path: root/drivers/spi
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27GCC4.6: Squash warnings in kirkwood_spi.cMarek Vasut
kirkwood_spi.c:125:2: warning: format '%08X' expects type 'unsigned int', but argument 4 has type 'const void *' kirkwood_spi.c:125:2: warning: format '%08X' expects type 'unsigned int', but argument 5 has type 'void *' kirkwood_spi.c:160:5: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'void *' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27GCC4.6: Squash warnings in fsl_espi.cMarek Vasut
fsl_espi.c: In function 'spi_setup_slave': fsl_espi.c:100: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' fsl_espi.c: In function 'spi_xfer': fsl_espi.c:237: warning: format '%08x' expects type 'unsigned int', but argument 5 has type 'const void *' fsl_espi.c:237: warning: format '%08x' expects type 'unsigned int', but argument 7 has type 'void *' Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27kirkwood_spi: add dummy spi_init()Michael Walle
The spi_init() function is missing. Add it. Signed-off-by: Michael Walle <michael@walle.cc>
2011-10-27ARM: kirkwood: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-10-27SPI: Add SPI driver support for Marvell Armada100Ajay Bhargav
This patch provides support for SPI emulated over SSP for Marvell Armada100 SOC. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-16Blackfin: bfin_spi: fix build error when DEBUG is definedMike Frysinger
The new debug() changes pointed out debug code that rotted a little. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-04IMX: uniform GPIO interface using GPIO frameworkStefano Babic
IMX processors has a slightly different interface to access GPIOs and do not make use of the provided GPIO framework. The patch substitutes mxc_ specific functions and make use of the API in asm/gpio.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-08-03AT91/SPI: fix atmel_dataflash_spi.c to allow building without warningsReinhard Meyer
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-25andes_spi: add andes_spi interfaceMacpaul Lin
andes_spi is an spi interface developed by Andes Tech. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-18MX31: Cleanup clock functionStefano Babic
The patch provide the same API used with other i.MX processors and get rid of mx31_ functions. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-06-21ATMEL spi_dataflash driver - fix to build againReinhard Meyer
The rework effort for ATMEL (AT91/AVR32) accidentially broke build of this driver. Fix this to make it build again. However this driver should be reworked as soon as possible! Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21mxc_spi.c: typo fixedHelmut Raiger
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2011-05-18ATMEL: fix dataflash (dirty) this file should be converted to struct SoC accessReinhard Meyer
2011-05-18ATMEL: fix related common atmel driver filesReinhard Meyer
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-30spi: add new driver for OpenCores tiny_spiThomas Chou
This patch adds support for OpenCores tiny_spi. http://opencores.org/project,tiny_spi Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-04-29powerpc: eSPI and eSPI controller supportMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-25bfin_spi: add spi_set_speedThomas Chou
The new speed will be applied by spi_claim_bus. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-13add CONFIG_SPI_IDLE_VAL for cf_spi.c to allow use of spi_mmcWolfgang Wegner
This patch adds CONFIG_SPI_IDLE_VAL to cf_spi.c The default setting is 0x0 to behave same as current version, in case CONFIG_SPI_MMC is set, the value is set to 0xFFFF (all ones). In either case, the value can be overwritten by board configuration. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-04-08Blackfin: BF50x: new processor portMike Frysinger
2011-03-27Coding Style cleanup: remove trailing empty linesWolfgang Denk
2011-02-08altera_spi: add spi_set_speedThomas Chou
Added this for mmc_spi driver. Though altera spi core does not support programmable speed. It is fixed when configured in sopc-builder. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-02spi: add support SuperH SPI moduleYoshihiro Shimoda
SH7757 has SPI module. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02SPI: mxc_spi: replace fixed offsets with structuresStefano Babic
This patch cleans driver code replacing all accesses to registers with fixed offsets with a corresponding structure. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02SPI: mxc_spi: add SPI clock calculation and setup to the driverAnatolij Gustschin
The MXC SPI driver didn't calculate the SPI clock up to now and just used highest possible divider 512 for DATA RATE in the control register. This results in very low transfer rates. The patch adds code to calculate and setup the SPI clock frequency for transfers. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02SPI: mxc_spi: fix swapping bug and add missing swapping in unaligned rx caseAnatolij Gustschin
We need to shift only one time in each cycle in the swapping loop for unaligned tx case. Currently two byte shift operations are performed in each loop cycle causing zero gaps in the transmited data, so not all data scheduled for transmition is actually transmited. The proper swapping in unaligned rx case is missing, so add it as we need to put the received data into the rx buffer in the correct byte order. Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2011-02-02SPI: mxc_spi: add support for i.MX35 processorStefano Babic
