path: root/drivers/spi
2016-08-25spi: tegra: fix hang in set_mode()Stephen Warren
In tegra20_slink.c, the set_mode() function may be executed before the SPI bus is claimed the first time, and hence the clocks to the SPI controller may not be running. If so, any register read/write at this time will hang the CPU. Fix this by ensuring the clock is running as soon as the driver is probed. This is observed on the Tegra30 Beaver board. Apply the same clock initialization fix to all other Tegra SPI drivers so that if set_mode() is ever implemented there, the same bug will not appear. Note that tegra114_spi.c already operates in this fashion. The clock manipulation code is copied from claim_bus() to probe() rather than moved. This ensures that any calls to set_speed() take effect; the clock can't be set once during probe and left unchanged. Fixes: 5cb1b7b395c0 ("spi: tegra20: Add support for mode selection") Cc: Mirza Krak <mirza.krak@hostmobility.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-07spi: cadence_qspi_apb: Ensure baudrate doesn't exceed max valueChin Liang See
Ensuring the baudrate divisor value doesn't exceed the max value in the calculation.It will be capped at max value to ensure the correct value being written into the register. Example of the existing bug is when calculated div = 16. After and with the mask, the value written to register is actually 0 (register field for baudrate divisor). With this fix, the value written is now 15 which is max value for baudrate divisor. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Jagan Teki <jteki@openedev.com> Cc: Dinh Nguyen <dinguyen@altera.com>
2016-08-02driver: spi: fsl-qspi: remove compile WarningsYunhui Cui
Warnins log: drivers/spi/fsl_qspi.c: In function ‘qspi_ahb_read’: drivers/spi/fsl_qspi.c:400:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] memcpy(rxbuf, (u8 *)(priv->cur_amba_base + priv->sf_addr), len); Signed-off-by: Yunhui Cui <yunhui.cui@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-30spi: ti_qspi: dra7xx: Add support to use 76.8MHz clockVignesh R
According to AM572x DM SPRS953A, QSPI bus speed can be 76.8MHz, update the driver to use the same. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-07-30spi: ti_qspi: Remove delay in read path for dra7xxVignesh R
As per commit b545a98f5dc563 ("spi: ti_qspi: Add delay for successful bulk erase) says its added to meet bulk erase timing constraints. But bulk erase is a cmd to flash and delay in read path does not make sense. Morever, testing on DRA74/DRA72 evm has shown that this delay is no longer required. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-07-30spi: ti_qspi: Fix compiler warning when DEBUG macro is setVignesh R
clk_div is uninitialized at the beginning of ti_spi_set_speed(), move debug() print after clk_div calculation to avoid compiler warning and to have proper value of clk_div printed during debugging. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-07-30spi: ti_qspi: Fix failure on multiple READ_ID cmdVignesh R
Populating QSPI_RD_SNGL bit(0x1) in priv->cmd means that value QSPI_INVAL (0x4) is not written to CMD field of QSPI_SPI_CMD_REG in ti_qspi_cs_deactivate(). Therefore CS is never deactivated between successive READ ID which results in sf probe to fail. Fix this by not populating priv->cmd with QSPI_RD_SNGL and OR it wih priv->cmd as required (similar to the convention followed in the driver). Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-07-27dm: Use dm_scan_fdt_dev() directly where possibleSimon Glass
Quite a few places have a bind() method which just calls dm_scan_fdt_dev(). We may as well call dm_scan_fdt_dev() directly. Update the code to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-09dm: spi: Read default speed and mode values from DTVignesh R
In case of DT boot, don't read default speed and mode for SPI from CONFIG_*, instead read from DT node. This will make sure that boards with multiple SPI/QSPI controllers can be probed at different bus frequencies and SPI modes. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-09spi: cadence_quadspi: Enable QUAD mode based on DT dataVignesh R
Instead of relying on CONFIG_SPI_FLASH_QUAD to be defined to enable QUAD mode, make use of mode_rx field of dm_spi_slave_platdata to determine whether to enable or disable QUAD mode. This is necessary to support muliple SPI controllers where one of them may not support QUAD mode. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-09spi: cadence_qspi_apb: Support 32 bit AHB addressVignesh R
