path: root/drivers/spi/omap3_spi.h
2013-11-12spi: omap3: add support for more word lengthsNikita Kiryanov
Current implementation only supports 8 bit word lengths, even though omap3 can handle anything between 4 and 32. Update the spi interface to support changing the SPI word length, and implement it in omap3_spi driver to support the full range of possible word lengths. This implementation is backwards compatible by defaulting to the old behavior of 8 bit word lengths. Also, it required a change to the omap3_spi non static I/O functions, but since they are not used anywhere else, no collateral changes are required. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2012-12-10OMAP3 SPI : Fixed bugs related to SPI transferajoy
Added posted writes (read after writes) to effect the change immediately for channel confiuration and channel enable register Disable the channel to purge receieve data in TX_ONLY mode transfer otherwise rx data will get affected by the next immediate RX_ONLY mode transfer Wait for the EOT bit to be set after last byte has been loaded to TX shift register in the the TX_ONLY mode.This ensures TX data has been completely shifted out Disable the channel in RX_ONLY mode before reading the last data from RXX register to prevent the SPI slave to transmit next word Signed-off-by: Ajoy Kumar Das <akdas75@yahoo.in> Cc: Tom Rini <trini@ti.com> Cc: jacopo mondi <j.mondi@voltaelectronics.com>
2012-09-01am33xx: Add support, update omap3 McSPI driverTom Rini
2012-03-27omap3_spi: receive transmit modejacopo mondi
Implementation of receive-transmit mode for omap3 MCSPI. Introduces full duplex communication, needed by some spi devices (such as enc28j60). Signed-off-by: jacopo mondi <mondi@cs.unibo.it> <j.mondi@voltaelectronics.com>
2010-12-11OMAP3: SPI driverDirk Behme
CC: Ruslan N. Araslanov <byaaka@yandex.ru> Signed-off-by: Ruslan Araslanov <ruslan.araslanov@vitecmm.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
