Add support for spi memory operations for xilinx AXI qspi driver.
This provides an high-level interface to execute SPI memory
operations by the controller.
Remove existing spi transfer based implementation and use
spi memory based exec_op() implementation for qspi IO operations.
Simplified existing startup_block implementation.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
Link: https://lore.kernel.org/r/1657954727-31972-2-git-send-email-ashok.reddy.soma@xilinx.com
Signed-off-by: Michal Simek <michal.simek@amd.com>
The SPI controllers in the Allwinner F1Cx00 series of SoCs are
compatible to the H3 IP. The only difference in the integration is
the missing mod clock in the F1C100, instead the SPI clock is directly
derived from the AHB clock.
We *should* be able to model this through the DT, but the addition of
get_rate() requires quite some refactoring, so it's not really worth in
this simple case: We programmed both the PLL_PERIPH to 600 MHz and the
PLL/AHB divider to 3 in the SPL, so we know the SPI base clock is 200
MHz. Since we used a hard coded fixed clock rate of 24 MHz for all the
other SoCs so far, we can as well do the same for the F1C100.
Define the SPI input clock and maximum frequency differently when
compiling for the F1C100 SoC.
Also adjust the power-of-2 divider programming, because that uses a
"minus one" encoding, compared to the other SoCs.
This allows to enable SPI flash support for the F1C100 boards.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The current SPI clock divider calculation has two problems:
- We use a normal round-down division, which results in a divider
typically being too small, resulting in a too high frequency on the bus.
- The calculaction for the power-of-two divider is very inaccurate, and
again rounds down, which might lead to wild bus frequencies.
This wasn't a real problem so far, since most chips can handle slightly
higher bus frequencies just fine. Also the actual speed was mostly lost
anyway, due to release_bus() reseting the device. And the power-of-2
calculation was probably never used, because it only applies to
frequencies below 47 KHz.
However this will become a problem for the F1C100s support, due to its
much higher base frequency.
Calculate a safe divider correctly (using round-up), and re-use that
value when calculating the power-of-2 value. We also separate the
maximum frequency and the input clock on the way, since they will be
different for the F1C100s.
As George rightfully pointed out [1], the spi-sunxi driver programs the
speed and mode settings only when the respective functions are called,
but this gets lost over a call to release_bus(). That asserts the
reset line, thus forces each SPI register back to its default value.
Adding to that, trying to program SPI_CCR and SPI_TCR might be pointless
in the first place, when the reset line is still asserted (before
claim_bus()), so those setting won't apply most of the time. In reality
I see two nested claim_bus() calls for the first use, so settings between
the two would work (for instance for the initial "sf probe"). However
later on the speed setting is not programmed into the hardware anymore.
So far we get away with that default frequency, because that is a rather
tame 24 MHz, which most SPI flash chips can handle just fine.
Move the actual register programming into a separate function, and use
.set_speed and .set_mode just to set the variables in our priv structure.
Then we only call this new function in claim_bus(), when we are sure
that register accesses actually work and are preserved.
[1] https://lore.kernel.org/u-boot/20210725231636.879913-17-me@yifangu.com/
Reported-by: George Hilliard <thirtythreeforty@gmail.com>
The current detection of RX FIFO depth seems to be not reliable, and
XCH will self-clear when a transfer is done.
Check XCH bit when polling for transfer finish.
Signed-off-by: Icenowy Zheng <uwu@icenowy.me>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
This patch makes mt7621_spi driver available for MediaTek MT7621 SoC
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
When the requested flash speed is 0, the baudrate division for the
requested speed causing drop in the performance. So set the ospi flash
to operate at max frequency when requested speed is zero.
Link: https://lore.kernel.org/r/20220512100535.16364-6-ashok.reddy.soma@xilinx.com
On versal platform, enable apb linear mode for apb read and write
execute operations amd disable it when using dma reads. This is done by
xilinx_pm_request() secure calls when CONFIG_ZYNQMP_FIRMWARE is enabled,
else we use direct raw reads and writes in case of mini U-Boot.
Link: https://lore.kernel.org/r/20220512100535.16364-5-ashok.reddy.soma@xilinx.com
When flash operated at non default mode like DDR, flash need to be reset
to operate in SDR mode to read flash ids by spi-nor framework. Reset the
flash to the default state before using the flash. This reset is handled
by a gpio driver, in case of mini U-Boot as gpio driver is disabled, we
do raw read and write access by the registers.