AHB address can be as long as 32 bit, hence remove the CQSPI_REG_INDIRECTRDSTARTADDR mask. Since AHB address is passed from DT and read as u32 value, it anyway does not make sense to mask upper bits. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-09spi: davinci_spi: Convert to driver to adapt to DMVignesh R
Convert davinci_spi driver so that it complies with SPI DM framework. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-06spi: spi-uclass: fix typo in debug outputAnatolij Gustschin
Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-01driver: qspi: correct QSPI disable CS reset valuePraneeth Bajjuri
Correcting QSPI disable/unselect CS reset value. CTRL_CORE_CONTROL_IO_2: QSPI_MEMMAPPED_CS[10:8] This is not causing any issue, but its better to untouch the reserved bits. Praneeth Bajjuri <praneeth@ti.com> Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-06-19clk: convert API to match reset/mailbox styleStephen Warren
The following changes are made to the clock API: * The concept of "clocks" and "peripheral clocks" are unified; each clock provider now implements a single set of clocks. This provides a simpler conceptual interface to clients, and better aligns with device tree clock bindings. * Clocks are now identified with a single "struct clk", rather than requiring clients to store the clock provider device and clock identity values separately. For simple clock consumers, this isolates clients from internal details of the clock API. * clk.h is split so it only contains the client/consumer API, whereas clk-uclass.h contains the provider API. This aligns with the recently added reset and mailbox APIs. * clk_ops .of_xlate(), .request(), and .free() are added so providers can customize these operations if needed. This also aligns with the recently added reset and mailbox APIs. * clk_disable() is added. * All users of the current clock APIs are updated. * Sandbox clock tests are updated to exercise clock lookup via DT, and clock enable/disable. * rkclk_get_clk() is removed and replaced with standard APIs. Buildman shows no clock-related errors for any board for which buildman can download a toolchain. test/py passes for sandbox (which invokes the dm clk test amongst others). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-06-10spi: pic32_spi: add SPI master driver for PIC32 SoC.Purna Chandra Mandal
This driver implements SPI protocol in master mode to communicate with the SPI device connected on SPI bus. It handles /CS explicitly by controlling respective pin as gpio ('cs-gpios' property in dt node) and uses PIO mode for SPI transaction. It is configurable based on driver-model only. Cc: Jagan Teki <jteki@openedev.com> Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-05-23Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2016-05-23omap3: Fix SPI registers on am33xx and am43xxMartin Hejnfelt
When the base registers are read from device tree the base is not 0x48030100 as the driver expects, but 0x48030000, resulting in non functioning SPI. To deal with this, use same idea as how this is done in the linux kernel (drivers/spi/spi-omap2-mcspi.c) and add a structure with a field that is used to shift the registers on these systems. v2: Fixed commit subject line to correct cpu Signed-off-by: Martin Hejnfelt <mh@newtec.dk>
2016-05-21ath79: spi: Remove the explicit pinctrl settingWills Wang
The correct pinctrl is handled automatically so we don't need to do it in the driver. Signed-off-by: Wills Wang <wills.wang@live.com>
2016-05-21drivers: spi: add spi support for QCA/Atheros ath79 SOCsWills Wang
This patch add a compatible spi driver for ath79 series SOC. Signed-off-by: Wills Wang <wills.wang@live.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-18spi: fsl_qspi: Enable Spansion S25FS-S family flashesYuan Yao
The flash type of LS2085AQDS QSPI is S25FS256S. It has special write any device register command and read any device register command. This patch enable support for those commands. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-18spi: fsl_qspi: Assign AMBA mem according CS num in dtsYuan Yao
QSPI controller automatic enable the chipselect signal according the dest AMBA memory address. Now we distribute the AMBA memory zone averagely to every chipselect slave device according chipselect numbers got from dts node. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-18spi: fsl_qspi: Fix issues on arm64Yuan Yao
The address value and size value get from dts "reg" property have type of u64 on arm64. If we assign those values to "u32" variables, driver can't work correctly. Converting the type of those variables to fdt_xxx_t. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17dm: spi: introduce dm apiPeng Fan
