path: root/drivers/sysreset/sysreset_sandbox.c
2018-12-05sandbox: sysreset: Update to support power-on resetSimon Glass
If U-Boot is started from SPL or TPL, then those earlier phases deal with the reset cause. On real hardware this cause may be lost once it is read. Emulate that behaviour in sandbox by reporting a warm reset when a previous phase has run since start-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sysreset: Add a way to find the last resetSimon Glass
We have a method to return the last reset as a string for humans, but not a method that allows it to be used programmatically. Add a new method that returns the last reset as an enum. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-18test: Add tests for sysreset_get_statusMario Six
Add some tests for sysreset_get_status. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: sandbox: sysreset: Convert driver to livetreeSimon Glass
Update this driver to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-12drivers/sysreset: group sysreset driversMax Filippov
Create drivers/sysreset and move sysreset-uclass and all sysreset drivers there. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
