System reset via the SRST extension in the SBI should be the default.
The driver checks if the extension is available when probing.
So there is no risk in enabling it.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Add VPL versions of commonly used Kconfig options.
This patch adds a sysreset driver for Atmel/Microchip platforms.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Add an option to automatically register watchdog devices with the
wdt_reboot driver for use with sysreset. This allows sysreset to be a
drop-in replacement for platform-specific watchdog reset code, without
needing any device tree changes.
Signed-off-by: Samuel Holland <samuel@sholland.org>
None of the sysreset drivers do anything beyond providing sysreset
uclass ops. They should depend on the sysreset uclass.
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Provide sysreset driver using the SBI system reset extension.
Reviewed-by: Sean Anderson <seanga2@gmail.com>
Tested-by: Samuel Holland <samuel@sholland.org>
Create common macro TARGET_SOCFPGA_SOC64 for Stratix10 and Agilex.
Signed-off-by: Siew Chin Lim <elly.siew.chin.lim@intel.com>
sysreset uclass driver provides an implementation of 'reset'
command using the sysreset_ APIs unconditionally. It also
supports the 'poweroff' command using the sysreset_ APIs,
but under a Kconfig option CONFIG_SYSRESET_CMD_POWEROFF.
Let's do the same for the 'reset' command, by introducing a
new Kconfig option CONFIG_SYSRESET_CMD_RESET, and set it to
on by default, to allow a board that don't have a sysreset
reset driver yet, but have a sysreset poweroff driver to
compile without any issue.
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Add GPIO poweroff driver, which is based on the Linux
driver and uses the same DT binding.
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
Enable sysreset support for Agilex platform.
Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Rename the driver from S10 to SoC64 because Intel Agilex platform
also using the this SYSRESET SoCFPGA driver for S10.
This patch adds a UCLASS_SYSRESET sysreset driver for the Octeon SoC
family.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Some chips provide their sysreset function in reset controller, which is
normally a bit written to 1 to perform the sysreset.
This patch adds a new sysreset driver to take advantage of it.
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
At present this driver is always included in SPL and TPL, if U-Boot proper
enables it. Update the Makefile to provide full control using the existing
Kconfig options.
[bmeng: make the Kconfig help text a little bit clearer]
This is a generic implementation. Add CONFIG_SYSRESET_CMD_POWEROFF
to signal when we need it. Enable it from the STPMIC1 config and in
sandbox.
The config flag is transitionary, that is it can be removed after all
poweroff implementations use sysreset, and just have CMD_POWEROFF depend
on sysreset.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Tested-by: Patrick Delaunay <patrick.delaunay@st.com>
This adds separate kconfig options for drivers/sysreset and
drivers/firmware.
Up to now, CONFIG_SPL_DRIVERS_MISC_SUPPORT added drivers/misc to SPL
build but also added drivers/firmware and drivers/sysreset at the same
time.
Since that is confusing, this patch uses CONFIG_SPL_SYSRESET for
drivers/sysreset and adds CONFIG_SPL_FIRMWARE for
drivers/firmware (and accordingly for the TPL options).
CONFIG_SPL_DRIVERS_MISC_SUPPORT stays for including drivers/misc into
the SPL build (and accordingly for TPL) since there are boards using
non-DM (non UCLASS_MISC) files from drivers/misc. Such boards don't
have CONFIG_SPL_MISC enabled, so cannot use this to include
drivers/misc into the SPL build.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
This adds a UCLASS_SYSRESET sysreset driver for socfgpa stratix10.
This adds a UCLASS_SYSRESET sysreset driver for socfgpa gen5.
CONFIG_GPIO does not exist. sysreset_gpio.c uses the DM gpio APIs so the
correct option to select is DM_GPIO.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
SPL/TPL also need use sysreset for some feature like panic callback.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Add a sysreset driver for the MPC83xx platform.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Devices from the TI K3 family of SoCs like the AM654x contain a Device
Management and Security Controller (SYSFW) that manages the low-level
device control (like clocks, resets etc) for the various hardware
modules present on the SoC. These device control operations are provided
to the host processor OS through a communication protocol called the TI
System Control Interface (TI SCI) protocol.
This patch adds a system reset driver that communicates to the system
controller over the TI SCI protocol for allowing to perform a system-
wide SoC reset.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
This adds a generic reset driver for x86 processor.
Microblaze is storing reset vector at address 0x0.
It means soft reset can be done by just jumping to this address.
This code was in platform code but sysreset interface is providing
enough capabilities to have more options how to reset the system. It can
go from gpio reset through watchdog reset till soft reset.
The driver has not compatible string because this is cpu specific and DM
core is not able to detect compatible string in DT root that's why this
driver will be instantiated from platform code by calling
device_bind_driver(gd->dm_root, "mb_soft_reset", "reset_soft",
NULL);
It should be bind as the last reset method to ensure that hw reset is
called before this.
The Linux kernel has binding for gpio-restart node.
This patch is adding basic support without supporting any optional
properties.
This driver was tested on Microblaze system where gpio is connected to
SoC reset logic.
Output value is handled via gpios cells values.
In gpio_reboot_request() set_value is writing 1 because
dm_gpio_set_value() is capable to changing it when it is ACTIVE_LOW.
if (desc->flags & GPIOD_ACTIVE_LOW)
value = !value;
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add a new sysreset driver that uses the recently added watchdog support.
It performs a full SoC reset by calling wdt_expire_now op.
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Add a new sysreset driver based on linux/drivers/power/reset/syscon-reboot.c,
which provides a generic driver for platforms that only require writing a mask
to a regmap offset.
If the system is running PSCI firmware, the System Reset function
(func ID: 0x80000009) is supposed to be handled by PSCI, that is,
the SoC/board specific reset implementation should be moved to PSCI.
U-Boot should call the PSCI service according to the arm-smccc
manner.
The arm-smccc is supported on ARMv7 or later. Especially, ARMv8
generation SoCs are likely to run ARM Trusted Firmware BL31. In
this case, U-Boot is a non-secure world boot loader, so it should
not be able to reset the system directly.
Create drivers/sysreset and move sysreset-uclass and all sysreset
drivers there.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