Introduce dm_spi_claim_bus, dm_spi_release_bus and dm_spi_xfer Convert spi_claim_bus, spi_release_bus and spi_xfer to use the new API. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jagan Teki <jteki@openedev.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: spi: soft_spi: switch to use linux compatible stringPeng Fan
1. Support compatible string "spi-gpio" which is used by Linux Linux use different bindings, so use UBOOT_COMPAT and LINUX_COMPAT to differentiate them. 2. Introduce SPI_MASTER_NO_RX and SPI_MASTER_NO_TX to handle no rx or no tx case. 3. Tested on i.MX6 UltraLite board with 74LV595 spi-gpio chip. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: spi: soft_spi bug fixPeng Fan
When doing xfer, should use device->parent, but not device When doing bit xfer, should use "!!(tmpdout & 0x80)", but not "(tmpdout & 0x80)" Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jagan Teki <jteki@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-06mtd: cqspi: Simplify indirect read codeMarek Vasut
The indirect read code is a pile of nastiness. This patch replaces the whole unmaintainable indirect read implementation with the one from upcoming Linux CQSPI driver, which went through multiple rounds of thorough review and testing. All the patch does is it plucks out duplicate ad-hoc code distributed across the driver and replaces it with more compact code doing exactly the same thing. There is no speed change of the read operation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Jagan Teki <jteki@openedev.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vignesh R <vigneshr@ti.com>
2016-05-06mtd: cqspi: Simplify indirect write codeMarek Vasut
The indirect write code is buggy pile of nastiness which fails horribly when the system runs fast enough to saturate the controller. The failure results in some pages (256B) not being written to the flash. This can be observed on systems which run with Dcache enabled and L2 cache enabled, like the Altera SoCFPGA. This patch replaces the whole unmaintainable indirect write implementation with the one from upcoming Linux CQSPI driver, which went through multiple rounds of thorough review and testing. While this makes the patch look terrifying and violates all best-practices of software development, all the patch does is it plucks out duplicate ad-hoc code distributed across the driver and replaces it with more compact code doing exactly the same thing. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Jagan Teki <jteki@openedev.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vignesh R <vigneshr@ti.com>
2016-04-06spi: kirkwood_spi: Add support for multiple chip-selects on MVEBUStefan Roese
Currently only chip-select 0 is supported by the kirkwood SPI driver. The Armada XP / 38x SoCs also use this driver and support multiple chip selects. This patch adds support for multiple CS on MVEBU. The register definitions are restructured a bit with this patch. Grouping them to the corresponding registers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-04spi: kirkwood_spi.c: Add compatible match ID for Armada 375Stefan Roese
This enables this driver for the Marvell Armada 375 SoC. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Reviwer-by: Jagan Teki <jteki@openedev.com>
2016-03-15spi: omap3: Fix multiple definition of 'priv'Jagan Teki
Global definition of priv seems no-sense to use it for non-dm case and pass the pointer to functions which are common to both dm and non-dm. So, fix this by removing omap3_spi_slave from non-dm and make visible to omap3_spi_priv for both dm and non-dm. Cc: Christophe Ricard <christophe-h.ricard@st.com> Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-03-14spi: omap3: Convert to driver modelJagan Teki
After this conversion the driver will able to support both dm and non-dm and code is more extensible like we can remove the non-dm part simply without touching anycode if all the boards which are using this driver become dm driven. Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Tested-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Jagan Teki <jteki@openedev.com> [Set priv->wordlen, Add Kconfig entry and file credit for dm conversion] Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
2016-03-14spi: omap3: Make local functions as staticJagan Teki
Attach static on local defined functions. Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
2016-03-14spi: omap3: Move headers code inside the driverJagan Teki
