This name is far too long. Rename it to remove the 'data' bits. This makes
it consistent with the platdata->plat rename.
Rename this to be consistent with the change from 'platdata'.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
After latest improvements on OF_PLATDATA struct names are generated
based on driver name instead of compatible strings. With this in mind,
using aliases in drivers are not longer needed.
This patch removes code that tried to handle these kind of aliases to
improve readability.
Signed-off-by: Walter Lozano <walter.lozano@collabora.com>
Currently when using OF_PLATDATA the binding between devices and drivers
is done trying to match the compatible string in the node with a driver
name. However, usually a single driver supports multiple compatible strings
which causes that only devices which its compatible string matches a
driver name get bound.
To overcome this issue, this patch adds the U_BOOT_DRIVER_ALIAS macro,
which generates no code at all, but allows an easy way to declare driver
name aliases. Thanks to this, dtoc could be improve to look for the driver
name based on its alias when it populates the U_BOOT_DEVICE entry.
When using OF_PLATDATA, the bind process between devices and drivers
is performed trying to match compatible string with driver names.
However driver names are not strictly defined, and also there are different
names used when declaring a driver with U_BOOT_DRIVER, the name of the
symbol used in the linker list and the used in the struct driver_info.
In order to make things a bit more clear, rename the drivers names. This
will also help for further OF_PLATDATA improvements, such as checking
for valid driver names.
Add a fix for sandbox of-platdata to avoid using an invalid ANSI colour:
Order the macros, private structures and simple functions
in a proper way to have more code readability.
No functionality changed.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Deadline for DM migration already passed by months
and no response on full dm conversation hence removed
the nondm code.
Note: Look like there is no user for nondm code
for this driver.
Move this uncommon header out of the common header.
Move this header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
After this patch the mxs_spi.c DM/DTS driver can be used at early SPL to
read payload from SPI-NOR memories.
It was necessary to adjust its name to 'fsl_imx_2{38}_spi' to match
requirements for SPL_OF_PLATDATA usage.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Without this change the DM/DTS version of mxs_spi driver doesn't reset the
SPI IP block in probe.
As a result this driver (when used solely on U-Boot proper) relies on reset
performed by mxs spi driver in SPL.
In the use case where eMMC is used in SPL as a boot primary device, the
mxs_reset_block() is not called at all and DM/DTS aware SPI driver in
U-Boot proper is malfunctioning.
This change initializes proper member of struct driver -
platdata_auto_alloc_size instead of priv_auto_alloc_size, which is setup
twice.
This patch converts mxs_spi driver to support DM/DTS.
Remove spi_init definition which never used on
respective code since from many years.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Now that we have a new header file for cache-aligned allocation, we should
move the stack-based allocation macro there also.
The chipselect must be written into the CTRL0 register after the SSP
block is reset, otherwise the block will always use ChipSelect #0.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
[trini: Fixup common/cmd_io.c]
The following headers are moved to a i.MX common location:
- regs-common.h
- regs-apbh.h
- regs-bch.h
- regs-gpmi.h
- dma.h
This way this header can be re-used also by other i.MX platforms.
For example the i.MX6 which will need it for the upcoming NAND
support.
Rather than each driver having its own way to allocate a SPI slave,
use the new allocation function everywhere. This will make it easier
to extend the interface without breaking drivers.
The CONFIG_MXS_SPI_DMA_ENABLE is no longer relevant as the SPI DMA
has proven to work correctly. Remove this configuration option.
The MX23 has slightly different register layout. Adjust the SPI
driver to match the layout, both the PIO and DMA part.
This patch streamlines the differences between the MX23 and MX28 by
implementing a few helper functions to handle different DMA channel
mapping, different clock domain for SSP block and fixes a few minor
bugs.
First of all, the DMA channel mapping is now fixed in dma.h by defining
the actual channel map for both MX23 and MX28. Thus, MX23 now does no
longer use MX28 channel map which was wrong. Also, there is a fix for
MX28 DMA channel map, where the last four channels were incorrect.
Next, because correct DMA channel map is in place, the mxs_dma_init_channel()
call now bases the channel ID starting from SSP port #0. This removes the
need for DMA channel offset being added and cleans up the code. For the
same reason, the SSP0 offset can now be used in mxs_dma_desc_append(), thus
no need to adjust dma channel number in the driver either.
Lastly, the SSP clock ID is now retrieved by calling mxs_ssp_clock_by_bus()
which handles the fact that MX23 has shared SSP clock for both ports, while
MX28 has per-port SSP clock.
