon: convert to use live dtÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-15db410c: replace reset driver with psciJorge Ramirez-Ortiz
this should be the norm for armv8 platforms. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-12-12dm: reset: have the reset-command perform a COLD resetPhilipp Tomsich
The DM version of do_reset has been issuing a warm-reset, which (on some platforms keeps GPIOs and other parts of the platform active). This may cause unintended behaviour, as calling do_reset usually indicates a desire to reset the board/platform and not just the CPU. This changes do_reset to always request a COLD reset. Note that programmatic uses can still invoke a WARM reset through reset_cpu() or using sysreset_walk(). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21rockchip: sysreset: update Makefile to work with merged sysreset driverPhilipp Tomsich
After applying the merged sysreset driver, there are build failures due to an out-of-sync Makefile. This updates drivers/sysreset/Makefile to address these build failures. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-21rockchip: sysreset: merge into one common driverKever Yang
Use a common driver for all Rockchip SOC instead of one for each SoC. Use driver_data for reg offset. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-06sti: fix STMicroelectronics copyrightPatrice Chotard
Uniformize all STMicroelectronics copyrights headers for STi related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-18rockchip: enable rk322x sysreset driverKever Yang
The sysreset driver for rk322x is ready but not enabled, add it to Makefile to make sure it's enabled. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: rk322x: add sysreset driverKever Yang
Rockchip rk322x sysreset is much like rk3036 and other Rockchip SoCs, only difference is that the target register address is different. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: Add core Soc start-up code for rv1108Andy Yan
RV1108 is embedded with an ARM Cortex-A7 single core and a DSP core from Rockchip. It is designed for varies application scenario such as car DVR, sports DV, secure camera and UAV camera. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: rk3368: Add sysreset driverAndy Yan
Add sysreset driver to reset rk3368 SOC. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: sandbox: sysreset: Convert driver to livetreeSimon Glass
Update this driver to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: sysreset: add watchdog-reboot driverÁlvaro Fernández Rojas
Add a new sysreset driver that uses the recently added watchdog support. It performs a full SoC reset by calling wdt_expire_now op. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10sysreset: add syscon-reboot driverÁlvaro Fernández Rojas
Add a new sysreset driver based on linux/drivers/power/reset/syscon-reboot.c, which provides a generic driver for platforms that only require writing a mask to a regmap offset. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor AST2500 RAM Driver and Sysreset Drivermaxims@google.com
This change switches all existing users of ast2500 Watchdog to Driver Model based Watchdog driver. To perform system reset Sysreset Driver uses first Watchdog device found via uclass_first_device call. Since the system is going to be reset anyway it does not make much difference which watchdog is used. Instead of using Watchdog to reset itself, SDRAM driver now uses Reset driver to do that. These were the only users of the old Watchdog API, so that API is removed. This all is done in one change to avoid having to maintain dual API for watchdog in between. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-18sysreset: psci: support system reset in a generic way with PSCIMasahiro Yamada
If the system is running PSCI firmware, the System Reset function (func ID: 0x80000009) is supposed to be handled by PSCI, that is, the SoC/board specific reset implementation should be moved to PSCI. U-Boot should call the PSCI service according to the arm-smccc manner. The arm-smccc is supported on ARMv7 or later. Especially, ARMv8 generation SoCs are likely to run ARM Trusted Firmware BL31. In this case, U-Boot is a non-secure world boot loader, so it should not be able to reset the system directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-15rockchip: sysreset: rk3188: Make sure remap is off on warm-resetsHeiko Stübner
The warm-reset of rk3188 socs keeps the remap setting as it was, so if it was enabled, the cpu would start from address 0x0 of the sram instead of address 0x0 of the bootrom, thus making the reset hang. Therefore make sure the remap is disabled before attempting a warm reset. Cold reset is not affected by this at all. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3328: add sysreset driverKever Yang
Add rk3328 sysreset driver. Signed-off-by: William Zhang <william.zhang@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: rk3188: Add sysreset driverHeiko Stübner
Driver for the sysreset of Rockchip rk3188 socs. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com>
2017-03-14STiH410: Add STi sysreset driverPatrice Chotard
Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28aspeed: Add drivers common to all Aspeed SoCsmaxims@google.com
Add support for Watchdog Timer, which is compatible with AST2400 and AST2500 watchdogs. There is no uclass for Watchdog yet, so the driver does not follow the driver model. It also uses fixed clock, so no clock driver is needed. Add support for timer for Aspeed ast2400/ast2500 devices. The driver actually controls several devices, but because all devices share the same Control Register, it is somewhat difficult to completely decouple them. Since only one timer is needed at the moment, this should be OK. The timer uses fixed clock, so does not rely on a clock driver. Add sysreset driver, which uses watchdog timer to do resets and particular watchdog device to use is hardcoded (0) Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15xtensa: add support for the 'xtfpga' evaluation boardChris Zankel
The 'xtfpga' board is actually a set of FPGA evaluation boards that can be configured to run an Xtensa processor. - Avnet Xilinx LX60 - Avnet Xilinx LX110 - Avnet Xilinx LX200 - Xilinx ML605 - Xilinx KC705 These boards share the same components (open-ethernet, ns16550 serial, lcd display, flash, etc.). Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-12drivers/sysreset: group sysreset driversMax Filippov
Create drivers/sysreset and move sysreset-uclass and all sysreset drivers there. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
