Add new sysinfo IDs for R-Car V3H Condor/Condor-I .
Enable support for sysinfo on R-Car V3H Condor/Condor-I. The sysinfo is
used e.g. to access and decode board-specific information and then in
turn used by board-info to print those information.
Reviewed-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
Signed-off-by: Tam Nguyen <tam.nguyen.xa@renesas.com>
Signed-off-by: Hai Pham <hai.pham.ud@renesas.com>
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
[Marek: Drop compatible from I2C node, this is in r8a77980.dtsi already.
Drop status = "okay" from EEPROM node.
Add dts: tag.
Update the commit message, note the new sysinfo IDs.
Fix Kconfig EEPROM address to be 0x50 and match the DT, sync config.]
Correct the board code ID based on the hardware documentation
Clarify documentation, fix a few more cases that could be broken by the
change.
Signed-off-by: Michal Suchanek <msuchanek@suse.de>
The Renesas R-Car Gen3 development kits contain board ID EEPROM.
This driver parses out the board ID and revision out of that
EEPROM and exports it e.g. for the board-info print on boot.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Sean Anderson <sean.anderson@seco.com>
Define LOG_CATEGORY for all uclass to allow filtering with
log command.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
This uses the newly-added dm_gpio_get_values_as_int_base3 function to
implement a sysinfo device. The revision map is stored in the device tree.
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
This has the uclass enforce calling detect() before other methods. This
allows drivers to cache information in detect() and perform (cheaper)
retrieval in the other accessors. This also modifies the only instance
where this sequencing was not followed.
Since 07c9e683a4 ("smbios: Allow a few values to come from sysinfo")
there are common global sysinfo IDs. This patch moved existing IDs above
SYSINFO_ID_USER.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
Some boards want to specify the manufacturer or product name but do not
need to have their own sysinfo driver.
Add a default driver which provides a way to specify this SMBIOS
information in the devicetree, without needing any board-specific
functionality.
This uclass is intended to provide a way to obtain information about a
U-Boot board. But the concept of a U-Boot 'board' is the whole system,
not just one circuit board, meaning that 'board' is something of a
misnomer for this uclass.
In addition, the name 'board' is a bit overused in U-Boot and we want to
use the same uclass to provide SMBIOS information.
The obvious name is 'system' but that is so vague as to be meaningless.
Use 'sysinfo' instead, since this uclass is aimed at providing information
on the system.
Rename everything accordingly.
Note: Due to the patch delta caused by the symbol renames, this patch
shows some renamed files as being deleted in one place and created in
another.