Finally, the mxs_ssp_bus_id_valid() pulls out two implementations of the
same functionality from MMC and SPI driver into common code.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Create function which converts SSP bus number to SSP register pointer.
This functionality is reimplemented multiple times in the code, thus
make one common implementation. Moreover, make it a switch(), since the
SSP ports are not mapped in such nice linear fashion on MX23, therefore
having it a switch will simplify things there.
Cc: Andy Fleming <afleming@freescale.com>
It turns out that in order for the SPI DMA to properly support
continuous transfers longer than 65280 bytes, there are some very
important parts that were left out from the documentation.
Firstly, the XFER_SIZE register is not written with the whole length
of a transfer, but is written by each and every chained descriptor
with the length of the descriptors data buffer.
Next, unlike the demo code supplied by FSL, which only writes one PIO
word per descriptor, this does not apply if the descriptors are chained,
since the XFER_SIZE register must be written. Therefore, it is essential
to use four PIO words, CTRL0, CMD0, CMD1, XFER_SIZE. CMD0 and CMD1 are
written with zero, since they don't apply. The DMA programs the PIO words
in an incrementing order, so four PIO words.
Finally, unlike the demo code supplied by FSL, the SSP_CTRL0_IGNORE_CRC
must not be set during the whole transfer, but it must be set only on the
last descriptor in the chain.
Cc: Fabio Estevam <festevam@gmail.com>
This patch fixes dcache-related problem. The problem manifested
when dcache was enabled and the following command issued twice:
mw 0x42000000 0 0x4000 ; sf probe ; sf read 0x42000000 0x0 0x10000 ; sha1sum 0x42000000 0x10000
The SHA1 checksum was correct during the first call. Yet with
every subsequent call of the above command, it differed and was
wrong.
It turns out this was because of a race condition. On the first
time the command was called, no cacheline contained any data from
the destination memory location. The DMA transfered data into the
location and the cache above the location was invalidated. Then the
checksum was computed, but that meant the data were loaded into data
cache.
On any subsequent call, the DMA again transfered data into the same
destination. Yet during the transfer, some of the DCache lines were
evicted and written back into the main memory. Once the DMA transfer
completed, the data cache was invalidated over the memory location as
usual. But the data that were to be loaded back into the data cache
by subsequent SHA1 checksuming were corrupted.
This change implements DMA chaining into SPI driver. This allows
the transfers to go much faster, while also fixing SF issues.
Use calloc() instead of malloc() to allocate the mxs_spi_slave structure.
Clearing the memory is necessary since most of the time this gets done
super early in boot, but on warm reboots, and when SPI probing is done
long after the init stages it could actually pick up previously used memory,
and things like the chipselect polarity and other data end up being filled
with trash data if not explicitly set by the board files.
This solves a semi-random, almost unreproducable error whereby SPI devices
act very, very strangly on boot.
Signed-off-by: Matt Sealey <matt@genesi-usa.com>
The sys_proto.h functions (except the boot modes) are compatible with
i.MX233 and i.MX28 so we use 'mxs' prefix for its methods.
The DMA transfers happen only if the transfered data are larger
than 512 bytes. Otherwise PIO is used. This is a small speed
optimization.
The DMA transfer doesn't work if unaligned transfer is requested
due to the limitation of the DMA controller. This has to be fixed
by introducing generic bounce buffer. Therefore the DMA feature
is now disabled by default.
Pull out all the PIO transfer logic into separate function,
so DMA can be added.
This makes it easier to adapt for addition of DMA support.
MXS SSP controller may have up to three chip selects per port: SS0, SS1 and SS2.
Currently only SS0 is supported in the mxs_spi driver.
Allow all the three chip select to work by selecting the desired one
in bits 20 and 21 of the HW_SSP_CTRL0 register.
Introduce spi_cs_is_valid() for validating spi bus and chip select numbers.
Instead of returning -1, it is preferred to return -ETIMEDOUT in case of timeouts.
The generic spi flash driver (drivers/mtd/spi/spi_flash.c) uses the
spi low level driver's spi_xfer() function with len=0 to deassert the
SPI flash' chip select. But the i.MX28 spi driver rejects this call
due to len=0.
This patch implements an exception for len=0 with the SPI_XFER_END
flag set. This results in an extra read with the chip select being
deasserted afterwards. There seems to be no way to deassert the signal
by hand.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Detlev Zundel <dzu@denx.de>