Versal platform utilizes spi calibration for read delay programming, so
incase by default read delay property is set in DT. We make sure not to
use read delay from DT by overwriting read_delay with -1.
Link: https://lore.kernel.org/r/20220512100535.16364-4-ashok.reddy.soma@xilinx.com
Add support for cadence ospi driver for Versal platform. This driver
provides support for DMA read operation which utilizes cadence qspi
driver.
If "cdns,is-dma" DT property is specified use dma for read operation
from cadence_qspi driver. As cadence_qspi_apb_dma_read() is defined in
cadence_ospi_versal driver add a weak function defination in
Link: https://lore.kernel.org/r/20220512100535.16364-3-ashok.reddy.soma@xilinx.com
Move all the cadence macros from cadence_qspi_apb.c to cadence_qspi.h
file.
Link: https://lore.kernel.org/r/20220512100535.16364-2-ashok.reddy.soma@xilinx.com
The GXP supports 3 separate SPI interfaces to accommodate the system
flash, core flash, and other functions. The SPI engine supports variable
clock frequency, selectable 3-byte or 4-byte addressing and a
configurable x1, x2, and x4 command/address/data modes. The memory
buffer for reading and writing ranges between 256 bytes and 8KB. This
driver supports access to the core flash.
Signed-off-by: Nick Hawkins <nick.hawkins@hpe.com>
Merge in v2022.07-rc5.
Replace reference to the correct name STMicroelectronics
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
The nxp_fspi_default_setup() is only ever called from nxp_fspi_probe(),
where the IP clock are initially disabled. Drop the second disabling of
clock to prevent clock enable/disable imbalance reported by clock core:
clk qspi_root_clk already disabled
Cc: Fabio Estevam <festevam@denx.de>
Cc: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
There is a TX-FIFO and Shift Register empty(TFES) status
bit in spi controller. This commit checks the TFES bit
to wait the TX transfer completes.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Signed-off-by: Satoru Okamoto <okamoto.satoru@socionext.com>
Acked-by: Jassi Brar <jaswinder.singh@linaro.org>
DMSTART bit must not be set while there is active transfer.
This commit sets the DMSTART bit only when the transfer begins.
synquacer_cs_set() function does not wait the chip select
is deasserted when the driver sets the DMSTOP to deselect
the slave.
This commit checks the Slave Select Released(SRS) bit to wait
until the slave is deselected.
"busy" variable is ORed without being initialized,
must be zeroed before use.
Move legacy spi_get_bus_and_cs() code to _spi_get_bus_and_cs().
Add new spi_get_bus_and_cs() implementation which rely on DT
for speed and mode and don't need any drv_name nor dev_name
parameters. This will prepare the ground for next patch.
Update all callers to use _spi_get_bus_and_cs() to keep the
same behavior.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Marek Behun <marek.behun@nic.cz>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Vignesh R <vigneshr@ti.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Stefan Roese <sr@denx.de>
Cc: "Pali Rohár" <pali@kernel.org>
Cc: Konstantin Porotchkin <kostap@marvell.com>
Cc: Igal Liberman <igall@marvell.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Pratyush Yadav <p.yadav@ti.com>
Cc: Sean Anderson <seanga2@gmail.com>
Cc: Anji J <anji.jagarlmudi@nxp.com>
Cc: Biwen Li <biwen.li@nxp.com>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Chaitanya Sakinam <chaitanya.sakinam@nxp.com>
Waiting for SR_BUSY bit when receiving a new command is not needed.
SR_BUSY bit is already managed in the previous command treatment.
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Currently, SR_TCF flag is checked in case there is data, this criteria
is not correct.
SR_TCF flags is set when programmed number of bytes have been transferred
to the memory device ("bytes" comprised command and data send to the
SPI device).
So even if there is no data, we must check SR_TCF flag.
- NPCM7xx FIU SPI driver (Jim Liu)
- AT45DB641E dataflash (Luca Ellero)
Add a mask parameter to control the lookup of the PCI region from which
the mapping can be made.
Signed-off-by: Andrew Scull <ascull@google.com>
Evolve dm_pci_map_bar() to include an offset and length parameter. These
allow a portion of the memory to be mapped and range checks to be
applied.