Header file have macro's and register definition and some unneeded function proto types which becomes tunned further in future patches and entire driver code resides in one file for more readability. Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jagan Teki <jteki@openedev.com> [Fixes on code styles, Remove omap3_spi_txrx|write|read in header] Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
2016-03-12dm: ti_qspi: Fix conversion of address to a pointerLokesh Vutla
TI QSPI driver directly typecasts fdt_addr_t to a pointer. This is not strictly correct, as it gives a build warning when fdt_addr_t is u64. So, use map_physmem for a proper typecasts. This is inspired by commit 167efe01bc5a9 ("dm: ns16550: Use an address instead of a pointer for the uart base") Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-02-23spi: spi-uclass: Set slave wordlen with SPI_DEFAULT_WORDLENChristophe Ricard
In some case wordlen may not be set. Use SPI_DEFAULT_WORDLEN as default. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23spi: omap3: Remove unused variable irqstatus in omap3_spi_txrxChristophe Ricard
Remove unused variable irqstatus in omap3_spi_txrx Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23spi: ti_qspi: compile out spi_flash_copy_mmap when CONFIG_DMA is definedMugunthan V N
When CONFIG_DMA is defined the default spi_flash_copy_mmap() can handle dma memory copy, so compile out spi_flash_copy_mmap() from ti_qspi driver when CONFIG_DMA config is defined. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-05dm: pch: Rename get_sbase op to get_spi_baseBin Meng
Spell out 'sbase' to 'spi_base' so that it looks clearer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05spi: ich: Change PCHV_ to ICHV_Bin Meng
The ICH SPI controller supports two variants, one of which is ICH7 compatible and the other is ICH9 compatible. Change 'pch_version' to 'ich_version' to better match its original name. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05spi: ich: Use compatible strings to distinguish controller versionBin Meng
At present ich spi driver gets the controller version information via pch, but this can be simply retrieved via spi node's compatible string. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-05spi: ich: Some clean upBin Meng
This cleans up the ich spi driver a little bit: - Remove struct ich_spi_slave that is not referenced anywhere - Remove ending period in some comments - Move struct ich_spi_platdata and struct ich_spi_priv to ich.h - Add #ifndef _ICH_H_ .. in ich.h Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-27Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-01-27spi: fsl_qspi: Fix qspi_op_rdsr memcpy issueGong Qianyu
In current driver, we always copy 4 bytes to the dest memory. Actually the dest memory may be shorter than 4 bytes. Add an argument to indicate the dest memory length. Avoid writing memory outside of the bounds. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27spi: fsl_qspi: Fix qspi_op_rdid memcpy issueGong Qianyu
In current driver everytime we memcpy 4 bytes to the dest memory regardless of the remaining length. This patch adds checking the remaining length before memcpy. If the length is shorter than 4 bytes, memcpy the actual length of data to the dest memory. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27spi: fsl_qspi: fix compile warning for 64-bit platformGong Qianyu
This patch fixes the following compile warning: drivers/spi/fsl_qspi.c: In function 'fsl_qspi_probe': drivers/spi/fsl_qspi.c:937:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct fsl_qspi_regs *)plat->reg_base; ^ Just make the cast explicit. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-24dm: x86: spi: Convert ICH SPI driver to driver model PCI APISimon Glass
At present this SPI driver works by searching the PCI buses for its peripheral. It also uses the legacy PCI API. In addition the driver has code to determine the type of Intel PCH that is used (version 7 or version 9). Now that we have proper PCH drivers we can use those to obtain the information we need. While the device tree has a node for the SPI peripheral it is not in the right place. It should be on the PCI bus as a sub-peripheral of the LPC device. Update the device tree files to show the SPI controller within the PCH, so that PCI access works as expected. This patch includes Bin's fix-up patch from here: https://patchwork.ozlabs.org/patch/569478/ Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24spi: ich: Separate out the read/write trace from normal debuggingSimon Glass
The trace is seldom useful for basic debugging. Allow it to be enabled separately so that it is easier to see the more important init and error debug messages. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