2010-12-11OMAP3: SPI driverDirk Behme
CC: Ruslan N. Araslanov <byaaka@yandex.ru> Signed-off-by: Ruslan Araslanov <ruslan.araslanov@vitecmm.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-11Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-02Blackfin: bfin_spi: add optional DMA supportMike Frysinger
This moves the last piece from the old spi_flash driver to the new SPI framework -- optional DMA RX support. This typically cuts speeds by ~40% at the cost of additional ~300 bytes. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-30MXC: Fix byte-ordering in SPI driver for i.MX31/i.MX51Stefano Babic
The actual SPI driver for i.MX31 and i.MX51 controller use a wrong byte ordering, because it is supposed to work only with Freescale's devices, as the Power Controllers (PMIC). The driver is not suitable for general purposes, because the buffers passed to spi_xfer must be 32-bit aligned, as it is used mainly to send integer to PMIC devices. The patch drops any kind of limitation and makes the driver useful with devices controlled sending commands composed by single bytes (or by a odd number of bytes), such as spi flash, sensor, etc. Because the byte ordering is changed, any current driver using this controller must be adapted, too. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-30MXC: Correct SPI_CPOL setting in SPI driverStefano Babic
The handling of the SPI_CPOL bit inside the SPI driver was wrong. As reported by the manual, the meaning of the SSPOL inside the configuration register is the same as reported by SPI specification (0 if low in idle, 1 is high on idle). The driver inverts this logic. Because this patch sets the logic as specified, it is required to clear the CPOL bit in the configuration file to adapt to the correct logic. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: David Jander <david.jander@protonic.nl>
2010-09-29Use common function to set GPIOs for MX3 and MX5Stefano Babic
The patch adds support for setting gpios to the MX51 processor and change name to the corresponding functions for MX31. In this way, it is possible to get rid of nasty #ifdef switches related to the processor type. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-21Blackfin: bfin_spi: use same gpio cs define as LinuxMike Frysinger
Linux uses an offset of 8 to switch from hardware cs to a gpio cs, so have u-boot use the same value. Also make sure it is public for boards to access. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-03AT91/AVR32: atmel_spi.c: flush RDR before next SPI transactionReinhard Meyer
2010-07-15Merge branch 'master' of ../masterWolfgang Denk
2010-07-13Blackfin: bfin_spi: support gpios as chip selectsMike Frysinger
Rather than only support the pins dedicated as chip selects, utilize the gpio framework to support any gpio pin. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bfin_spi: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Davinci: SPI: add the missing v2 patch changesNick Thompson
Two Indentation fixes. Catch requests for full-duplex transfers when driver configured for half-duplex operation only. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-22Davinci: SPI performance enhancementsNick Thompson
The following restructuring and optimisations increase the SPI read performance from 1.3MiB/s (on da850) to 2.87MiB/s (on da830): Remove continual revaluation of driver state from the core of the copy loop. State can not change during the copy loop, so it is possible to move these evaluations to before the copy loop. Cost is more code space as loop variants are required for each set of possible configurations. The loops are simpler however, so the extra is only 128bytes on da830 with CONFIG_SPI_HALF_DUPLEX defined. Unrolling the first copy loop iteration allows the TX buffer to be pre-loaded reducing SPI clock starvation. Unrolling the last copy loop iteration removes testing for the final loop iteration every time round the loop. Using the RX buffer empty flag as a transfer throttle allows the assumption that it is always safe to write to the TX buffer, so polling of TX buffer full flag can be removed. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-06-08DaVinci: Improve DaVinci SPI speed.Delio Brignoli
I have updated this patch based on the comments [1] by Wolfgang Denk and removed unused variables. [1][http://lists.denx.de/pipermail/u-boot/2010-May/071728.html] Reduce the number of reads per byte transferred on the BUF register from 2 to 1 and take advantage of the TX buffer in the SPI module. On LogicPD OMAP-L138 EVM, SPI read throughput goes up from ~0.8Mbyte/s to ~1.3Mbyte/s. Tested with a 2Mbyte image file. Remove unused variables in the spi_xfer() function. Signed-off-by: Delio Brignoli <dbrignoli@audioscience.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-05-28spi: add altera spi controller supportThomas Chou
This patch adds the driver of altera spi controller, which is used as epcs/spi flash controller. It also works with mmc_spi driver. This driver support more than one spi bus, with base list declared #define CONFIG_SYS_ALTERA_SPI_LIST { BASE_0,BASE_1,... } Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-05SPI: added support for MX51 to mxc_spiStefano Babic
This patch add SPI support for the MX51 processor. Signed-off-by: Stefano Babic <sbabic@denx.de>