Passing both the offset and length as zero results in the previous
behaviour and this is used to migrate the previous callers.
Add Nuvoton NPCM BMC Flash Interface Unit(FIU) SPI master
controller driver using SPI-MEM interface.
The FIU supports single, dual or quad communication interface.
The FIU controller driver provides flash access in UMA(User
Mode Access) mode by using an indirect address/data mechanism.
the dts node is followed upstream kernel dts name.
Signed-off-by: Jim Liu <JJLIU0@nuvoton.com>
Signed-off-by: Stanley Chu <yschu@nuvoton.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
[Jagan: fixed the Kconfig, Makefile order]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Use the spi_mem_default_supports_op() core helper in order to take into
account the buswidth specified by the user in device tree.
Fixes: 24c8ff4684 ("spi: Add Atmel QuadSPI driver")
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
Add missing include for dm/device_compat.h. Without this include the
SFC driver fails to compile because dev_err and dev_dbg are not
defined.
Signed-off-by: Chris Morgan <macromorgan@hotmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The i.MX8M Mini and i.MX8M Plus flexspi IPs are compatible with one
another, however the linux kernel DT uses separate compatible string
for each SoC. Add the missing i.MX8MP compatible into this driver.
This is a little tricky since SoCFPGA has code to determine this as
runtime. Introduce a guard variable for platforms to select if they
have a static value to use. Then for ARCH_SOCFPGA, call
cm_get_qspi_controller_clk_hz() and otherwise continue the previous
behavior.
A big part is the DM pinctrl driver, which allows us to get rid of quite
some custom pinmux code and make the whole port much more robust. Many
thanks to Samuel for that nice contribution! There are some more or less
cosmetic warnings about missing clocks right now, I will send the trivial
fixes for that later.
Another big chunk is the mkimage upgrade, which adds RISC-V and TOC0
(secure images) support. Both features are unused at the moment, but I
have an always-secure board that will use that once the DT lands in the
kernel.
On top of those big things we have some smaller fixes, improving the
I2C DM support, fixing some H6/H616 early clock setup and improving the
eMMC boot partition support.
The gitlab CI completed successfully, including the build test for all
161 sunxi boards. I also boot tested on a A64, A20, H3, H6, and F1C100
board. USB, SD card, eMMC, and Ethernet all work there (where applicable).
This is now handled automatically by the pinctrl driver.
Signed-off-by: Samuel Holland <samuel@sholland.org>
This function always succeeds, so don't check its return value.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
Link: https://lore.kernel.org/r/20220115222504.617013-7-seanga2@gmail.com
Link: https://lore.kernel.org/r/20220115222504.617013-6-seanga2@gmail.com
The designware spi driver unconditionally uses polling.
The comment to spi_hw_init() also states that the function should disable
interrupts.
According to the DesignWare DW_apb_ssi Databook, value 0xff in IMR enables
all interrupts. Since we want to mask all interrupts write 0x0 instead.
On the canaan k210 board, pressing the reset button twice to reset the
board will run u-boot. If u-boot boots Linux without having SPI interrupts
masked, Linux will hang as soon as interrupts are enabled, because of an
interrupt storm.
Properly masking the SPI interrupts in u-boot allows us to successfully
boot Linux, even after resetting the board.
Fixes: 5bef6fd79f94 ("spi: Add designware master SPI DM driver used on SoCFPGA")
[Niklas: rewrite commit message]
Signed-off-by: Niklas Cassel <niklas.cassel@wdc.com>
Reviewed-by: Sean Anderson <seanga2@gmail.com>
The Canaan Kendryte K210 SoC DW apb_ssi v4 spi controller is documented
to have a 32 word deep TX and RX FIFO, which spi_hw_init() detects.
However, when the RX FIFO is filled up to 32 entries (RXFLR = 32), an
RX FIFO overrun error occurs. Avoid this problem by force setting
fifo_len to 31.
Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
"kendryte" is the marketing name for the K210 RISC-V SoC produced by
Canaan Inc. Rather than "kendryte,k210", use the usual "canaan,k210"
vendor,SoC compatibility string format in the device tree files and
use the SoC name for file names.
With these changes, the device tree files are more in sync with the
Linux kernel DTS and drivers, making uboot device tree usable by the
kernel.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
IPROC qspi driver supports both BSPI and MSPI modes.
Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Signed-off-by: Bharat Gooty <bharat.gooty@broadcom.com>
Acked-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Signed-off-by: Roman Bacik <roman.bacik@broadcom.com>
The driver is currently using sizeof(op->cmd.opcode) in the op_len
calculation. Commit d15de623013c ("spi: spi-mem: allow specifying a
command's extension") changed op->cmd.opcode from one byte to two.
Instead, a new struct member op->cmd.nbytes is supposed to be used.
For regular commands op->cmd.nbytes will be one.
Commit d15de623013c ("spi: spi-mem: allow specifying a command's
extension") did update some drivers that overload the generic mem_ops()
implementation, but forgot to update dw_spi_mem_ops().
Calculating op_len incorrectly causes dw_spi_mem_ops() to misbehave, since
op_len is used to determine how many bytes that should be read/written.
On the canaan k210 board, this causes the probe of the SPI flash to fail.
Fix the op_len calculation in dw_spi_mem_ops(). Doing so results in
working SPI flash on the canaan k210 board.
Fixes: d15de623013c ("spi: spi-mem: allow specifying a command's extension")
Reviewed-by: Pratyush Yadav <p.yadav@ti.com>
Tested-by: Damien Le Moal <damien.lemoal@opensource.wdc.com>
In the TI am65 device tree files there is no reset defined. Also
the Linux kernel driver uses devm_reset_control_get_optional_exclusive(..)
to get the reset.
Lets do the same as the kernel does and make thr reset optinal.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2022.04-rc3
microblaze:
- Fix exception handler
zynqmp:
- Show information about secure images
- DT changes (som u-boot file removal)
- Fix zynqmp_pm_cfg_obj_convert.py
- Fix platform boot
xilinx:
- Fix bootm_size calculation
- Remove GPIO_EXTRA_HEADER selection
power:
- Add zynqmp power management driver
scsi:
- Add phy support to ceva driver
zynq qspi:
- Fix unaligned accesses and check baudrate setup
- Add support for spi memory operations
net:
- Fix 64bit calculation in axi_emac
video:
- Add missing gpio dependency for seps driver
Add a driver for the SPI controller integrated on Apple SoCs.
This is necessary to support the keyboard on Apple Silicon laopts
since their keyboard uses an Apple-specific HID over SPI protocol.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
The value of cnt is overwritten without being used.
Signed-off-by: Haolin Li <li.haolin@qq.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Spi memory operation interface is added to zynq qspi
driver to provide an high-level interface to execute
qspi controller specific memory operations by avoiding
spi_mem_exec_op() from spi-mem framework.
Link: https://lore.kernel.org/r/20220131052240.23403-5-ashok.reddy.soma@xilinx.com
Add a check afer baudrate calculation to see if the resultant value
falls within the range, else set it to default baudrate value.
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Link: https://lore.kernel.org/r/20220131052240.23403-4-ashok.reddy.soma@xilinx.com
Read only one byte at a time from txbuf as txbuf may not be
aligned and accessing more than a byte at a time may cause
alignment issues. This fixes the issue of data abort exception
while writing to flash device.
Link: https://lore.kernel.org/r/20220131052240.23403-3-ashok.reddy.soma@xilinx.com
This patch typecasts and accesses rx buf properly as
an unaligned rxbuf, typecasting with u16 and accessing
it causes data abort exception and this patch fixes it.
Link: https://lore.kernel.org/r/20220131052240.23403-2-ashok.reddy.soma@xilinx.com
The driver for SPI0 on Allwinner H6 SoCs did not use the correct define
SUN50I_GPC_SPI0 for the pin function, but one for a different Allwinner
SoC series.
Fix the conditionals to use the correct define for H6 SoCs. This matches
the conditional logic in the SPL spi driver.
Tested by probing the spi-flash on a pine64_h64-model-b board with
adapted device-tree (disable mmc2, enable spi0).
Signed-off-by: Daniel Wagenknecht <dwagenk@mailbox.org>
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
On AM4372 the SPI_GCLK input gets its clock from the PRCM module which
divides the PER_CLKOUTM2 frequency (192MHz) by a fixed factor of 4.
See AM437x Reference Manual in section 27 QSPI >> 27.2 Integration.
The QSPI_FCLK therefore needs to take this factor into account and
becomes (192000000 / 4).
Signed-off-by: Stefan Mätje <stefan.maetje@esd.eu>
