path: root/drivers/spmi
2021-10-31spmi: msm: add arbiter version 5 supportDzmitry Sankouski
Currently driver supports only version 1 and 2. Version 5 has slightly different registers structure Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com> Cc: Ramon Fried <rfried.dev@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2021-07-06dm: define LOG_CATEGORY for all uclassPatrick Delaunay
Define LOG_CATEGORY for all uclass to allow filtering with log command. Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-12-13dm: treewide: Rename auto_alloc_size members to be shorterSimon Glass
This construct is quite long-winded. In earlier days it made some sense since auto-allocation was a strange concept. But with driver model now used pretty universally, we can shorten this to 'auto'. This reduces verbosity and makes it easier to read. Coincidentally it also ensures that every declaration is on one line, thus making dtoc's job easier. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-25treewide: convert devfdt_get_addr() to dev_read_addr()Masahiro Yamada
When you enable CONFIG_OF_LIVE, you will end up with a lot of conversions. To generate this commit, I used coccinelle excluding drivers/core/, include/dm/, and test/ The semantic patch that makes this change is as follows: <smpl> @@ expression dev; @@ -devfdt_get_addr(dev) +dev_read_addr(dev) </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-07-24Revert "Merge tag 'dm-pull-20jul20' of git://git.denx.de/u-boot-dm"Tom Rini
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing changes made to 56d37f1c564107e27d873181d838571b7d7860e7. Unfortunately this is causing CI failures: https://travis-ci.org/github/trini/u-boot/jobs/711313649 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-20treewide: convert devfdt_get_addr() to dev_read_addr()Masahiro Yamada
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15spmi: msm: display the PMIC Arb version (debug)Jorge Ramirez-Ortiz
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-12-12drivers: spmi-msm: fix scanning for peripheralsJorge Ramirez-Ortiz
A typo in the probe function causes not all peripherals to be scanned (in the case of the Dragonboard820c - work in progress - it wont find pmic0).
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-12Merge git://git.denx.de/u-boot-dmTom Rini
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-12kconfig: use bool instead of boolean for type definition attributesMasahiro Yamada
Linux stopped the use of keyword 'boolean' in Kconfig. Refer to commit 6341e62b212a2541efb0160c470e90bd226d5496 ("kconfig: use bool instead of boolean for type definition attributes") in Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-27dm: Use dm_scan_fdt_dev() directly where possibleSimon Glass
Quite a few places have a bind() method which just calls dm_scan_fdt_dev(). We may as well call dm_scan_fdt_dev() directly. Update the code to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-11spmi: Fix sandbox spmi driver memory corruptionMateusz Kulikowski
There is off-by-one error in sandbox_emul_gpio that causes segfault of certain tests. EMUL_GPIO_REG_END is the address of last valid (emulated) register. This patch fixed this (by adding one more element to emulated register array). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-04-01drivers: spmi: Add support for Qualcomm SPMI bus driverMateusz Kulikowski
Support SPMI arbiter on Qualcomm Snapdragon devices. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01spmi: Add sandbox test driverMateusz Kulikowski
This patch adds emulated spmi bus controller with part of pm8916 pmic on it to sandbox and tests validating SPMI uclass. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01drivers: Add SPMI bus uclassMateusz Kulikowski
Qualcom processors use proprietary bus to talk with PMIC devices - SPMI (System Power Management Interface). On wiring level it is similar to I2C, but on protocol level, it's multi-master and has simple autodetection capabilities. This commit adds simple uclass that provides bus read/write interface. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
