path: root/drivers/spi/pic32_spi.c
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-10spi: pic32_spi: add SPI master driver for PIC32 SoC.Purna Chandra Mandal
This driver implements SPI protocol in master mode to communicate with the SPI device connected on SPI bus. It handles /CS explicitly by controlling respective pin as gpio ('cs-gpios' property in dt node) and uses PIO mode for SPI transaction. It is configurable based on driver-model only. Cc: Jagan Teki <jteki@openedev.com> Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
